12 Oct 2020, 18:04
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 2 422 Inscrit : 31 Dec 2005 Lieu : La Drôme Membre no 52 618 |
Bonsoir à tous.
J'ai quelques galères pour installer la dernière mise à jour de ce logiciel. Je suis en contact avec le service technique mais mes connaissances en terminal ne sont pas assez fortes. Qu'un peut il m'aider avec ce processus? J'arrive bien à démarrer cmd-R et tapez chroot mais comment injecter dans le terminal les deux scripts car je n'ai plus accès au bureau? Une âme charitable? Cordialement. Removing all previous approvals / blocks for TripMode's KEXT This relies on two scripts attached to this post and requires rebooting so keep a copy of this note accessible. Save the scripts to an easily accessible place on your disk Give those scripts execution rights for everyone (chmod ugo+x removeTMKEXT.sh and chmod ugo+x listKEXTSP.sh) Restart in recovery (Cmd + R) Go the ‘Utilities’ Menu > Terminal Very important : chroot your normal startup disk, which is mounted in /Volumes in Recovery mode. For example chroot “/Volumes/Macintosh HD”. You need to adapt this to how your startup disk is named. Execute the removeTMKEXT.sh script (you can also execute the list script before and after, to check that the TeamID was correctly removed) Reboot in the normal OS The KEXT block should be reset to the original setting : the warning dialog will show and the message in System Preferences will prompt for approval Use latest TripMode 2.3. This build takes the new policy into account and stops the install to wait for approval if necessary Note : as previously written, some builds of macOS High Sierra beta are broken in regard to the allow mechanism. This is an OS bug that has been reported to Apple and needs to wait for their fix. Whitelisting the TripMode KEXT This procedure is to be used if the previous one did not work. The steps to follow are the same, until after executing the remove script. Before rebooting, execute the spctl kext-consent add 78UFGP42EU command to whitelist the TripMode kernel extension. Alternatively, it is possible to disable all KEXT consent warnings and allow the extensions to load as they did in macOS Sierra, but this is not recommended. This is done by running spctl kext-consent disable. Again, we do not recommend this option and it does not need to be used if the add option works. Reboot and relaunch the TripMode install. You should not be prompted for approval again, and the install should finish as it did in previous macOS versions. Ce message a été modifié par annapurna - 12 Oct 2020, 18:06. -------------------- Imac 27" I7 4,2Ghz 48Go de Ram Radeon pro 580 Ventura 13.7.8 / Iphone 13 pro iOS 26.2 256Go
MacBook Pro 15"Core i7 2,8ghz SSD 1To mid 2014 Ventura 13.7.8 OCLP 2.4.1 pâte thermique changée le 04/08/22 “La photographie est une brève complicité entre la prévoyance et le hasard.” John Stuart Mill |
12 Oct 2020, 18:15
Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 11 698 Inscrit : 15 Nov 2007 Lieu : Auvergne-Rhône-Alpe. Membre no 99 922 |
Où se trouvent tes 2 scripts? Sur le Bureau? |
12 Oct 2020, 18:38
je les ai téléchargé.
je te les envoi en MP? -------------------- Imac 27" I7 4,2Ghz 48Go de Ram Radeon pro 580 Ventura 13.7.8 / Iphone 13 pro iOS 26.2 256Go
12 Oct 2020, 18:48
je les ai téléchargé. je te les envoi en MP? Pas la peine. Il faut copier ces 2 scripts sur le Bureau avant tout puis les rendre exécutables : Code chmod a+x removeTMKEXT.sh puis Code chmod a+x listKEXTSP.sh Ensuite tu démarres en mode Recovery (cmd+R) Quand tu as fait le : Code chroot "/Volumes/Macintosh HD" Il faut te positionner au bon endroit : sur ton espace utilisateur dans le Bureau. Pour ce faire tu tapes la commande suivante : (je suppose que ton nom d'utilisateur est annapurna sinon il faut adapter) Code cd /Users/annapurna/Desktop Puis tu exécutes le script : Code ./removeTMKEXT.sh
Ce message a été modifié par jeanjd63 - 12 Oct 2020, 18:53. |
12 Oct 2020, 19:25
cool j'essaye demain. merci de ton aide précieuse.
12 Oct 2020, 20:14
13 Oct 2020, 07:43
bonjour Jeanjd63
j'ai respecté les scripts et la procédure indiquée ci-dessus mais j'ai un retour terminal pour: cd /Users/annapurna/Desktop. no such file or directory meme chose pour les suivants... -------------------- Imac 27" I7 4,2Ghz 48Go de Ram Radeon pro 580 Ventura 13.7.8 / Iphone 13 pro iOS 26.2 256Go
13 Oct 2020, 07:49
bonjour Jeanjd63 j'ai respecté les scripts et la procédure indiquée ci-dessus mais j'ai un retour terminal pour: cd /Users/annapurna/Desktop. no such file or directory meme chose pour les suivants... Quel est ton nom d'utilisateur sur le Mac? annapurna est un exemple qu'il faut adapter. |
13 Oct 2020, 08:10
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 7 367 Inscrit : 9 Feb 2002 Lieu : Cambodge Membre no 2 013 |
La camionnette Darty 4x4 à la conquête des grands sommets
Jusqu'où s'arrêtera t-il? -------------------- Actuellement : Mac Studio M4 Max (16 C-40 C) 64 GB 1 TB – Acasis 40 Gbps M.2 NVMe 4 Bay Tb4 – Acasis 80 Gbps M.2 NVMe SSD enclosure Tb5 – ACASIS 40Gbps Dock TB 4/3 Devices, USB 4, 13-in-1
13 Oct 2020, 16:57
Un grand merci à @Jeanjd63 pour sa patience.
A l'heure actuelle, aucune solution n'a été trouvée me concernant. Un-e installation SIP désactivée fonctionne mais dés celle ci réactivée, impossible de lancer l'application... Meme chose sur un autre compte. Le fichier noyau KEXT semble poser souci. Je renvois un message au service de maintenance afin d'en savoir plus. Ce message a été modifié par annapurna - 13 Oct 2020, 16:58. -------------------- Imac 27" I7 4,2Ghz 48Go de Ram Radeon pro 580 Ventura 13.7.8 / Iphone 13 pro iOS 26.2 256Go
21 Oct 2020, 19:19
Bonsoir à tous...
non non je ne vous ai pas oublié mais aucun retour des developeurs à séjour... -------------------- Imac 27" I7 4,2Ghz 48Go de Ram Radeon pro 580 Ventura 13.7.8 / Iphone 13 pro iOS 26.2 256Go
18 Dec 2020, 08:42
Bonjour à tous
je tiens à remercier @jeanjd63 pour son aide précieuse. L'unique solution trouvée pour pallier mon problème fut de créer une nouvelle partition, faire une clean Install du système et de tous mes logiciels. Une fois celle ci opérationnelle et fonctionnelle, nous l'avons rapatriée sur la précédente en l'écrasant. Je tiens à dire que je ne suis pas très content du service après vente de Tripmode qui malgré nos demandes ne nous a pas accompagner pour trouver une solution. bonnes fêtes. ps je ne me rappelle plus la manip pour éditer le titre et indiquer Résolu? merci. Ce message a été modifié par annapurna - 18 Dec 2020, 08:49. -------------------- Imac 27" I7 4,2Ghz 48Go de Ram Radeon pro 580 Ventura 13.7.8 / Iphone 13 pro iOS 26.2 256Go
18 Dec 2020, 13:43
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Modérateurs Messages : 20 341 Inscrit : 22 Jul 2004 Lieu : Louvain-la-Neuve (Gaule Gelbique) Membre no 21 291 |
Il faut cliquer sur le bouton Editer > Edition complète en dessous du 1er message, mais ça ne marche que pendant 30 jours.
Je m'en occupe. -------------------- ¶ MacBook Pro 14’’ 2021, M1 Pro, 16 Go/1 To – macOS 12.6 “Monterey” ¶ MacBook Pro 15’’ mi-2010 Core i5 2,53 GHz, 8 Go/SSD Samsung 860EVO 1 To – Mac OSX 10.6.8 ¶ Power Macintosh G3 beige de bureau, rev.1 @ 233MHz, 288 Mo/4Go – MacOS 9.1 + carte PCI IDE/ATA Tempo 66 Acard 6260 avec HD interne Maxtor 80 Go + graveur interne CDRW/DVD LG GCC-4520B + tablette A4 Wacom UD-0608-A + LaCie ElectronBlueIV 19" + HP ScanJet 6100C ¶ B-Box 3 +
18 Dec 2020, 18:23
merci @baron
| Nous sommes le : 14th May 2026 - 05:31 |
