7 Pages V  « < 4 5 6 7 >
> Attention - Mise à jour de sécurité Mojave 2020-005
Patrice Broussea...
posté 2 Oct 2020, 20:08
Message #151
Inscrit : 18 Jan 2015
Lieu : Montréal, Québec
Membre no 193 846
Citation (maclinuxG4 @ 2 Oct 2020, 14:15) *
question: qui peux confirmer update 2020-005 puis safari 14.0 :
la présence des messages résiduelles dans console , system.log:
svp vérifier si vous avez encore des messages comem ci dessous se terminant par One of the two will be used. Which one is undefined.
voici une liste du genre
objc[XXXX]: Class ASDPurchaseResult is implemented in both /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Versions/A/AppStoreDaemon (0x7fff9f2cdbe8) and /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent (0x100c0fd40). One of the two will be used. Which one is undefined.
ci dessous la liste:
objc[379]: Class ISPurchaseReceipt is implemented in both /System/Library/PrivateFrameworks/StoreServices.framework/Versions/A/StoreServices (0x7fffa1c0ba38) and /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore (0x121141f48). One of the two will be used. Which one is undefined.
soagent[379]: objc[379]: Class asn1Token is implemented in both /System/Library/PrivateFrameworks/StoreServices.framework/Versions/A/StoreServices (0x7fffa1c0b628) and /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore (0x121142038). One of the two will be used. Which one is undefined.
soagent[379]: objc[379]: Class asn1SetToken is implemented in both /System/Library/PrivateFrameworks/StoreServices.framework/Versions/A/StoreServices (0x7fffa1c0b650) and /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore (0x121142010). One of the two will be used. Which one is undefined.
soagent[379]: objc[379]: Class asn1SequenceToken is implemented in both /System/Library/PrivateFrameworks/StoreServices.framework/Versions/A/StoreServices (0x7fffa1c0b678) and /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore (0x121141fe8). One of the two will be used. Which one is undefined.
Note de la modération : Liste tronquée, aucun intérêt avéré de tout copier ici.
J’avais lu quelque part que c’est pas génial ce message (MacRumors?). Cela signifie, je pense, qu’il y a un truc de vérolé au niveau du code... mais je peux me tromper!
Nouveau Hackintosh dédié MAO • Gigabyte Designare i9 9900K 3,6GHz - RX560 - 96 Go DDR4 - OS X 10.14.6/Win 10 - OpenCore 0.8.8 Mod No ACPI
Hackintosh Bureau • Dell XPS 8930 i7 8700 3,2GHz - Radeon RX5500 - 32 Go DDR4 - MacOS 13.7/Windows 11 - OpenCore 1.0.1
MacMini 2018 i7 8700B 3,2 GHz - eGPU RX5500XT - 64 Go DDR4 - MacOS 13.7.3/MacOS 15.3.1/Windows 11
maclinuxG4
posté 2 Oct 2020, 20:14
Message #152
Inscrit : 28 Dec 2001
Lieu : ile de france
Membre no 1 715
BARON je ne suis pas du tout d'accord
itune
Oct 2 21:04:44 iMac-de-coin iTunes[7139]: objc[7139]: Class AMSBag_DeviceOffers is implemented in both /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/CommerceKit (0x7fff9fc05420) and /Applications/iTunes.app/Contents/MacOS/iTunes (0x10dd9b018). One of the two will be used. Which one is undefined.
Apple store
rtcreportingd[7109]: objc[7109]: Class UpdateAndReportServices is implemented in both /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting (0x7fffa29e5e60) and /usr/libexec/rtcreportingd (0x10570afe0). One of the two will be used. Which one is undefined.
rtcreportingd[7109]: objc[7109]: Class RTCReportingAggregationObject is implemented in both /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting (0x7fffa29e5d98) and /usr/libexec/rtcreportingd (0x10570b300). One of the two will be used. Which one is undefined.
rtcreportingd[7109]: objc[7109]: Class RTCReporting is implemented in both /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting (0x7fffa29e5d70) and /usr/libexec/rtcreportingd (0x10570b350). One of the two will be used. Which one is undefined.
book
Books[7116]: objc[7116]: Class bb74bdd798ceadff5c1f0c2b is implemented in both /Applications/Books.app/Contents/Frameworks/BKPlatformCore.framework/Versions/A/BKPlatformCore (0x10b7ea768) and /Applications/Books.app/Contents/MacOS/Books (0x10a9f0430). One of the two will be used. Which one is undefined.
Books[7116]: objc[7116]: Class BKAnimatedNoteWindow is implemented in both /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit (0x7fff9f2a2d30) and /Applications/Books.app/Contents/PlugIns/BKAssetEpub.bundle/Contents/MacOS/BKAssetEpub (0x113f51420). One of the two will be used. Which one is undefined.
Books[7116]: objc[7116]: Class BKMutableNoteMarginView is implemented in both /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit (0x7fff9f2a5418) and /Applications/Books.app/Contents/PlugIns/BKAssetEpub.bundle/Contents/MacOS/BKAssetEpub (0x113f51d58). One of the two will be used. Which one is undefined.
Books[7116]: objc[7116]: Class bb74bdd798ceadff5c1f0c2b is implemented in both /Applications/Books.app/Contents/Frameworks/BKPlatformCore.framework/Versions/A/BKPlatformCore (0x10b7ea768) and /Applications/Books.app/Contents/PlugIns/BKAssetEpub.bundle/Contents/MacOS/BKAssetEpub (0x113f53478). One of the two will be used. Which one is undefined.
system
coreauthd[295]: objc[295]: Class TKTokenRefImpl is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fff9e91a0d8) and /System/Library/Frameworks/LocalAuthentication.framework/Support/ModulePlugins/ModuleACM.bundle/Contents/MacOS/ModuleACM (0x10d71ef30). One of the two will be used. Which one is undefined.
coreauthd[295]: objc[295]: Class TKTokenRefCtkd is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fff9e91a100) and /System/Library/Frameworks/LocalAuthentication.framework/Support/ModulePlugins/ModuleACM.bundle/Contents/MacOS/ModuleACM (0x10d71ef58). One of the two will be used. Which one is undefined.
com.apple.preference.security.remoteservice[7193]: objc[7193]: Class AWDSecurityPrefAutoUnlockSetup is implemented in both /System/Library/PreferencePanes/Security.prefPane/Contents/XPCServices/com.apple.preference.security.remoteservice.xpc/Contents/MacOS/com.apple.preference.security.remoteservice (0x1068948e0) and /System/Library/PreferencePanes/Security.prefPane/Contents/MacOS/Security (0x1091fa330). One of the two will be used. Which one is undefined.
icloud
com.apple.preferences.icloud.remoteservice[7218]: objc[7218]: Class ITNSImage is implemented in both /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/iTunesLibrary (0x7fff9eef82a0) and /System/Library/CoreServices/SetupAssistantPlugins/iTunes.icdplugin/Contents/MacOS/iTunes (0x106de2398). One of the two will be used. Which one is undefined.
t 2 21:26:54 iMac-de-coin WeatherService[7352]: objc[7352]: Class WFWeatherChannelParser is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf520) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a6e20). One of the two will be used. Which one is undefined.
plan
WeatherService[7352]: objc[7352]: Class WFTemperatureUnitChangeRequest is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adfbd8) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a6e98). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFDefaultFavoritesProvider is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf250) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a6ec0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFWeatherUndergroundParser is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adfc00) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a6f10). One of the two will be used. Which one is undefined.
iMac-de-coin WeatherService[7352]: objc[7352]: Class WFWeatherStoreService is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adfb10) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a6f60). One of the two will be used. Which one is undefined.
iMac-de-coin WeatherService[7352]: objc[7352]: Class WFUserDefaultsPersistence is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf2f0) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a6fb0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFWeatherUndergroundRequestFormatter is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf4a8) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7028). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFLocationQueryGeocode is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf430) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7050). One of the two will be used. Which one is undefined.
iMac-de-coin WeatherService[7352]: objc[7352]: Class WFTemperatureUnitResponse is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf570) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a70a0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFQueryDispatcher is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adfd90) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a70f0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFTemperatureUnitProvider is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3ae0150) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7140). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFAggregateDictionary is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adfac0) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7190). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFWeatherStoreServiceConfiguration is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf340) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a72d0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFReachabilityConfigurationResponse is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3ae0240) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7370). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFJSONStructureLeafNode is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf660) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7410). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFWeatherChannelValidator is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf6b0) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7460). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFWeatherChannelRequestFormatter is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf408) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a74d8). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFParsedForecastData is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf5e8) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7528). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFForecastDataParser is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf638) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7578). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFTemperature is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adfe80) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a75a0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WeatherService is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf750) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a75f0). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFWeatherStoreCache is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf390) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7640). One of the two will be used. Which one is undefined.
WeatherService[7352]: objc[7352]: Class WFLocationQueryGeocodeCache is implemented in both /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/WeatherFoundation (0x7fffa3adf700) and /System/Library/PrivateFrameworks/WeatherFoundation.framework/Versions/A/XPCServices/WeatherService.xpc/Contents/MacOS/WeatherService (0x1099a7690). One of the two will be used. Which one is undefined.
il semble qu'il reste encore des éléments, ils sont présent.
Cependant, j ai passé ONYX puis redémarrer, la liste diminue, mais j ai encore des messages.
Merci de me confirmer.
NOTA: il suffit de laisser la console ouverte et de lancer une application, vous verrez si un message de ce type est présent ou pas.
c'est pas normal, je pense que l'usage classique conserve un peu des traces
Merci de confirmer
Ce message a été modifié par maclinuxG4 - 3 Oct 2020, 06:08.
Patrice Broussea...
posté 2 Oct 2020, 20:24
Message #153
Membre no 193 846
Message d’un utilisateur sur le site de Mr Macintosh:
Résultat: l'économiseur d'écran se fige toujours lorsque j'essaye de charger mes photos ou de déplacer le curseur dans le coin activé de l'écran.
Tout support sera très apprécié
Il semblerait donc que tout ne soit pas totalement réglé. Si, en plus, il y a des messages d’erreurs récurrents dans le log, je m’abstiendrai de Safari 14...
@maclinuxG4: c’est dû à Safari 14 ou 2020-005? Peut-être ne connais-tu pas la réponse mais reste que ça fait un peu tache...
maclinuxG4
posté 2 Oct 2020, 20:39
Message #154
Membre no 1 715
Citation (Patrice Brousseau @ 2 Oct 2020, 21:24) *
c'est du à un décalge entre les deux livraisons, en cas d'application asymétrie (genre 1 -> 2 OK mais 2 -> 1 KO)
la mise à jour n'as pas intégré ce que safari 14 a livré....C'est tout.
normalement, avant de publier, tu dois avoir une liste de PR pour chaque livraison, tu sais si elle sont prise en compte ou pas.
Mais comme les équipes sont totalement différentes, si un manager as eut la pression ou ordre de livrer ou si pour éviter une transition sur icloud, safari a été proposé pour l'update.
Impossible pour le grand public de savoir cela, c'est le temps qu'appel analyse et regroupe les informations, cela à pris trop de temps.
pour moi, sur un produit, tu installe mojave à jour (2020-004) stable sur 2 machines, tu applique 1->2 sur l'un et sur l'autre 2->1
et tu vois que le résultat est différent, tu ne livre pas, tu demande que quel ordre est il à appliqué ? puis tu livre
Quand je dis cela n'as pas été testé, c'est très clair.
D'autant que moi, j utilise memory clean 3, dont toutes les application tiers par les sociétés éditrices ou d'un coup aussi des demandes.
j ai contacté le support, ils ont vu venir....ils attendent..... et je leur donne raison, ils modifieront plus tard
C'est génial la data numérique, le données, mais quand tu fait un erreur, pense à l'opération clean qu'il va falloir réaliser ( nettoyage des bases de données, log, l'horreur,...)
si ce n'est pas automatique est prévue ouille et le cout je n'imagine même pas.
Ce message a été modifié par maclinuxG4 - 7 Oct 2020, 10:11.
Patrice Broussea...
posté 2 Oct 2020, 21:56
Message #155
Membre no 193 846
Citation (maclinuxG4 @ 2 Oct 2020, 15:39) *
Mais comme les équipes sont totalement différentes, si un manager as eut la pression ou ordre de livrer ou si pour éviter une transition sur icloud, safari as été proposé pour l'update.
si cen'est pas automatique est prévue ouille et le cout je n'imagine même pas.
Tu parles du bug initial ou les messages de log toujours présents après le « correctif »? Pas trop sûr de te suivre...
Je ferai un test de la 2020-005 (sans Safari 14) sur mon « crash test » clone USB et te dirai si les messages d’erreurs apparaissent dans le log.
Édition:
Vu toutes les apps qui apparaissent dans ton log, ça doit être la mise à jour Sécurité.
Ce message a été modifié par Patrice Brousseau - 2 Oct 2020, 22:02.
baron
posté 2 Oct 2020, 22:40
Message #156
Inscrit : 22 Jul 2004
Membre no 21 291
Il y a simplement deux mises à jour qui se télescopent.
Une réinstallation de la version combo en conservant les données suivie de l'application des mises à jour aujourd'hui proposées par le système (pas via le site d'Apple !) devrait suffire à remettre le tout d'aplomb.
Aucun besoin de poster ici la liste de tous tes fichiers doublons pour qu'on comprenne le problème… rolleyes.gif
allmitel
posté 2 Oct 2020, 22:58
Message #157
Inscrit : 29 Sep 2020
Membre no 212 489
@Yves : comme je suis du genre têtu, j'ai donc testé (histoire de ne pas m'avancer sans vérifier).
Passage de 10.14.6 "tout updaté" vers un 10.14 trouvé d'internet (mais j'en ai vérifié l'authenticité, et c'est pas bien compliqué). Et retour à 10.14.6 à partir d'un installeur téléchargé début septembre.
> Pour le passage vers 10.14 : possible en mode on-line direct depuis le bureau. "Évidemment" qu'il faut couper internet + changer la date avant : c'est valable pour TOUT CE QUI EST SORTI D'APPLE AVANT LA MI-OCTOBRE 2019.
> Pour le retour vers 10.14.6 : ça marche sans bidouille aucune.
Bref : j'ai la conviction que tu racontes n'importe quoi ou que tu n'as pas vraiment compris ce qu'il fallait faire. Ou alors que tu tentes le 10.15.6 vers 10.14.6…
Sinon par "logiciel gris", c'est pas non plus très compliqué de comprendre = marché "gris", pas vraiment légal. En clair ceux qui piratent Office et/ou Adobe et/ou tout autre "gros" logiciel pro.
J'ai écrit et surligné en vert que ça ne s'appliquait pas à ceux qui ont des matériels/logiciels non supporté par la suite + confirmé dans un message que cette histoire de "mauvaise fois" ne s'appliquait pas à toi spécifiquement.
Répéter 100 fois que Apple n'a pas "réparé" son installeur de Mojave 10.14.6 n'en fera pas une vérité pour autant. Et ce n'est pas l'installeur lui-même le problème, c'est le certificat qui lui est appliqué. Si c'est téléchargé avant la mi-octobre 2019 = ça a expiré à la mi-octobre 2019. Téléchargé après = ça expirera le 14 avril 2029. Ça m'a pris 10 secondes à trouver cette date. Pas la peine de chouiner.
Je te propose d'aller jeter un œil par là : spécifiquement les images.
> Du coup "donner des conseils" ainsi approximatifs à qui veut l'entendre, c'est assez agaçant.
@Maclinux : désolé d'être cash (mais je m'en fout un peu) : tes histoires de log et de 1>2 OK et 2>1KO sont incompréhensibles en français non spécialiste.
Ce que je crois que tu veux dire c'est qu'ils ont testé la mise à jour dans un scénario 10.14.6 > Security Update 2020-005 > Safari 14 mais qu'ils n'ont pas testé le scénario 10.14.6 > Safari 14 > Security Update 2020-005, ce qu'ils auraient dû parce que c'est ce qu'ils ont finalement mis en ligne et qu'on a la preuve que la Security Update 5 "casse" d'une certaine façon ce qui avait été installé pour Safari 14.
Je ne vois pas ce que iCloud vient faire la dedans ni ton outil (à mon sens inutile) de nettoyage de RAM.
Enfin d'une façon générale : c'est beaucoup (moi y compris) d'énergie dépensée et de brassage d'air pour une affaire qui aura été bouclée en moins d'une semaine. À trop regarder les processus pousser, on en vient à faire n'importe quoi. Et le mieux est de revenir aux essentiels :
- je repasse un coup de la dernière ComboUpdate.
- réinstaller le "même" système par dessus ça marche.
- reset de la PRAM/NVRAM et du SMU
- un tour d'Onyx
à une époque on aurait ajouté :
- on vérifie les autorisations.
Ce message a été modifié par allmitel - 2 Oct 2020, 23:18.
Yves PRA
Message #158
Inscrit : 11 Sep 2002
Lieu : Pas loin de Grenoble (Là bas, sous la Montagne)
Membre no 3 458
Je ne suis pas assez calé pour tout comprendre des messages de la console et des doublons, mais en gros tout n'est pas réglé ?
les correctifs des mises à jour ne corrigent pas tout, du moins pour ceux qui ont fait la "premiere" mise à jour de sécurité 005 ?
MacBook Pro 15.4/Core i7 2,6 Ghz/16 Go sous 10.14.6, (UN Hackintosh) i7 4790K 4,0 Ghz/32 Go RAM CM Gigabyte Z87X-UD5H CG NVIDIA GeForce GTX 770, avec 10.14.6 Clover "Made in Macbidouille". Un Mac Studio M4 en rodage sous Tahoe. Et un PC Win 11 + quelques antiquités (Mac Mini 2012, G5 biprocesseur 2005, G4 Graphite)
Yves PRA
posté 2 Oct 2020, 23:40
Message #159
Membre no 3 458
Pour Almintel :
j'ai effectivement utilisé le "vieil" installeur de Mojave (celui téléchargé 3 fois en aout) et pas le nouveau de début octobre 2020.
Sans doute par flemme ou fatigue de télécharger la même chose pour la 4ème fois, en espérant que ce sera enfin la bonne.
Donc la solution proposée par Apple est la meilleure : télécharger, re-télécharger, encore et encore, jusqu'à ce que ça marche.
Je suis totalement désolé d'avoir "donné des conseils aussi approximatifs" à Magnétophone, qui a finalement réussi à réinstaller Mojave sur son Mac Mini livré avec Catalina.
En lisant ses messages, on voit combien ça a été facile, rapide, et à la portée de tout utilisateur. Surtout avec les conseils avisés du support Apple.
Pour en revenir à la mise à jour de sécurité 005, il semble que les 2 nouvelles MàJ proposées ne règlent pas tout, ou pas pour tout le monde.
Donc, encore un peu d'attente avant de les installer, ça évitera de couiner.
Quand aux kamikazes, c'était juste une tentative d'humour, pas une critique.
Si le mot ne plait pas, disons "les pressés avides de comprendre et d'essayer" : ce sont eux qui ont alerté, et évité ainsi pas mal d'ennuis aux autres lecteurs du forum.
Ce sont aussi souvent ceux qui trouvent des solutions et les font partager.
Patrice Broussea...
posté 2 Oct 2020, 23:50
Message #160
Membre no 193 846
Citation (Yves PRA @ 2 Oct 2020, 17:58) *
Merci du retour.
Je fais quand même un clone de mon installation actuelle (2020-004 et Safari 13.1.2) et testerai la mise à jour 005 (l'actuelle, mais j'imagine que c'est la même que l'ancienne?). Sur mon Clone Test évidemment...
baron
posté 3 Oct 2020, 01:48
Message #161
Membre no 21 291
Citation (Yves PRA @ 2 Oct 2020, 23:58) *
Ne te laisse pas emberlificoter par les errements embrouillés de maclinuxG4. rolleyes.gif
Aujourd'hui, il semble bien (notamment selon les infos collectées par Mr. Macintosh) que les versions proposées actuellement par l'outil de mise à jour de Mojave 10.14.6 2020-05 et 2020-06 (qui répare les dégâts causés par la précédente version de 2020-05, depuis retirée et remplacée) soient sûres et efficaces.
https://mrmacintosh.com/10-14-6-supplementa...revious-issues/
Une sauvegarde avant mise à jour reste cependant toujours une bonne pratique — que ce soit par clone ou par snapshot.
Pixel44
posté 3 Oct 2020, 04:48
Message #162
Inscrit : 17 Jul 2004
Lieu : Nantes
Membre no 21 109
Cette mise à jour a bien corrigé les problèmes sous Mojave
Mac Arthur
posté 3 Oct 2020, 05:55
Message #163
Inscrit : 9 Feb 2002
Lieu : Cambodge
Membre no 2 013
@Baron et Pixel44
MacBook Pro 14" 2021 MacBook M3 15" 2024 - Synology DS1522+ - Raspberry PI 4 Tahoe 26.5 (25F71)
maclinuxG4
posté 3 Oct 2020, 06:23
Message #164
Membre no 1 715
si il reste des message comme j'indique, c'est qu'il manque quelques modifications.
les résumés des modifications ne sont pas toujours complets, les petites modifications y sont parfois intégrer.
Après passer ONYX, un grand nombre devrait plus apparaitre, mais il en reste encore quelques un ...
S'ils en reste, cela va ralentir votre mac os , et les services associé, y comprit icloud
(ventillo à fond lorsque je vais sur le icloud....)
ouverture de chaque dossier dans preference sans rien modifier
preference
com.apple.preferences.internetaccounts.remoteservice[765]: objc[765]: Class ITNSImage is implemented in both /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/iTunesLibrary (0x7fffa6afe2a0) and /System/Library/CoreServices/SetupAssistantPlugins/iTunes.icdplugin/Contents/MacOS/iTunes (0x10a5a1398). One of the two will be used. Which one is undefined.
com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
appstoreagent[793]: objc[793]: Class ASDPurchaseResult is implemented in both /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Versions/A/AppStoreDaemon (0x7fffa6ed3be8) and /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent (0x1015bfd40). One of the two will be used. Which one is undefined.
System Preferences[583]: objc[583]: Class ConfigKeyEditor is implemented in both /System/Library/PrivateFrameworks/SpeechObjects.framework/Versions/A/Frameworks/DictationServices.framework/Versions/A/DictationServices (0x7fffab0546c8) and /System/Library/PreferencePanes/Keyboard.prefPane/Contents/MacOS/Keyboard (0x110da96b0). One of the two will be used. Which one is undefined.
System Preferences[583]: objc[583]: Class BTDeviceManager is implemented in both /System/Library/PreferencePanes/Mouse.prefPane/Contents/MacOS/Mouse (0x110acf9d8) and /System/Library/PreferencePanes/Keyboard.prefPane/Contents/MacOS/Keyboard (0x110da97f0). One of the two will be used. Which one is undefined.
System Preferences[583]: objc[583]: Class TabController is implemented in both /System/Library/PreferencePanes/Keyboard.prefPane/Contents/MacOS/Keyboard (0x110da9610) and /System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane/Contents/MacOS/DesktopScreenEffectsPref (0x1129b9040). One of the two will be used. Which one is undefined.
ContainerMetadataExtractor[
ContainerMetadataExtractor[434]: objc[434]: Class BRMangledID is implemented in both /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs (0x7fffa75ea188) and /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadataExtractor.xpc/Contents/MacOS/ContainerMetadataExtractor (0x10fa12480). One of the two will be used. Which one is undefined.
familycircled[435]: objc[435]: Class FAFamilyCloudKitProperties is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle (0x7fffa848aea8) and /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled (0x104abaa50). One of the two will be used. Which one is undefined.
familycircled[435]: objc[435]: Class FAFamilyMember is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle (0x7fffa848acc8) and /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled (0x104abab40). One of the two will be used. Which one is undefined.
familycircled[435]: objc[435]: Class FAFamilyCircle is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle (0x7fffa848ae58) and /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled (0x104abac80). One of the two will be used. Which one is undefined.
secd
secd[305]: objc[305]: Class SEParameters is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa651fe80) and /usr/libexec/secd (0x10b8d21e8). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class CTKClient_SEKey is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa651fed0) and /usr/libexec/secd (0x10b8d2238). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class CTKClient_TKDataSource is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa651ff20) and /usr/libexec/secd (0x10b8d2288). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class CTKClient_TKTLVRecord is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa651ff70) and /usr/libexec/secd (0x10b8d22d8). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class CTKClient_TKBERTLVRecord is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa651ffc0) and /usr/libexec/secd (0x10b8d2328). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class CTKClient_TKSimpleTLVRecord is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520010) and /usr/libexec/secd (0x10b8d2378). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class CTKClient_TKCompactTLVRecord is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520060) and /usr/libexec/secd (0x10b8d23c8). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class TKTokenRefImpl is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa65200d8) and /usr/libexec/secd (0x10b8d2440). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class TKTokenRefCtkd is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520100) and /usr/libexec/secd (0x10b8d2468). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class TKTokenRefSEP is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520150) and /usr/libexec/secd (0x10b8d24b8). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class SOSCachedNotification is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa65209e8) and /usr/libexec/secd (0x10b8d2710). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class SecSOSStatus is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa65208d0) and /usr/libexec/secd (0x10b8d2b98). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class SecKeyProxyTarget is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520920) and /usr/libexec/secd (0x10b8d2be8). One of the two will be used. Which one is undefined.
secd[305]: objc[305]: Class SecKeyProxy is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520970) and /usr/libexec/secd (0x10b8d2c38). One of the two will be used. Which one is undefined.
CommCenter
CommCenter[298]: objc[298]: Class CTAsciiAddress is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffa506d8b8) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10abf36d8). One of the two will be used. Which one is undefined.
CommCenter[298]: objc[298]: Class CTPhoneNumber is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffa506da48) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10abf3908). One of the two will be used. Which one is undefined.
CommCenter[298]: objc[298]: Class CTSimLabel is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffa506d9f8) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10abf4948). One of the two will be used. Which one is undefined.
ctkahp[273]
ctkahp[273]: objc[273]: Class TKTokenRefImpl is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa65200d8) and /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp (0x10483a738). One of the two will be used. Which one is undefined.
tkahp[273]: objc[273]: Class TKTokenRefCtkd is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520100) and /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp (0x10483a760). One of the two will be used. Which one is undefined.
ctkahp[276]: objc[276]: Class TKTokenRefImpl is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa65200d8) and /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp (0x104d22738). One of the two will be used. Which one is undefined.
ctkahp[276]: objc[276]: Class TKTokenRefCtkd is implemented in both /System/Library/Frameworks/Security.framework/Versions/A/Security (0x7fffa6520100) and /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp (0x104d22760). One of the two will be used. Which one is undefined.
mds
mds[75]: objc[75]: Class MDSObjectToken is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffab0dbde0) and /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds (0x10494c080). One of the two will be used. Which one is undefined.
mds[75]: objc[75]: Class MDSToken is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffab0dbd90) and /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds (0x10494c5d0). One of the two will be used. Which one is undefined.
mds[75]: objc[75]: Class MDSReadCopyUpdate is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffab0dbe30) and /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds (0x10494d160). One of the two will be used. Which one is undefined.
mds[75]: objc[75]: Class MDSInternalToken is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffab0dbd40) and /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds (0x10494e240). One of the two will be used. Which one is undefined.
maclinuxG4
posté 3 Oct 2020, 06:49
Message #165
Membre no 1 715
En clair, passer un coup d'ONYX, il en diminura un nombre, il en reste malheuresement, j'espère à la prochaine mise à jour 2020-006, la mise à jour et safari seront correctement pris en compte,
et corrigerons les delta pour tous.
Mac Arthur
posté 3 Oct 2020, 06:55
Message #166
Lieu : Cambodge
Membre no 2 013
Citation (maclinuxG4 @ 3 Oct 2020, 12:23) *
c'est là qu'il faut creuser...
maclinuxG4
posté 3 Oct 2020, 06:58
Message #167
Membre no 1 715
Si tu prend chaque mise à jour, l un ou l' autre mais pas les deux, tu n'as pas de pb.
Simplement, comme ces deux mise à jours, il ya des impacts commun, et c'est ceux la qui pose soucis, ainsi qu'une mise à jour local de ton mac os (base, etc...)
Lorsque l'update as été proposé (mise en ligne), il semble qu'aucune analyse des modifications , même globale, n'ont été réalisées, pas même de test sur une machine pour
se rendre compte si safari 14 + 2020-005 ET 2020-005 +safari 14 donne un mac os stable et identique.
L'ensemble des problèmes, les log et la lenteurs, les problème mémoires se voient très très vite.
je pense que safari 14 as été publié trop tôt, et j ignore les raisons. C'est tout.
Ce message a été modifié par maclinuxG4 - 7 Oct 2020, 10:13.
allmitel
posté 3 Oct 2020, 07:40
Message #168
Membre no 212 489
@Yves : Bref, c'est comme lutter contre les moulins à vents, j'abandonne. Raconter à tous que tu as dû telecharger 3 fois en Août ("par des moyens compliqués et avec de l'aide") un installeur remis en ligne en fin octobre dernier, n'aide vraiment pas au problème.
Prétendre que la solution pour débloquer les dits installeurs est complexe alors que la manip est connue de tout internet et se règle au moment de l'installation...
C'est clair, c'est net c'est "je coupe internet et je fais la commande "date -u 0808080818" dans le Terminal".
Son problème au gars était de ne pas avoir une base propre de partition et de s'être embrouillé avec ses doigts pour les commandes de date machin. L'embarquer dans "l'installeur est méchant" et raconter sa vie ne sert à rien. Vraiment.
Et pourtant il y avait un vrai risque que sa machine soit black-listée pour Mojave. Et ça c'est un truc inscrit dans le firmware définitivement et sans appel (numéro de séries). C'est testé dans l'installeur et c'est plus ardu à contourner (si jamais on le peut).
Ce message a été modifié par allmitel - 3 Oct 2020, 07:42.
Gritche
posté 3 Oct 2020, 09:58
Message #169
Inscrit : 6 Jul 2003
Lieu : Suisse
Membre no 8 457
Bonjour, J'ai rencontré le même problème (système figé) que j'ai constaté en ouvrant l'économiseur d'écran dans les préférences système. J'ai ensuite rechargé Mojave pour vérifier si le problème était bien lié à la dernière mise à jour, le problème n'existe plus, mais réapparait une fois la mise à jour effectuée. Je dois avouer être très fortement déçu des performances d'Apple...
PS. Onyx ne corrige pas le défaut...
Ce message a été modifié par Gritche - 3 Oct 2020, 10:00.
Croque la pomme depuis 1985 !
Mac 128K, Mac SE, Mac SE30, Power Mac G3, Mac Pro, Mac Studio M2 Max, SSD 500 Go, RAM 64 Go— Sequoia 15.7.7 — HD externes : LaCie 5big - 14 To, LMP Dataflex 200 8 To, Thunderbolt. Écran EIZO ColorEdge CS2420 + Calibrite Colorchecker Display Pro. iPhone 17.
http://www.pbase.com/cendres
maclinuxG4
posté 3 Oct 2020, 10:23
Message #170
Membre no 1 715
Citation (Gritche @ 3 Oct 2020, 10:58) *
pour l'éconiseur d'écran, il est nécessaire qu'apple fasse une mise à jour.
ONYX, je l'ai utilisé après la mise à jour, pour vider les caches et nettoyer les log. Cela ne règle pas les modifications résiduelles qu'apple doit encore corriger (screensaver).
La liste as été donné sur
Ce message a été modifié par maclinuxG4 - 3 Oct 2020, 10:24.
Yves PRA
posté 3 Oct 2020, 11:38
Message #171
Membre no 3 458
Alimintel a entièrement raison :
prétendre qu'un installeur fourni par la société Apple doive fonctionner en double-cliquant dessus est complètement stupide.
Mea Culpa.
J'aurai du comprendre bien plus vite qu'il fallait arrêter sa machine, redémarrer dans un autre mode, lancer une commande qui tombe sous le sens commun dans le terminal (que tout utilisateur Mac connait par coeur, c'est aussi une évidence).
Comment ai-je pu être aussi bête.
Encore pardon pour ma stupide naïveté : avoir suivi les conseils avisé affichés par l'installeur (c'est corrompu, retéléchargez-le).
Et il a raison aussi sur le troisième point :
"C'est comme lutter contre les moulins à vents, j'abandonne".
Je vais suivre ce conseil en priorité.
Bon week end à tous ceux qui cherchent une solution aux problèmes résiduels des mises à jour récentes.
TERRY
posté 3 Oct 2020, 12:09
Message #172
Inscrit : 8 Jan 2003
Lieu : Ici...
Membre no 5 523
Citation (Yves PRA @ 3 Oct 2020, 12:38) *
Mea Culpa.
allmitel
posté 3 Oct 2020, 12:11
Message #173
Membre no 212 489
Personne n'a dit qu'il n'y avait pas un problème avec les anciens installeurs (ceux d'avant la mi-octobre 2019 qui donnaient un message contre-intuitif d'installeur "cassé"). Personne n'a dit que la solution était "évidente" et "accessible" à Mme Michu.
Mme Michu elle va re-télécharger le fichier par le canal officiel. C'est long, c'est débile, ça bouffe de la bande passante, mais ça va "marcher".
Le problème a été réglé à la mi-octobre 2019. Et les installeurs et autres fichiers Apple téléchargés depuis par les canaux officiels sont "réparés" depuis. Donc il est hautement improbable que tu aies re-téléchargé ce qu'il fallait par le canal officiel.
La solution de contournement qui donc ne sert qu'aux personnes averties et bidouilleurs de tout poil (l'histoire de la date) est connue depuis la mi-octobre 2019. Pire, c'est connu depuis 2015 où le problème avait déjà été posé. Pas la peine d'en faire un foin donc si tu as "choisi" d'être du camp des bidouilleurs. Et à ce titre ça suppose être responsable dans tes actes : si tu télécharges avec des outils qui ne sont pas les canaux officiels, tu en prends la responsabilité.
Idem pour cette histoire de mise à jour cassée SecurityUpdate-005 + Safari14 : bidouiller sans attendre la réaction d'Apple (moins d'une semaine pour le retrait + le correctif, alors qu'il y a un autre souci sur Cataline + bientôt BigSur), c'est prendre la responsabilité de ses actes sans faire un foin incroyable.
Attendre le correctif d'Apple : c'est long, c'est débile, ça bouffe de la bande passante mais dans 95% des cas ça "marche". Et je suis quasi certain que c'est très difficile d'être dans les 5% restant sauf à bricoler comme un bourrin ou le faire exprès (ou l'exemple - "j'ai un scanner pro dont la boîte a fermé en 2002" - "j'ai un logiciel que je traîne depuis Leopard sans mise à jour parce que la boite a fermé").
Va faire un tour sur "Le Journal du Lapin" : là c'est de la bidouille "dure". Dans ce cas précis, on se créée nos propres problèmes…
Mac Arthur
posté 3 Oct 2020, 12:15
Message #174
Lieu : Cambodge
Membre no 2 013
(Meuhh nan, je rigole :-)
Yves PRA
posté 3 Oct 2020, 14:21
Message #175
Membre no 3 458
Je viens de télécharger l'installeur de Mojave par la méthode expliquée par MacArthur (GBuildmacOSInstallApp, et choix 11 dans la liste des terminal).
Je me trouve avec un dossier "061-26578 - 10.14.5 macOS Mojave" contenant 11 fichiers, et je ne sais pas quoi faire pour transformer l'ensemble en un "installeur" complet de la version 10.4.5 de Mojave.
Ces fichiers proviennent des serveurs Apple comme le montre le terminal.
J'ai lu les notes explicatives de MacArthur, mais pas tout compris !
L'un des paquets "InstallESDDmg" ou "OSInstall" ou encore "InstallAssistantAuto" est-il le bon moyen ?
Je ne tente rien pour le moment, sur un clone en USB les essais ne sont pas rapides, surtout si après il faut reformater et refaire un clone.
Je souhaite faire ce type de réinstallation "par dessus une version 10.4.6" pour récupérer une version saine de Safari (13.qq chose), m'étant rendu compte que sur 2 autres machines la mise à jour safari 14 était déjà faite :
tous mes Macs et Hacks ont cette version Safari 14 (et mes clones aussi ! ils datent d'après safari 14, et d'avant la "security 005 premiere version)
Ce message a été modifié par Yves PRA - 3 Oct 2020, 14:22.
Mac Arthur
posté 3 Oct 2020, 14:26
Message #176
Lieu : Cambodge
Membre no 2 013
On avance !
Ca se passe au #54
https://forum.macbidouille.com/index.php?s=...t&p=4340483
Mac
Patrice Broussea...
posté 3 Oct 2020, 16:16
Message #177
Membre no 193 846
Citation (Yves PRA @ 3 Oct 2020, 06:38) *
Mea Culpa.
Yves, je te soutiens. Cette « évidence » pour certains n’est pas nécessairement évidente pour tous...
Yves PRA
posté 3 Oct 2020, 16:39
Message #178
Membre no 3 458
Merci MacArthur !
"J'avais raté une étape" moi aussi
On est au moins deux.. Et pourtant l'explication est claire et illustrée.
Je vais passer mes lunettes en version 2.0 !
Et surtout copier ces instructions et ces liens pour les garder au chaud, j'ai dans l'idée qu'ils vont servir plus d'une fois.
Merci aussi P. Brousseau : les manips comme celles de Github et les explications détaillées de MacArthur montrent bien la puissance du terminal et de ses commandes, mais c'est quand même réservé aux Pros.
Sans bonnes connaissances, on doit pouvoir faire de tres grosses bêtises en 2 ou 3 clics.
Ce message a été modifié par Yves PRA - 3 Oct 2020, 16:55.
allmitel
posté 3 Oct 2020, 16:54
Message #179
Membre no 212 489
Hé! Que les choses soient claires, je ne prends pas plus le camp de l'un que de l'autre.
Mais réfléchissez un peu : l'informatique personnelle, ça fait 40-50 ans que ça existe. Les "problèmes" informatiques ça donc aussi 40-50 ans que ça existe. Aussi. Rien de neuf sous le soleil.
Ici à entendre certains on soit se focaliser sur les "problèmes". Gnagnagna "problème-ci" "problème-ça". Plutôt que de se focaliser sur les bonnes solutions et bonnes méthodes.
Les questions de l'installeurs MacOS Mojave 10.14.6 : réglé depuis la mi-octobre 2019. À la rigueur on peut "croire" que ça a pu se reproduire entretemps mais j'en doute fort. Je ne comprends vraiment pas quels problèmes Yves se créée en se bricolant des installeurs foireux de 10.14.6 depuis lors.
Les mises à jour ratées d'Apple de la mi-fin septembre : on a compris c'est affreux affreux ils ont sorti des mises à jour qui ont créé des problèmes. Mais ils ont, foutre Dieu, corrigé le tir en moins d'une semaine. Je ne sais vraiment pas ce qu'il vous faut d'autres! Vous remuez le baton merdeux jusqu'à en avoir sur les doigts.
Pire, vous n'aidez pas forcément les gens qui "ne passent que brièvement par là". C'est tout l'objet de mon interrogation et demi énervement.
Yves : arrête de t'emberlificoter avec la 10.14.5! La 10.14.6 est encore livrée avec Safari 12.2.3 12.1.2. Mon installeur de Mojave date du 22 septembre 2020 et c'est encore le cas. Çe ne va pas se transformer comme par magie chez toi!
L'outil de téléchargement dont MacArthur à parlé (et dont je n'ai pas plus compris le fonctionnement pour transformer les pkg en truc utilisable jusque là), l'indique bien : le "dernier" Mojave qu'on peut télécharger date du 14 octobre 2019 à 20h51. Juste au moment où ils se sont rendu compte pour les certificats donc. C'est la même chose que l'on télécharge sur le MacAppStore et la même chose que l'outil de récupération télécharge. La même chose que la ligne de commande
[ softwareupdate --fetch-full-installer 10.14.6 ] télécharge. Voilà l'image si tu veux :
Fichier joint  Capture_d_____cran_2020_10_03____17.41.20.png ( 61.15 Ko ) Nombre de téléchargements : 7
Et si c'est pour récupérer une version "saine" de Safari (admettons). Je suis à peu près certains que tu ne vas pas y arriver de cette façon :
- si la 10.14.6 est livrée avec un Safari 12.quelque chose; il y a de grande chance que ce soit de même pour la version 10.14.5… En tout cas ça ne sera pas le Safari 13.quelque chose que tu espères.
Et le Software Update par défaut ne te fera probablement pas de cadeau et ne te proposera de mise à jour que vers Safari14. Pour Apple, c'est "clair et net", le problème est réglé pour l'update de Safari. Sauf grosse surprise ils ne reviendront pas en arrière.
Il y a un outil pour faire les récups du Software Update autre que les "gros installeurs". Un peu comme le GibHubMac dont a parlé MacArthur. Je l'ai vu à bricoler mon install à fond ces derniers jours. Il s'agit de voir si c'est encore disponible dans leur catalogue.
Ce message a été modifié par allmitel - 3 Oct 2020, 17:46.
Yves PRA
posté 3 Oct 2020, 17:08
Message #180
Membre no 3 458
Le dernier installeur Mojave (estampillé 14.6.06, téléchargé sur l'app store) contient Safari 12.2.3 ?
On est passé directement de 12.2.3 à 14 ? Bon d'accord, 13 ça porte malheur, mais ça m'étonne un peu.
Il me semble bien avoir eu une version 13.qqchose (mais je n'ai plus les moyens de verifier).
12.x.x, c'était pas sous Sierra ?
"ll y a un outil pour faire les récups du Software Update autre que les "gros installeurs"
Ca m'intéresse bien !
Safari pèse 43,3 Mo, devoir télécharger 6,5 Go (et parfois plusieurs fois) pour le récupérer c'est lourd et long.
Ce message a été modifié par Yves PRA - 3 Oct 2020, 17:24.
Nous sommes le : 25th May 2026 - 07:40
