Jeanjd63 un dernier pour la route?, Terminer 2020 sur un bon cru — Topic pour du beurre… |
31 Dec 2020, 17:00
Macbidouilleur d'Or ! Groupe : Membres Messages : 5 391 Inscrit : 9 Feb 2002 Lieu : Cambodge Membre no 2 013 |
Bon réveillon
Code Last login: Thu Dec 31 22:50:04 on ttys000 domhack@iMac ~ % diskutil list /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *1.0 TB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_APFS Container disk4 1000.0 GB disk0s2 /dev/disk1 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *500.1 GB disk1 1: EFI EFI 209.7 MB disk1s1 2: Apple_APFS Container disk3 499.9 GB disk1s2 /dev/disk2 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *4.0 TB disk2 1: EFI EFI 209.7 MB disk2s1 2: Apple_APFS Container disk9 4.0 TB disk2s2 /dev/disk3 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +499.9 GB disk3 Physical Store disk1s2 1: APFS Volume Musique PYC 219.0 GB disk3s1 2: APFS Volume Preboot 24.6 KB disk3s2 3: APFS Volume Recovery 20.5 KB disk3s3 4: APFS Volume VM 1.1 MB disk3s4 5: APFS Volume SABnzbd 3.2 GB disk3s7 /dev/disk4 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +1000.0 GB disk4 Physical Store disk0s2 1: APFS Volume SSD 1T0 - Data 698.3 GB disk4s1 2: APFS Volume Big Sur 15.1 GB disk4s2 3: APFS Snapshot com.apple.os.update-... 15.1 GB disk4s2s1 4: APFS Volume Preboot 519.8 MB disk4s3 5: APFS Volume Recovery 615.0 MB disk4s4 6: APFS Volume VM 2.1 GB disk4s5 /dev/disk5 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *6.0 TB disk5 1: EFI EFI 209.7 MB disk5s1 2: Apple_APFS Container disk8 6.0 TB disk5s2 /dev/disk6 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *4.0 TB disk6 1: EFI EFI 209.7 MB disk6s1 2: Microsoft Reserved 16.8 MB disk6s2 3: Microsoft Basic Data Windows64 149.5 GB disk6s3 4: Windows Recovery 540.0 MB disk6s4 5: Apple_APFS Container disk11 3.9 TB disk6s5 /dev/disk7 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *8.0 TB disk7 1: EFI EFI 209.7 MB disk7s1 2: Apple_APFS Container disk10 8.0 TB disk7s2 /dev/disk8 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +6.0 TB disk8 Physical Store disk5s2 1: APFS Volume SATA1 6To 2.4 TB disk8s1 2: APFS Volume Virtual Machines 455.1 GB disk8s2 3: APFS Volume One Drive 787.5 GB disk8s3 4: APFS Volume CCC Catalina - Data 656.5 GB disk8s4 5: APFS Volume CCC Catalina 11.3 GB disk8s5 6: APFS Volume Preboot 81.9 MB disk8s6 7: APFS Volume Recovery 534.7 MB disk8s7 8: APFS Volume VM 4.3 GB disk8s8 /dev/disk9 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +4.0 TB disk9 Physical Store disk2s2 1: APFS Volume SATA4 4To 67.8 GB disk9s1 2: APFS Volume CCC Big Sur 15.0 GB disk9s2 3: APFS Volume CCC Big Sur - Data 689.2 GB disk9s3 4: APFS Volume Preboot 475.3 MB disk9s4 5: APFS Volume Recovery 613.6 MB disk9s5 6: APFS Volume VM 1.1 MB disk9s7 7: APFS Volume Anciennes versions A... 386.3 GB disk9s8 /dev/disk10 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +8.0 TB disk10 Physical Store disk7s2 1: APFS Volume SATA3 8To 7.1 TB disk10s1 /dev/disk11 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +3.9 TB disk11 Physical Store disk6s5 1: APFS Volume SATA2 4To 810.1 GB disk11s1 2: APFS Volume Time Machine Big Sur 1.1 TB disk11s3 3: APFS Volume Preboot 20.5 KB disk11s4 4: APFS Volume Recovery 20.5 KB disk11s5 5: APFS Volume VM 34.4 GB disk11s6 6: APFS Volume Photos Lightroom 1.7 TB disk11s8 /dev/disk12 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *4.0 TB disk12 1: EFI EFI 314.6 MB disk12s1 2: Apple_APFS Container disk13 4.0 TB disk12s2 /dev/disk13 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +4.0 TB disk13 Physical Store disk12s2 1: APFS Volume DDE 4To Dom 1.0 MB disk13s1 2: APFS Volume Preboot 24.6 KB disk13s4 3: APFS Volume Recovery 20.5 KB disk13s5 4: APFS Volume VM 1.1 MB disk13s6 /dev/disk14 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *245.9 GB disk14 1: EFI EFI 209.7 MB disk14s1 2: Apple_HFS Lexar F35 Outils 183.5 GB disk14s2 3: Apple_HFS Install Sierra 7.9 GB disk14s3 4: Apple_HFS Install OSX El Capitan 9.9 GB disk14s4 5: Apple_HFS Install macOS Big Su... 13.9 GB disk14s5 6: Apple_HFS Install macOS High S... 9.9 GB disk14s6 7: Apple_HFS Install macOS Mojave 9.9 GB disk14s7 8: Apple_HFS Install macOS Catalina 9.9 GB disk14s8 /dev/disk15 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: CD_partition_scheme *2.7 GB disk15 1: CD_ROM_Mode_1 Lexar 2.4 GB disk15s0 domhack@iMac ~ % Code EtreCheckPro version: 6.3.6 (6D029) Report generated: 2020-12-31 22:59:33 Download EtreCheckPro from https://etrecheck.com Runtime: 4:52 Performance: Good Problem: No problem - just checking Major Issues: Anything that appears on this list needs immediate attention. Unsigned files - There are unsigned software files installed that could be adware and should be reviewed. System Integrity Protection disabled - System Integrity Protection is disabled. This computer is at risk of malware infection. Security updates disabled - Security updates are disabled. This computer is at risk of malware infection. Heavy CPU usage - Some processes are using an unusually high amount of CPU. Apple security disabled - Apple security software is disabled. This computer is at risk of malware infection. Adobe Flash Player installed - Adobe Flash Player is installed on this computer. This is a security risk and no longer supported. Minor Issues: These issues do not need immediate attention but they may indicate future problems or opportunities for improvement. Heavy RAM usage - Apps are using a large amount of RAM. Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage. Clean up - There are orphan files that could be removed. Unsigned files - There are unsigned software files installed. Apple has said that unsigned software will not run by default in a future version of the operating system. System modifications - There are a large number of system modifications running in the background. Runaway user process - A user process is using a large percentage of your CPU. 32-bit Apps - This computer has 32-bits apps will not work on current versions of the operating system. Kernel boot arguments - This computer has custom kernel boot arguments. Kernel extensions present - This computer has kernel extensions that may not work in the future. Sharing enabled - This computer has sharing services enabled that could be a security risk. Hardware Information: iMac (Retina 5K, 27-inch, 2019) iMac Model: iMac19,1 3,8 GHz 8-Core Intel Core i7 (i7-10700K) CPU: 8-core 64 GB RAM - At maximum BANK 0/ChannelA-DIMM0 - 16 GB DDR4 2133 BANK 1/ChannelA-DIMM1 - 16 GB DDR4 2133 BANK 2/ChannelB-DIMM0 - 16 GB DDR4 2133 BANK 3/ChannelB-DIMM1 - 16 GB DDR4 2133 Video Information: Radeon RX 5700 XT - VRAM: 8 GB C49RG9x 5120 x 1440 DELL P2419H 2560 x 1440 Drives: disk0 - Samsung SSD 970 EVO Plus 1TB 1.00 TB (Solid State - TRIM: Yes) Internal PCI-Express 8.0 GT/s x4 NVM Express disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk0s2 [APFS Container] 1000.00 GB disk4 [APFS Virtual drive] 1000.00 GB (Shared by 6 volumes) disk4s1 - S******* - Data (APFS) [APFS Virtual drive] (Shared - 698.38 GB used) disk4s2 (APFS) [APFS Container] (Shared - 15.05 GB used) disk4s2s1 - B*****r (APFS) [APFS Snapshot] (Shared - 15.05 GB used) disk4s3 - Preboot (APFS) [APFS Preboot] (Shared - 520 MB used) disk4s4 - Recovery (APFS) [Recovery] (Shared - 615 MB used) disk4s5 - VM (APFS) [APFS VM] (Shared - 2.15 GB used) disk4s6 - Update (APFS) (Shared - 4 MB used) disk1 - Samsung SSD 970 EVO 500GB 500.11 GB (Solid State - TRIM: Yes) Internal PCI-Express 8.0 GT/s x4 NVM Express disk1s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk1s2 [APFS Container] 499.90 GB disk3 [APFS Virtual drive] 499.90 GB (Shared by 6 volumes) disk3s1 - M*********C (APFS) (Shared - 218.98 GB used) disk3s2 - Preboot (APFS) [APFS Preboot] (Shared - 25 KB used) disk3s3 - Recovery (APFS) [Recovery] (Shared - 20 KB used) disk3s4 - VM (APFS) [APFS VM] (Shared - 1 MB used) disk3s6 - Update (APFS) (Shared - 1 MB used) disk3s7 - S*****d (APFS) (Shared - 3.17 GB used) disk2 - WDC WD40EFRX-68N32N0 4.00 TB (Mechanical - 5400 RPM) Internal SATA 6 Gigabit Serial ATA disk2s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk2s2 [APFS Container] 4.00 TB disk9 [APFS Virtual drive] 4.00 TB (Shared by 8 volumes) disk9s1 - S*******o (APFS) (Shared - 67.83 GB used) disk9s2 - C*********r (APFS) (Shared - 15.05 GB used) disk9s3 - C*********** - Data (APFS) (Shared - 689.25 GB used) disk9s4 - Preboot (APFS) [APFS Preboot] (Shared - 475 MB used) disk9s5 - Recovery (APFS) [Recovery] (Shared - 614 MB used) disk9s6 - Update (APFS) (Shared - 78 KB used) disk9s7 - VM (APFS) [APFS VM] (Shared - 1 MB used) disk9s8 - A**************************X (APFS) (Shared - 386.26 GB used) disk5 - WDC WD60EFRX-68L0BN1 6.00 TB (Mechanical - 5700 RPM) Internal SATA 6 Gigabit Serial ATA disk5s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk5s2 [APFS Container] 6.00 TB disk8 [APFS Virtual drive] 6.00 TB (Shared by 9 volumes) disk8s1 - S*******o (APFS) (Shared - 2.43 TB used) disk8s2 - V**************s (APFS) (Shared - 455.09 GB used) disk8s3 - O*******e (APFS) (Shared - 787.49 GB used) disk8s4 - C************ - Data (APFS) (Shared - 656.55 GB used) disk8s5 - C**********a (APFS) (Shared - 11.34 GB used) disk8s6 - Preboot (APFS) [APFS Preboot] (Shared - 82 MB used) disk8s7 - Recovery (APFS) [Recovery] (Shared - 535 MB used) disk8s8 - VM (APFS) [APFS VM] (Shared - 4.29 GB used) disk8s9 - Update (APFS) (Shared - 303 KB used) disk6 - WDC WD40EFRX-68WT0N0 4.00 TB (Mechanical - 5400 RPM) Internal SATA 6 Gigabit Serial ATA disk6s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk6s2 17 MB disk6s3 - W*******4 (MS-DOS FAT12) 149.46 GB (94.01 GB used) disk6s4 540 MB disk6s5 [APFS Container] 3.85 TB disk11 [APFS Virtual drive] 3.85 TB (Shared by 7 volumes) disk11s1 - S*******o (APFS) (Shared - 810.10 GB used) disk11s3 - T******************r (APFS) (Shared - 1.10 TB used) disk11s4 - Preboot (APFS) [APFS Preboot] (Shared - 20 KB used) disk11s5 - Recovery (APFS) [Recovery] (Shared - 20 KB used) disk11s6 - VM (APFS) [APFS VM] (Shared - 34.36 GB used) disk11s7 - Update (APFS) (Shared - 528 KB used) disk11s8 - P**************m (APFS) (Shared - 1.68 TB used) disk7 - WDC WD80EFAX-68KNBN0 8.00 TB (Mechanical - 5400 RPM) Internal SATA 6 Gigabit Serial ATA disk7s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk7s2 [APFS Container] 8.00 TB disk10 [APFS Virtual drive] 8.00 TB (Shared by 2 volumes) disk10s1 - S*******o (APFS) (Shared - 7.10 TB used) disk10s2 - Update (APFS) (Shared - 49 KB used) disk12 - StoreJet Transcend 4.00 TB External USB 5 Gbit/s USB disk12s1 - EFI [EFI] 315 MB disk12s2 [APFS Container] 4.00 TB disk13 [APFS Virtual drive] 4.00 TB (Shared by 5 volumes) disk13s1 - D*********m (APFS) (Shared - 1 MB used) disk13s4 - Preboot (APFS) [APFS Preboot] (Shared - 25 KB used) disk13s5 - Recovery (APFS) [Recovery] (Shared - 20 KB used) disk13s6 - VM (APFS) [APFS VM] (Shared - 1 MB used) disk13s7 - Update (APFS) (Shared - 37 KB used) disk14 - Lexar F35 245.89 GB External USB 5 Gbit/s USB disk14s1 - EFI (MS-DOS FAT32) [EFI] 210 MB disk14s2 - L**************s (Journaled HFS+) 183.54 GB (65.95 GB used) disk14s3 - I************a (Mac OS Extended) 7.87 GB (6.27 GB used) disk14s4 - I********************n (Mac OS Extended) 9.87 GB (7.61 GB used) disk14s5 - I************************a (Journaled HFS+) 13.87 GB (12.96 GB used) disk14s6 - I***********************a (Journaled HFS+) 9.87 GB (5.30 GB used) disk14s7 - I******************e (Journaled HFS+) 9.87 GB (6.11 GB used) disk14s8 - I********************a (Journaled HFS+) 9.87 GB (8.32 GB used) Mounted Volumes: disk3s1 - M*********C 499.90 GB (Shared - 218.98 GB used, 277.59 GB available, 277.58 GB free) APFS Mount point: /Volumes/M*********C disk3s7 - S*****d 499.90 GB (Shared - 3.17 GB used, 277.58 GB free) APFS Mount point: /Volumes/S*****d disk4s1 - S******* - Data [APFS Virtual drive] 1000.00 GB (Shared - 698.38 GB used, 289.83 GB available, 283.07 GB free) APFS Mount point: /System/Volumes/Data disk4s2s1 - B*****r [APFS Snapshot] 1000.00 GB (Shared - 15.05 GB used, 289.83 GB available, 283.07 GB free) APFS Mount point: / Read-only: Yes disk4s3 - Preboot [APFS Preboot] 1000.00 GB (Shared - 520 MB used, 283.07 GB free) APFS Mount point: /System/Volumes/Preboot disk4s5 - VM [APFS VM] 1000.00 GB (Shared - 2.15 GB used, 283.07 GB free) APFS Mount point: /System/Volumes/VM disk4s6 - Update 1000.00 GB (Shared - 4 MB used, 283.07 GB free) APFS Mount point: /System/Volumes/Update disk6s3 - W*******4 149.46 GB (94.01 GB used, 55.45 GB free) MS-DOS FAT12 Mount point: /Volumes/W*******4 disk8s1 - S*******o 6.00 TB (Shared - 2.43 TB used, 1.66 TB free) APFS Mount point: /Volumes/S*******o disk8s2 - V**************s 6.00 TB (Shared - 455.09 GB used, 1.66 TB free) APFS Mount point: /Volumes/V**************s disk8s3 - O*******e 6.00 TB (Shared - 787.49 GB used, 1.66 TB free) APFS Mount point: /Volumes/O*******e disk8s4 - C************ - Data 6.00 TB (Shared - 656.55 GB used, 1.66 TB free) APFS Mount point: /Volumes/C************ - Data disk8s5 - C**********a 6.00 TB (Shared - 11.34 GB used, 1.66 TB free) APFS Mount point: /Volumes/C**********a Read-only: Yes disk9s1 - S*******o 4.00 TB (Shared - 67.83 GB used, 2.84 TB free) APFS Mount point: /Volumes/S*******o disk9s2 - C*********r 4.00 TB (Shared - 15.05 GB used, 2.84 TB free) APFS Mount point: /Volumes/C*********r Read-only: Yes disk9s3 - C*********** - Data 4.00 TB (Shared - 689.25 GB used, 2.84 TB free) APFS Mount point: /Volumes/C*********** - Data disk9s8 - A**************************X 4.00 TB (Shared - 386.26 GB used, 2.84 TB free) APFS Mount point: /Volumes/A**************************X disk10s1 - S*******o 8.00 TB (Shared - 7.10 TB used, 900.69 GB available, 900.49 GB free) APFS Mount point: /Volumes/S*******o disk11s1 - S*******o 3.85 TB (Shared - 810.10 GB used, 226.02 GB free) APFS Mount point: /Volumes/S*******o disk11s3 - T******************r 3.85 TB (Shared - 1.10 TB used, 226.02 GB free) APFS Mount point: /Volumes/T******************r disk11s8 - P**************m 3.85 TB (Shared - 1.68 TB used, 226.02 GB free) APFS Mount point: /Volumes/P**************m disk13s1 - D*********m 4.00 TB (Shared - 1 MB used, 4.00 TB free) APFS Mount point: /Volumes/D*********m Owners enabled: No disk14s2 - L**************s 183.54 GB (65.95 GB used, 117.59 GB free) Journaled HFS+ Mount point: /Volumes/L**************s Owners enabled: No disk14s3 - I************a 7.87 GB (6.27 GB used, 1.60 GB free) Mac OS Extended Mount point: /Volumes/I************a Owners enabled: No disk14s4 - I********************n 9.87 GB (7.61 GB used, 2.25 GB free) Mac OS Extended Mount point: /Volumes/I********************n Owners enabled: No disk14s5 - I************************a 13.87 GB (12.96 GB used, 907 MB free) Journaled HFS+ Mount point: /Volumes/I************************a Owners enabled: No disk14s6 - I***********************a 9.87 GB (5.30 GB used, 4.57 GB free) Journaled HFS+ Mount point: /Volumes/I***********************a Owners enabled: No disk14s7 - I******************e 9.87 GB (6.11 GB used, 3.75 GB free) Journaled HFS+ Mount point: /Volumes/I******************e Owners enabled: No disk14s8 - I********************a 9.87 GB (8.32 GB used, 1.54 GB free) Journaled HFS+ Mount point: /Volumes/I********************a Owners enabled: No Network: Interface en0: Ethernet Interface en1: Ethernet 2 Interface en2: VM network interface Interface en3: VM network interface 2 Printer sharing: Enabled Remote Management: Enabled Screen sharing: Enabled Web sharing: Enabled System Software: macOS Big Sur 11.2 (20D5029f) Time since boot: About a day Boot args: keepsyms=1 dart=0 debug=0x100 agdpmod=pikera alcid=11 shikigva=80 Configuration Files: /etc/hosts - Count: 1 Notifications: Viber.app 2 notifications EPSON Software Updater.app one notification CCC User Agent.app 7 notifications Gemini 2.app 2 notifications (one scheduled) DriveDx.app 37 notifications Telegram.app one notification Microsoft Outlook.app 53 notifications SABnzbd.app 6 notifications OneDrive.app 100 notifications WhatsApp.app 10 notifications Security: Gatekeeper: App Store and identified developers System Integrity Protection: unknown (Custom Configuration) Security Updates: Disabled Antivirus software: Malwarebytes Security Risk! - Adobe Flash Player installed! Printer sharing: Enabled Remote Management: Enabled Screen sharing: Enabled Web sharing: Enabled Unsigned Files: Launchd: /Library/LaunchAgents/com.googlecode.munki.managedsoftwareupdate-loginwindow.plist Executable: /usr/local/munki/supervisor --timeout 43200 -- /usr/local/munki/managedsoftwareupdate --logoutinstall Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/org.cindori.SenseiDaemon.plist Executable: /Library/Application Support/Sensei/SenseiDaemon Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.googlecode.munki.MunkiStatus.plist Executable: /Applications/Managed Software Center.app/Contents/Resources/MunkiStatus.app/Contents/MacOS/MunkiStatus Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.googlecode.munki.ManagedSoftwareCenter.plist Executable: /usr/local/munki/launchapp -a '/Applications/Managed Software Center.app' Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.googlecode.munki.app_usage_monitor.plist Executable: /usr/local/munki/app_usage_monitor Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.googlecode.munki.munki-notifier.plist Executable: /usr/local/munki/launchapp -a '/Applications/Managed Software Center.app/Contents/Resources/munki-notifier.app' Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.mingjie.mjrecorder.agent.plist Executable: /Library/Audio/Plug-Ins/HAL/MJRecorderDevice.driver/Contents/MacOS/MJRecorder-agent Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/org.cindori.SenseiMonitor.plist Executable: /Library/Application Support/Sensei/Sensei Monitor.app/Contents/MacOS/Sensei Monitor Launchd: /Library/LaunchDaemons/com.sleepwatcher.plist Executable: /usr/local/sbin/sleepwatcher -V '-s /etc/rc.sleep' '-w /etc/rc.wakeup' Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.googlecode.munki.authrestartd.plist Executable: /usr/local/munki/authrestartd Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.staticz.soundsiphon.inputagent.plist Executable: /Applications/Sound Siphon.app/Contents/XPCServices/Sound Siphon Microphone Input.app/Contents/MacOS/Sound Siphon Microphone Input Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.googlecode.munki.logouthelper.plist Executable: /usr/local/munki/logouthelper Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.audiojinglex.soundtree.agent.plist Executable: /Library/Audio/Plug-Ins/HAL/Audiojingle.driver/Contents/Resources/Audiojingleagent.xpc/Contents/MacOS/Audiojingleagent Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.projectosx.clover.daemon.plist Executable: /Library/Application Support/Clover/CloverDaemon startup Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.googlecode.munki.managedsoftwareupdate-install.plist Executable: /usr/local/munki/supervisor --timeout 43200 -- /usr/local/munki/managedsoftwareupdate --installwithnologout Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.googlecode.munki.managedsoftwareupdate-check.plist Executable: /usr/local/munki/supervisor --delayrandom 3600 --timeout 43200 -- /usr/local/munki/managedsoftwareupdate --auto Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.googlecode.munki.appusaged.plist Executable: /usr/local/munki/appusaged Launchd: /Library/LaunchDaemons/org.cindori.SenseiHelper.plist Executable: /Library/PrivilegedHelperTools/org.cindori.SenseiHelper Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/org.virtualbox.startup.plist Executable: /Library/Application Support/VirtualBox/LaunchDaemons/VirtualBoxStartup.sh restart Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.audiojinglex.soundtree.agent.plist Executable: /Library/Audio/Plug-Ins/HAL/Audiojingle.driver/Contents/Resources/Audiojingleagent.xpc/Contents/MacOS/Audiojingleagent Details: Exact match found in the legitimate list - probably OK Launchd: ~/Library/LaunchAgents/net.tunnelblick.tunnelblick.LaunchAtLogin.plist Executable: /Applications/Tunnelblick.app/Contents/Resources/launchAtLogin.sh Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchDaemons/com.twocanoes.mds.micromdm.plist Executable: /usr/local/mds-micromdm/bin/start_micromdm Launchd: /Library/LaunchDaemons/com.googlecode.munki.managedsoftwareupdate-manualcheck.plist Executable: /usr/local/munki/supervisor --timeout 43200 -- /usr/local/munki/managedsoftwareupdate --manualcheck Details: Exact match found in the legitimate list - probably OK Launchd: /Library/LaunchAgents/com.amazon.sendtokindle.launcher.plist Executable: /usr/local/bin/stkLaunchAgent.sh Details: Exact match found in the legitimate list - probably OK Running app: /Applications/***intosh tools/***intool.app/Contents/MacOS/Hackintool Running app: /Applications/Sync Folders Pro.app/Contents/MacOS/Sync Folders Pro Running app: /Applications/***intosh tools/HWMonitorSMC2.app/Contents/MacOS/HWMonitorSMC2 Running app: /Applications/OneDrive.app/Contents/MacOS/OneDrive Running app: /Applications/***intosh tools/HWMonitorSMC2.app/Contents/Library/LoginItems/HWMonitorSMC2 Helper.app Running app: /Applications/Utilities/Disk Drill.app/Contents/Helpers/SmartDaemon.app/Contents/MacOS/SmartDaemon Safari Extension: "Open In" button for Internet Explorer Login Item: /Applications/***intosh tools/HWMonitorSMC2.app/Contents/Library/LoginItems/HWMonitorSMC2 Helper.app Login Item: /Applications/Path Finder copie gros fichiers.app/Contents/Library/LoginItems/PathFinderLauncher.app Login Item: /Applications/OneDrive.app Login Item: /Applications/Start Liquidctl.app Login Item: /Applications/Utilities/Disk Drill.app/Contents/Helpers/SmartDaemon.app Login Item: /Applications/SyncMate.app/Contents/Library/LoginItems/SyncMateService.app Login Item: /Applications/Utilities/MacDroid.app/Contents/Library/LoginItems/DroiderLauncher.app Login Item: /Applications/Clover.app/Contents/Library/LoginItems/CloverRunAtLogin.app Login Item: /Applications/TinkerTool System.app/Contents/Library/LoginItems/LaunchTTS.app Plugin: /Library/Internet Plug-Ins/Flash Player.plugin/Flash Player.plugin/Contents/PlugIns/FlashPlayer-10.6.plugin Plugin: /Library/Internet Plug-Ins/Flash Player.plugin/Flash Player.plugin Plugin: /Library/Internet Plug-Ins/SharePointBrowserPlugin.plugin Plugin: /Library/Audio/Plug-Ins/HAL/MJRecorderDevice.driver Plugin: /Library/Audio/Plug-Ins/HAL/Audiojingle.driver Apps: 685 32-bit Applications: 53 32-bit apps System Extensions: [Running] Little Snitch Network Extension - version 5.0.4 (Objective Development Software GmbH - 2020-12-01) Application: /Applications/Little Snitch.app - version 5.0.4 (Objective Development Software GmbH - 2020-12-01) Description: This system extension enables Little Snitch to filter network traffic. [Not Loaded] Little Snitch Endpoint Security - version 5.0.4 (Objective Development Software GmbH - 2020-12-01) Application: /Volumes/C*********** - Data/A**********s/Little Snitch.app - version 5.0.4 (Objective Development Software GmbH - 2020-12-01) Description: Little Snitch Endpoint Security Kernel Extensions: /Applications/Tunnelblick.app [Not Loaded] tap-notarized.kext (Jonathan Bullard, 20141104 (Tunnelblick build 5300)) [Not Loaded] tun-notarized.kext (Jonathan Bullard, 20141104 (Tunnelblick build 5300)) /Library/Application Support/HASP/kexts [Not Loaded] aksfridge.signed.kext (SFNT Germany GmbH, 1.0.16332) /Library/Application Support/Paragon Software/Snapshot [Not Loaded] ParagonSnapshot.kext (Paragon Software GmbH, 3.3.0 - SDK 10.11) /Library/Application Support/VirtualBox [Not Loaded] VBoxDrv.kext (Oracle America, Inc., 6.1.14) [Not Loaded] VBoxNetAdp.kext (Oracle America, Inc., 6.1.14) [Not Loaded] VBoxNetFlt.kext (Oracle America, Inc., 6.1.14) [Not Loaded] VBoxUSB.kext (Oracle America, Inc., 6.1.14) /Library/Extensions [Not Loaded] FTDIKext.kext (Wacom Technology Corp., 1.0 - SDK 10.11) [Loaded] EnergyDriver.kext (Intel Corporation Apps, 3.7.0 - SDK 10.14) [Loaded] ControllerMate.kext (Ken Heglund, 4.6.0 - SDK 10.6) [Loaded] ufsd_NTFS.kext (Paragon Software GmbH, 15.5.100 - SDK 10.10) [Loaded] VDMounter.kext (Paragon Software GmbH, 1370.2 - SDK 10.8) [Not Loaded] Wacom Tablet.kext (Wacom Technology Corp., Wacom Tablet 6.3.15-3 - SDK 10.11) [Loaded] SATSMARTDriver.kext (Kirill Luzanov, 0.8.2 - SDK 10.9) /Volumes/C*********** - Data/A**********s/Parallels Access.app [Loaded] prl_virtual_hid.kext (Parallels International GmbH, 1.0.3 - SDK 10.9) [Loaded] prl_virtual_sound.kext (Parallels International GmbH, 1.0.36 - SDK 10.6) /Volumes/C*********** - Data/A**********s/Parallels Desktop.app [Not Loaded] prl_hypervisor.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.11) [Not Loaded] prl_netbridge.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.9) [Not Loaded] prl_usb_connect.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.9) [Not Loaded] prl_vnic.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.9) /Volumes/C*********** - Data/A**********s/Sensei.app [Not Loaded] SATSMARTDriver.kext (0.10 - SDK 10.9) [Not Loaded] TrimDriver.kext (2.0 - SDK 10.15) /Volumes/C*********** - Data/A**********s/VyprVPN.app [Not Loaded] SplitTunnel.kext (Golden Frog, Inc., 1.0 - SDK 10.14) [Not Loaded] VyprVPNMalwareFilter.kext (Golden Frog, Inc., 1.0 - SDK 10.12) /Volumes/C*********** - Data/A**********s/Wondershare Filmora9.app [Not Loaded] SystemAudioRecorder.kext (Wondershare Software Co., Ltd, 1.1.0 - SDK 10.9) /Volumes/C************ - Data/A**********s/EaseUS Data Recovery Wizard.app [Not Loaded] EaseUSDriver.kext (WU YANG, 1.0.0 - SDK 10.14) /Volumes/C************ - Data/A**********s/H**************s/***intool.app [Not Loaded] AppleIntelInfo.kext (3.0 - SDK 10.14) /Volumes/C************ - Data/A**********s/H**************s/OC Gen-X.app [Not Loaded] BrcmFirmwareData.kext (2.5.4 - SDK 10.14) [Not Loaded] BrcmPatchRAM2.kext (2.5.4 - SDK 10.14) [Not Loaded] BrcmPatchRAM3.kext (2.5.4 - SDK 10.14) [Not Loaded] BrcmBluetoothInjector.kext (2.5.4 - SDK 10.14) [Loaded] IntelMausi.kext (1.0.3 - SDK 10.14) [Not Loaded] AirportBrcmFixup.kext (2.0.9 - SDK 10.16) [Loaded] AppleALC.kext (1.5.2 - SDK 10.14) [Loaded] Lilu.kext (1.4.7 - SDK 10.14) [Loaded] SMCProcessor.kext (1.1.6 - SDK 10.14) [Loaded] VirtualSMC.kext (1.1.6 - SDK 10.14) [Loaded] WhateverGreen.kext (1.4.2 - SDK 10.14) [Not Loaded] AtherosE2200Ethernet.kext (2.2.2 - SDK 10.12) [Not Loaded] LucyRTL8125Ethernet.kext (1.0.0d6 - SDK 10.15) [Not Loaded] RealtekRTL8111.kext (2.2.2 - SDK 10.12) [Loaded] USBInjectAll.kext (0.7.1 - SDK 10.11) [Not Loaded] SmallTreeIntel82576.kext (1.0 - SDK 10.13) [Not Loaded] AppleMCEReporterDisabler.kext (1.2) [Loaded] SMCSuperIO.kext (1.1.6 - SDK 10.14) [Not Loaded] SMCBatteryManager.kext (1.1.6 - SDK 10.14) [Not Loaded] SMCLightSensor.kext (1.1.6 - SDK 10.14) /Volumes/C************ - Data/A**********s/U*******s/Disk Drill.app [Not Loaded] SecureDisk.kext (Justin Johnson, 1.0 - SDK 10.14) [Not Loaded] SecureDisk_11.kext (Justin Johnson, 1.0 - SDK 10.14) /Volumes/C************ - Data/A**********s/U*******s/DiskWarrior.app [Not Loaded] DiskWarriorPreview.kext (Alsoft, Inc, 5.2 - SDK 10.5) /Volumes/C************ - Data/A**********s/U*******s/Recoverit.app [Not Loaded] WondershareDriver.kext (Wondershare Software Co., Ltd, 2.1.3 - SDK 10.14) /Volumes/C************ - Data/A**********s/U*******s/TechTool Pro 13.app [Not Loaded] spdKernel.kext (Micromat, Inc., 1.0 - SDK 10.14) /Volumes/C************ - Data/A**********s/VMware Fusion.app [Not Loaded] vmioplug.kext (VMware, Inc., 19.9.0) [Not Loaded] vmnet.kext (VMware, Inc., 12.0.0) [Not Loaded] vmmon.kext (VMware, Inc., 12.0.0) System Launch Agents: [Not Loaded] 19 Apple tasks [Loaded] 176 Apple tasks [Running] 136 Apple tasks System Launch Daemons: [Not Loaded] 34 Apple tasks [Loaded] 181 Apple tasks [Running] 145 Apple tasks [Other] One Apple task Launch Agents: [Running] at.obdev.littlesnitch.agent.plist (Objective Development Software GmbH - installed 2020-12-01) [Other] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a2 3d420d.plist (Adobe Systems, Inc. - installed 2020-11-06) [Not Loaded] com.adobe.AdobeCreativeCloud.plist (Adobe Inc. - installed 2020-11-03) [Running] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2020-04-30) [Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-04-30) [Loaded] com.adobe.ccxprocess.plist (Apple - installed 2020-09-04) [Running] com.amazon.sendtokindle.launcher.plist (? 6b4bf780 - installed 2019-11-20) [Loaded] com.audiojinglex.soundtree.agent.plist (? 5c0ee2b3 - installed 2018-11-12) [Other] com.avast.userinit.plist (? 4b9d47d7 - installed 2019-10-04) [Loaded] com.epson.esua.launcher.plist (Seiko Epson Corporation - installed 2020-09-27) [Loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2020-10-16) [Loaded] com.google.keystone.xpcservice.plist (Google, Inc. - installed 2020-10-16) [Loaded] com.googlecode.munki.ManagedSoftwareCenter.plist (? f8bfedaa - installed 2020-10-06) [Not Loaded] com.googlecode.munki.MunkiStatus.plist (? b698141 - installed 2020-10-06) [Running] com.googlecode.munki.app_usage_monitor.plist (? 9be37c7c - installed 2020-10-06) [Not Loaded] com.googlecode.munki.managedsoftwareupdate-loginwindow.plist (? a546384a - installed 2020-10-06) [Loaded] com.googlecode.munki.munki-notifier.plist (? 3604ea2e - installed 2020-10-06) [Running] com.malwarebytes.mbam.frontend.agent.plist (Malwarebytes Corporation - installed 2020-12-07) [Loaded] com.microsoft.OneDriveStandaloneUpdater.plist (Microsoft Corporation - installed 2020-11-04) [Loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2020-12-16) [Running] com.orderedbytes.ControllerMateHelper.plist (Ken Heglund - installed 2018-10-09) [Running] com.paragon-software.ntfs.notification-agent.plist (Paragon Software GmbH - installed 2020-02-12) [Other] com.paragon.updater.plist (Paragon Software GmbH - installed 2014-10-31) [Loaded] com.parallels.mobile.prl_deskctl_agent.launchagent.plist (Parallels International GmbH - installed 2020-04-30) [Loaded] com.staticz.soundsiphon.inputagent.plist (? be4db961 - installed 2020-11-18) [Running] com.staticz.soundsiphon.playeragent.plist (Dominic Feira - installed 2020-12-01) [Running] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2020-12-20) [Running] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2020-12-20) [Running] com.wacom.DataStoreMgr.plist (Wacom Technology Corp. - installed 2020-09-26) [Running] com.wacom.IOManager.plist (Wacom Technology Corp. - installed 2020-09-26) [Running] com.wacom.wacomtablet.plist (Wacom Technology Corp. - installed 2020-09-26) [Loaded] com.xrite.device.softwareupdate.plist (X-Rite, Incorporated - installed 2020-06-02) [Loaded] com.xrite.i1Profiler.tray.plist (X-Rite, Incorporated - installed 2020-12-14) [Not Loaded] org.cindori.SenseiMonitor.plist (? e260d5c9 - installed 2020-11-01) Launch Daemons: [Loaded] TinkerToolSystem-PrivilegedTool.plist (Marcel Bresink - installed 2019-08-15) [Running] at.obdev.littlesnitch.daemon.plist (Objective Development Software GmbH - installed 2020-12-01) [Loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2020-09-25) [Loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2020-09-25) [Loaded] com.adobe.acc.installer.v2.plist (Adobe Inc. - installed 2020-12-04) [Loaded] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2020-10-06) [Other] com.adobe.fpsaud.plist (Adobe Inc. - installed 2020-11-25) [Running] com.aladdin.aksusbd.plist (Gemalto, Inc. - installed 2019-08-09) [Running] com.aladdin.hasplmd.plist (Gemalto, Inc. - installed 2019-08-09) [Loaded] com.apple.musicapps.InstallerHelperTool.plist (App Store - installed 2020-12-20) [Loaded] com.audiojinglex.soundtree.agent.plist (? 5c0ee2b3 - installed 2018-11-12) [Loaded] com.audirvana.audirvana-plus.SysOptimizerTool.plist (Audirvana - installed 2018-11-11) [Running] com.autodesk.AdskLicensingService.plist (Autodesk - installed 2019-12-18) [Other] com.avast.init.plist (? fe750b9b - installed 2019-10-04) [Other] com.avast.update.plist (? f4a2548f - installed 2019-10-04) [Running] com.bjango.istatmenus.daemon.plist (Bjango Pty Ltd - installed 2020-11-18) [Running] com.bjango.istatmenus.fans.plist (Bjango Pty Ltd - installed 2020-11-18) [Loaded] com.bjango.istatmenus.installerhelper.plist (Bjango Pty Ltd - installed 2018-10-14) [Running] com.bombich.ccchelper.plist (Bombich Software, Inc. - installed 2020-12-27) [Loaded] com.charlessoft.pacifist.helper.plist (Charles Srstka - installed 2019-11-06) [Running] com.cleverfiles.cfbackd.plist (Justin Johnson - installed 2020-10-07) [Running] com.easeus.dataprotectbackup.plist (CHENGDU Yiwo Tech Development Co., Ltd - installed 2020-07-27) [Running] com.edovia.screens.connect.plist (Edovia Inc. - installed 2018-10-26) [Loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2020-10-16) [Loaded] com.googlecode.munki.appusaged.plist (? e5a39033 - installed 2020-10-06) [Loaded] com.googlecode.munki.authrestartd.plist (? b0ba4b4e - installed 2020-10-06) [Loaded] com.googlecode.munki.logouthelper.plist (? ae2422b2 - installed 2020-10-06) [Loaded] com.googlecode.munki.managedsoftwareupdate-check.plist (? a3bf0d09 - installed 2020-10-06) [Loaded] com.googlecode.munki.managedsoftwareupdate-install.plist (? 70e0ffde - installed 2020-10-06) [Loaded] com.googlecode.munki.managedsoftwareupdate-manualcheck.plist (? 5e2eee61 - installed 2020-10-06) [Running] com.malwarebytes.mbam.rtprotection.daemon.plist (Malwarebytes Corporation - installed 2020-12-09) [Running] com.malwarebytes.mbam.settings.daemon.plist (Malwarebytes Corporation - installed 2020-12-07) [Loaded] com.microsoft.OneDriveStandaloneUpdaterDaemon.plist (Microsoft Corporation - installed 2020-11-04) [Loaded] com.microsoft.OneDriveUpdaterDaemon.plist (Microsoft Corporation - installed 2020-11-04) [Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2020-12-16) [Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2017-09-05) [Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2020-06-15) [Loaded] com.mingjie.mjrecorder.agent.plist (? 8ce67b23 - installed 2018-11-12) [Not Loaded] com.oracle.java.Helper-Tool.plist (? 0 - installed ) [Running] com.paragon-software.installer.plist (Paragon Software GmbH - installed 2020-10-14) [Loaded] com.paragon-software.ntfs.loader.plist (Apple - installed 2020-02-12) [Running] com.paragon-software.ntfsd.plist (Paragon Software GmbH - installed 2020-02-12) [Loaded] com.paragon-software.snapshot.plist (Paragon Software GmbH - installed 2018-06-04) [Loaded] com.paragon-software.vdmounter.plist (Apple - installed 2020-01-01) [Running] com.parallels.mobile.dispatcher.launchdaemon.plist (Parallels International GmbH - installed 2020-04-30) [Loaded] com.parallels.mobile.kextloader.launchdaemon.plist (Apple - installed 2020-04-30) [Loaded] com.projectosx.clover.daemon.plist (? c08af8c2 - installed 2018-08-03) [Loaded] com.prosofteng.DRInstaller.plist (PROSOFT Engineering, Inc. - installed 2020-07-27) [Other] com.sleepwatcher.plist (? 771cbcad - installed 2018-10-19) [Other] com.sonos.SonosLibraryServer.plist (? ad20e9f8 - installed 2019-08-11) [Running] com.staticz.soundsiphon.bridgedaemon.plist (Dominic Feira - installed 2020-12-01) [Loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2020-12-16) [Running] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2020-12-20) [Loaded] com.tonymacx86.InstallHelper.plist (TONYMACX86 LLC - installed 2018-11-04) [Not Loaded] com.twocanoes.mds.micromdm.plist (? 5a78e40d - installed 2020-11-03) [Running] com.wacom.UpdateHelper.plist (Wacom Technology Corp. - installed 2020-09-26) [Loaded] com.wacom.displayhelper.plist (Apple - installed 2020-09-26) [Running] com.xrite.device.xrdd.plist (X-Rite, Incorporated - installed 2020-06-02) [Loaded] com.xrite.device.xrdd.restart.plist (X-Rite, Incorporated - installed 2020-01-01) [Running] io.privado.main.hive.plist (PRIVADO NETWORKS LLC - installed 2020-11-04) [Loaded] net.tunnelblick.tunnelblick.tunnelblickd.plist (Jonathan Bullard - installed 2020-12-15) [Loaded] nl.syncfactory.HedgeHelper.Mac.plist (The Sync Factory - installed 2020-07-22) [Running] org.cindori.SenseiDaemon.plist (? 2d57335a - installed 2020-09-04) [Loaded] org.cindori.SenseiHelper.plist (? 2c289df0 - installed 2020-11-01) [Not Loaded] org.virtualbox.startup.plist (? 700b9385 - installed 2020-09-21) [Running] vyprvpnservice.plist (Golden Frog, Inc. - installed 2020-07-24) User Launch Agents: [Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-05-01) [Not Loaded] com.adobe.ccxprocess.plist (Apple - installed 2020-07-19) [Running] com.bjango.istatmenus.agent.plist (Bjango Pty Ltd - installed 2020-11-18) [Running] com.bjango.istatmenus.status.plist (Bjango Pty Ltd - installed 2020-11-18) [Other] com.dropbox.DropboxMacUpdate.agent.plist (? 0 - installed 2019-08-22) [Loaded] com.dxo.PhotoLab4LaunchAgent.plist (DxO Labs - installed 2020-12-19) [Running] com.goldenfrog.VyprVPNUserAgent.plist (Golden Frog, Inc. - installed 2020-07-24) [Running] com.parallels.mobile.startgui.launchagent.plist (Parallels International GmbH - installed 2020-12-30) [Other] mega.mac.megaupdater.plist (? 0 - installed 2019-11-24) [Loaded] net.tunnelblick.tunnelblick.LaunchAtLogin.plist (? 0 - installed 2020-12-14) [Not Loaded] org.virtualbox.vboxwebsrv.plist (Oracle America, Inc. - installed 2020-09-21) User Login Items: [Running] AppCleaner SmartDelete (Julien Ramseier - installed 2019-09-20) Modern Login Item /Applications/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app [Not Loaded] CloverRunAtLogin (? - installed 2020-08-02) Modern Login Item /Applications/Clover.app/Contents/Library/LoginItems/CloverRunAtLogin.app [Not Loaded] CompressorHelper (App Store - installed 2019-11-10) Modern Login Item /Applications/Compressor.app/Contents/Library/LoginItems/CompressorHelper.app [Running] Day-O (Shaun Inman - installed 2020-04-11) Application /Applications/Day-O.app [Running] EaseUS Data Recovery Wizard Tray (CHENGDU Yiwo Tech Development Co., Ltd - installed 2020-06-10) Application /Applications/EaseUS Data Recovery Wizard.app/Contents/MacOS/EaseUS Data Recovery Wizard Tray.app [Not Loaded] FonePaw Screen Recorder Helper (FonePaw Technology Limited - installed 2018-12-06) Modern Login Item /Applications/FonePaw Screen Recorder.app/Contents/Library/LoginItems/FonePaw Screen Recorder Helper.app [Loaded] HWMonitorSMC2 Helper (? - installed 2019-08-29) Modern Login Item /Applications/***intosh tools/HWMonitorSMC2.app/Contents/Library/LoginItems/HWMonitorSMC2 Helper.app [Loaded] FSMenuAppLoginItemHelper (Paragon Software GmbH - installed 2020-10-29) Modern Login Item /Applications/NTFS for Mac.app/Contents/Library/LoginItems/FSMenuAppLoginItemHelper.app [Running] OneDrive (? - installed 2020-11-04) Application /Applications/OneDrive.app [Not Loaded] Launcher Disabler (Microsoft Corporation - installed 2020-11-04) Modern Login Item /Applications/OneDrive.app/Contents/Library/LoginItems/Launcher Disabler.app [Not Loaded] OneDrive Launcher (Microsoft Corporation - installed 2020-11-04) Modern Login Item /Applications/OneDrive.app/Contents/Library/LoginItems/OneDrive Launcher.app [Not Loaded] PathFinderLauncher (? - installed 2020-08-05) Modern Login Item /Applications/Path Finder copie gros fichiers.app/Contents/Library/LoginItems/PathFinderLauncher.app [Not Loaded] Launcher (PRIVADO NETWORKS LLC - installed 2020-11-04) Modern Login Item /Applications/Privado.app/Contents/Library/LoginItems/Launcher.app [Running] Sound Control (Dominic Feira - installed 2020-12-02) Application /Applications/Sound Control.app [Loaded] SoundControlLauncher (Dominic Feira - installed 2020-12-02) Modern Login Item /Applications/Sound Control.app/Contents/Library/LoginItems/SoundControlLauncher.app [Loaded] StartUpHelper (Spotify - installed 2020-10-09) Modern Login Item /Applications/Spotify (old).app/Contents/Library/LoginItems/StartUpHelper.app [Loaded] Start Liquidctl (? - installed 2020-10-27) Application /Applications/Start Liquidctl.app [Not Loaded] SyncMateService (? - installed 2020-03-31) Modern Login Item /Applications/SyncMate.app/Contents/Library/LoginItems/SyncMateService.app [Not Loaded] TeamViewerMeetingLoginItem (TeamViewer GmbH - installed 2020-12-20) Modern Login Item /Applications/TeamViewer.app/Contents/Library/LoginItems/TeamViewerMeetingLoginItem.app [Not Loaded] LaunchTTS (? - installed 2019-09-20) Modern Login Item /Applications/TinkerTool System.app/Contents/Library/LoginItems/LaunchTTS.app [Not Loaded] TrashMeHelper (Jean-Baptiste ZEDDA - installed 2020-08-22) Modern Login Item /Applications/TrashMe.app/Contents/Library/LoginItems/TrashMeHelper.app [Running] CCC User Agent (Bombich Software, Inc. - installed 2020-12-27) Modern Login Item /Applications/Utilities/Carbon Copy Cloner copy 2 original website.app/Contents/Library/LoginItems/CCC User Agent.app [Running] SmartDaemon (? - installed 2020-10-01) Application /Applications/Utilities/Disk Drill.app/Contents/Helpers/SmartDaemon.app [Loaded] DriveDxLoginItemHelper (Kirill Luzanov - installed 2020-11-08) Modern Login Item /Applications/Utilities/DriveDx.app/Contents/Library/LoginItems/DriveDxLoginItemHelper.app [Not Loaded] DroiderLauncher (? - installed 2020-06-18) Modern Login Item /Applications/Utilities/MacDroid.app/Contents/Library/LoginItems/DroiderLauncher.app [Not Loaded] MacUpdaterLaunchHelper (CoreCode Limited - installed 2020-12-09) Modern Login Item /Applications/Utilities/MacUpdater.app/Contents/Library/LoginItems/MacUpdaterLaunchHelper.app [Loaded] Malwarebytes (Malwarebytes Corporation - installed 2020-05-03) Application /Applications/Utilities/Malwarebytes.app [Loaded] MonitorControlHelper (Joni Van Roost - installed 2020-04-02) Modern Login Item /Applications/Utilities/MonitorControl.app/Contents/Library/LoginItems/MonitorControlHelper.app [Not Loaded] SpeedTestHelper (App Store - installed 2020-09-22) Modern Login Item /Applications/Utilities/Speedtest.app/Contents/Library/LoginItems/SpeedTestHelper.app [Running] Viber (Viber Media SARL. - installed 2020-12-25) Application /Applications/Viber.app [Running] WhatsApp (WhatsApp Inc. - installed 2020-12-17) Application /Applications/WhatsApp.app [Running] SwitchResX Daemon (Stephane Madrau - installed 2020-07-05) Application ~/Library/PreferencePanes/SwitchResX.prefPane/Contents/MacOS/SwitchResX Daemon.app [Not Loaded] ChronoSync Scheduler (Econ Technologies, Inc. - installed 2020-07-23) Modern Login Item /Volumes/C************ - Data/A**********s/U*******s/ChronoSync synchronisation de répertoires.app/Contents/Library/LoginItems/ChronoSync Scheduler.app Internet Plug-ins: AdobeAAMDetect: 3.0.0.0 (Adobe Inc. - installed 2020-11-03) FlashPlayer-10.6: 32.0.0.465 (? - installed 2020-12-08) AdobePDFViewerNPAPI: 17.012.20098 (Adobe Systems, Inc. - installed 2020-09-04) AdobePDFViewer: 20.012.20041 (Adobe Systems, Inc. - installed 2020-09-04) Flash Player: 32.0.0.465 (? - installed 2020-12-08) SharePointBrowserPlugin: 14.7.7 (? - installed 2020-08-04) PepperFlashPlayer: 32.0.0.465 (Adobe Inc. - installed 2020-12-08) Audio Plug-ins: MJRecorderDevice: 1.1 (? - installed 2018-11-12) Audiojingle: 1.6.0 (? - installed 2018-11-12) _SoundSiphon: 3.3.0b11 (Dominic Feira - installed 2020-12-01) Safari Extensions: "Open In" button for Internet Explorer (? - installed 2019-12-12) Bitwarden (8bit Solutions LLC - installed 2020-12-04) Open in IINA (HeChen LI - installed 2020-10-01) 3rd Party Preference Panes: Flash Player (Adobe Inc. - installed 2020-11-25) FUSE (Benjamin Fleischer - installed 2019-09-15) ParagonNTFS (Paragon Software GmbH - installed 2020-02-12) SwitchResX (Stephane Madrau - installed 2020-07-05) WacomTablet (Wacom Technology Corp. - installed 2020-09-26) Backup: Auto backup: Yes Destinations: T******************r [Local] (Last used) Total size: 1.33 TB Total number of backups: 102 Oldest backup: 2020-12-19 16:53:19 Last backup: 2020-12-31 22:12:10 24 local snapshots Oldest local snapshot: 2020-12-30 23:11:18 Last local snapshot: 2020-12-31 22:11:28 3rd party backup: Carbon Copy Cloner Performance: System Load: 3.24 (1 min ago) 3.57 (5 min ago) 3.60 (15 min ago) Nominal I/O speed: 1.30 MB/s File system: 11.03 seconds Write speed: 3005 MB/s Read speed: 2915 MB/s CPU Usage Snapshot: Type Overall System: 10 % User: 8 % Idle: 82 % Top Processes Snapshot by CPU: Process (count) CPU (Source - Location) Sync Folders Pro 99.88 % (? - /Applications/Sync Folders Pro.app) Finder 69.68 % (Apple) WindowServer 34.46 % (Apple) Google Chrome Helper (GPU) 8.00 % (Google, Inc.) storagekitd 7.78 % (Apple) Top Processes Snapshot by Memory: Process (count) RAM usage (Source - Location) plugin-container (11) 2.81 GB (Mozilla Corporation) storagekitd 1.17 GB (Apple) Google Chrome Helper (Renderer) (10) 1.12 GB (Google, Inc.) Core Audio Driver (_SoundSiphon.driver) 1.05 GB (?) EtreCheckPro 1.01 GB (Etresoft, Inc.) Top Processes Snapshot by Network Use: Process Input / Output (Source - Location) mDNSResponder 10 MB / 1 MB (Apple) firefox 5 MB / 452 KB (Mozilla Corporation) netbiosd 529 KB / 392 KB (Apple) Viber 623 KB / 62 KB (Viber Media SARL.) hasplmd 351 KB / 103 KB (Gemalto, Inc.) Top Processes Snapshot by Energy Use: Process (count) Energy (0-100) (Source - Location) Finder 12 (Apple) WindowServer 9 (Apple) diskarbitrationd 6 (Apple) storagekitd 5 (Apple) deleted 3 (Apple) Virtual Memory Information: Physical RAM: 64 GB Free RAM: 29.42 GB Used RAM: 25.43 GB Cached files: 9.16 GB Available RAM: 38.57 GB Swap Used: 0 B Software Installs (past 30 days): Install Date Name (Version) 2020-12-02 STZ Sound Processor (3.3.0b11) 2020-12-04 macOS Big Sur Beta (20.0.5395.7) 2020-12-08 Adobe Flash Player (32.0.0.465) 2020-12-08 Adobe Pepper Flash Player (32.0.0.465) 2020-12-09 Synology Cloud Station Drive (4.3.3) 2020-12-09 Malwarebytes for Mac (1.0) 2020-12-14 Wacom Tablet (0) 2020-12-14 i1Profiler (1.0) 2020-12-14 Infinite Color Installer (1.0) 2020-12-15 macOS Big Sur 2020-12-16 Microsoft AutoUpdate (4.30.20121301) 2020-12-16 Microsoft PowerPoint (16.44.20121301) 2020-12-16 Microsoft Excel (16.44.20121301) 2020-12-16 Microsoft Word (16.44.20121301) 2020-12-16 Microsoft Outlook (16.44.20121301) 2020-12-19 macOS 11.1 (11.1) 2020-12-19 macOS 11.2 (11.2) 2020-12-20 TeamViewer (15.13.7) 2020-12-31 MDS (3.6.36240) Clean up: ~/Library/LaunchAgents/com.dropbox.DropboxMacUpdate.agent.plist ~/Library/Dropbox/DropboxMacUpdate.app/Contents/MacOS/DropboxMacUpdate Executable not found /Library/LaunchAgents/com.avast.userinit.plist /Applications/Avast.app/Contents/Backend/hub/userinit.sh Executable not found /Library/LaunchDaemons/com.avast.init.plist /Applications/Avast.app/Contents/Backend/hub/init.sh Executable not found /Library/LaunchDaemons/com.avast.update.plist /Applications/Avast.app/Contents/Backend/scripts/update/update.sh Executable not found /Library/LaunchDaemons/com.sonos.SonosLibraryServer.plist /Library/Application Support/Sonos/SonosLibraryServer Executable not found ~/Library/LaunchAgents/mega.mac.megaupdater.plist /Applications/MEGAsync.app/Contents/MacOS/MEGAupdater Executable not found Diagnostics Information (past 7-30 days): 2020-12-31 20:32:22 signpost_reporter - High CPU Use (6 times) Executable: /usr/libexec/signpost_reporter 2020-12-31 09:48:29 WindowServer - High CPU Use (2 times) Executable: /System/Library/PrivateFrameworks/SkyLight.framework/Resources/WindowServer 2020-12-30 13:35:43 Sync Folders Pro.app - High CPU Use Executable: /Applications/Sync Folders Pro.app 2020-12-30 12:36:14 OneDrive.app - High CPU Use (2 times) Executable: /Applications/OneDrive.app 2020-12-30 12:35:40 Parallels Access.app - High CPU Use (2 times) Executable: /Applications/Parallels Access.app 2020-12-28 03:02:27 TeamViewer.app - High CPU Use Executable: /Applications/TeamViewer.app 2020-12-26 17:30:19 Viber.app - High CPU Use Executable: /Applications/Viber.app 2020-12-26 11:12:58 lsd - Crash Executable: /usr/libexec/lsd Details: dyld3 mode savedDB WAS seeded, newDB WAS NOT seeded. Failed attempting to remap d atabase, abort to trigger seeding. Error: Error Domain=NSOSStatusError Domain Code=-9496 "kCSStoreBadDataErr" UserInfo={Line=204, Checksum=2, ZeroedRanges=( "0x6DC000-0x6EDFFF (74 KB)" ), NSDebugDescription=kCSStoreBadDataErr, NSURL=file:/var/folders/zz/z yxvpxvq6csfxvn_n0000000000000/0/com.apple.LaunchServices.dv/com.apple. LaunchServices-2543-v2.csstore} abort() called End of report -------------------- Hackintosh Gigabyte Z490 VISION D Intel® Core™ i7-10700K 16M Cache, up to 5.10 GHz 8Core 16 threads Gigabyte RX 5700 XT 64Go RAM 3600MHz SSDs addlink M.2 PCIE G3x4 NVMe 2To, Lextar M.2 PCIE G3x4 NVMe 2To, SSD Samsung 860 500Go (Windows), 4 SATAs Boîtier Cooler Master 700P 3 Ecrans Mi Xiaomi 34" 3440*1440
31 Dec 2020, 17:22
Aïe
Il y a un problèmmmmmmeeeeee. Bonne fin d'année. On va la regratter celle-ci. @ l'an de mains |
31 Dec 2020, 17:43
C'est du vice ou un fake ?
31 Dec 2020, 18:31
Ça file vite fait en section Divers…
Bonne année aussi ! -------------------- ¶ MacBook Pro 14’’ 2021, M1 Pro, 16 Go/1 To – macOS 12.6 “Monterey” ¶ MacBook Pro 15’’ mi-2010 Core i5 2,53 GHz, 8 Go/SSD Samsung 860EVO 1 To – Mac OSX 10.6.8 ¶ Power Macintosh G3 beige de bureau, rev.1 @ 233MHz, 288 Mo/4Go – MacOS 9.1 + carte PCI IDE/ATA Tempo 66 Acard 6260 avec HD interne Maxtor 80 Go + graveur interne CDRW/DVD LG GCC-4520B + tablette A4 Wacom UD-0608-A + LaCie ElectronBlueIV 19" + HP ScanJet 6100C ¶ B-Box 3 + HP LaserJet 4000 N
1 Jan 2021, 00:24
C'est du vice ou un fake ? Pourquoi un fake? Je fais juste un bilan de santé de mon micro en fin d'année ! -------------------- Hackintosh Gigabyte Z490 VISION D Intel® Core™ i7-10700K 16M Cache, up to 5.10 GHz 8Core 16 threads Gigabyte RX 5700 XT 64Go RAM 3600MHz SSDs addlink M.2 PCIE G3x4 NVMe 2To, Lextar M.2 PCIE G3x4 NVMe 2To, SSD Samsung 860 500Go (Windows), 4 SATAs Boîtier Cooler Master 700P 3 Ecrans Mi Xiaomi 34" 3440*1440
Nous sommes le : 26th April 2024 - 01:54 |
