#8941
![]() Macbidouilleur Normand ![]() ![]() ![]() Groupe : Membres Messages : 608 Inscrit : 10 Jan 2003 Lieu : Dans mon slip Membre no 5 554 ![]() |
Salut Ounet,
Bonne journuit mézamis ![]() -------------------- Vous voulez me faire chanter ? C'est ici !
MBP Retina 15" Core i7 2,7 Ghz, Ram 16Go, Mac OS X.10.11.6 |
#8942
![]() Modérateur <span style= ![]() ![]() ![]() ![]() ![]() Groupe : Ancien de la team Messages : 16 259 Inscrit : 2 Feb 2003 Lieu : BZH 29 S Membre no 5 954 ![]() |
'lut les gens
![]() Un petit coucou en passant. Bonjournuit à tous -------------------- |
#8943
![]() Aurum Pilius ![]() Groupe : Membres Messages : 110 Inscrit : 1 Jun 2002 Lieu : Paris 5e Membre no 2 600 ![]() |
Bonne journuit Lohuli, Triskel et le CTC.
![]() ![]() Beck - Nobody's fault but my own Treated you like a rusty blade A throwaway from an open grave Cut you loose from a chain gang And let you go And on the day you said it's true Some love holds, some gets used Tried to tell you I never knew It could be so sweet Who could ever be so cruel Blame the devil for the things you do Its such a selfish way to lose The way you lose these wasted blues These wasted blues Tell me that it's nobody's fault Nobody's fault but my own That it's nobody's fault Nobody's fault but my own When the moon is a counterfeit Better find the one that fits Better find the one that lights The way for you When the road is full of nails Garbage pails and darkened jails And their tongues are full of heartless tales That drain on you Who would ever notice you You fade into a shaded room It's such a selfish lose The way you lose these wasted blues These wasted blues Tell me that it's nobody's fault Nobody's fault but my own (x6) -------------------- Signature pas à jour du tout ! :D
Mac Pro 2x3ghz / 5 Go / DD Int+Ext ± 2To / Radeon X1900XT / DELL 3007WFP-HC / (mon iPod 20 Go 3eG est mort) / Freebox HD / iSight / Nokia N95 / Nokia N810 / Canon 400D. MacBook Pro 15' Santa Rosa 2.2ghz/2Go/120Go. G3 Beige MiniTower - 300@366 mHz, 512 mo, 8go + 120go, 100bt, X.3.9 dns/mail/ftp/www/php/mysq... Une p'tite photo ? Le RubIcôn "Tous les mots que j'avais à dire se sont changés en étoiles" Apollinaire |
#8944
Euh... comment on dit déjà ?
Ah oui ! Ouverture du CUPTC. ![]() 'scusez, je n'ai pas l'habitude. ![]() Bonsoir. -------------------- Signature pas à jour du tout ! :D
#8945
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 2 642 Inscrit : 16 Aug 2002 Lieu : Parisi Membre no 3 177 ![]() |
YO! Y a quelqu'un ?
#8946
![]() grat' grat' d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 5 129 Inscrit : 25 Feb 2004 Lieu : Paris 13ème Membre no 15 389 ![]() |
Hello Bonswââr tout le monde !!
Salut Zaraa et Sacha -------------------- MBP 2011 2,0 GHz, écran mat, 8Go RAM, SSD Crucial MX100 512Go + DD WD 1To, OS X.10 / iPhone6 / iPad2 64Go / Freebox v6 23Mbps
#8947
Hello ZaraA et ManiX, heureusement que vous êtes arrivés, j'ai cru que j'allais faire un triple post pour l'...
Ouverture du CTC ! ![]() -------------------- Signature pas à jour du tout ! :D
#8948
toujours là quand il le faut !
![]() Quand il ne faut pas aussi, d'ailleurs... ![]() -------------------- MBP 2011 2,0 GHz, écran mat, 8Go RAM, SSD Crucial MX100 512Go + DD WD 1To, OS X.10 / iPhone6 / iPad2 64Go / Freebox v6 23Mbps
#8949
Arf, ça ne se bouscule pas au portillon dîtes donc.
#8950
![]() Modérateur Tropical ![]() ![]() ![]() ![]() ![]() Groupe : Modérateurs Messages : 2 807 Inscrit : 7 Apr 2002 Lieu : Sainte-Marie (La Réunion) Membre no 2 220 ![]() |
Bonjour les gens !
![]() Très bon choix, la chanson d'hier , sacha ![]() -------------------- MacBook Pro 13 début 2011 sous 10.13.6 qui en est à sa quatrième batterie (SSD de 500 Go, dur d'1 To invisible depuis la MàJ High Sierra 10.13.5 (mais est-ce lié ?), 16 Go de RAM - le graveur DVD est donc externe)
NAS Synology DS220j pour les sauvegardes TimeMachine (2X1 To) Imprimante laser - scanner Brother MFC-L2720DW |
#8951
Hello Pattt.
Merci. ![]() Comment ça va t'y ? -------------------- Signature pas à jour du tout ! :D
#8952
Ca va pas mal.
Bon, j'ai toujours ce problème d'images disque. Mais je peux de nouveau réparer les autorisations. -------------------- MacBook Pro 13 début 2011 sous 10.13.6 qui en est à sa quatrième batterie (SSD de 500 Go, dur d'1 To invisible depuis la MàJ High Sierra 10.13.5 (mais est-ce lié ?), 16 Go de RAM - le graveur DVD est donc externe)
#8953
C'est déjà ça de gagné. Tu vas bien finir par y arriver, il n'y a pas de raison.
#8954
![]() Macbidouilleur d'argent ! ![]() ![]() ![]() Groupe : Membres Messages : 649 Inscrit : 14 Jul 2003 Lieu : Séoul Membre no 8 583 ![]() |
Coucou et bonne journuit à vous deux Sacha et Pattt ! ![]() Et une bonne fermeture à Sacha. ![]() ![]() -------------------- MBA 11" (late 2011)
MBP Unibody 2,53Ghz Powerbook 17" 1Ghz iPhone 4S 64Go |
#8955
Salut ALSAD !
Bonne journuit ![]() -------------------- MacBook Pro 13 début 2011 sous 10.13.6 qui en est à sa quatrième batterie (SSD de 500 Go, dur d'1 To invisible depuis la MàJ High Sierra 10.13.5 (mais est-ce lié ?), 16 Go de RAM - le graveur DVD est donc externe)
#8956
Bonne journuit Pattt, ALSAD (merci. un peu grande ton image
![]() ![]() ![]() Sushi, John Carroll Doyle Vincent Delerm - Quatrième de couverture 23 juillet, Paris s'éteint Et sur le Quai des Grands Augustins Nous tournons les pages à l'improviste Devant l'étalage d'un bouquiniste Je ne vous connais pas, je vous frôle, Là sur le Quai, épaule contre épaule. Nous jetons en même temps un oeil sur Les quatrièmes de couverture. Une biographie de Signoret Voilà le genre de choses qui vous plaît. Un storyboard de Fellini Le genre de truc qui vous fait lever la nuit. Je vous devine à Juan-les-Pins Un Press-Pocket entre les mains Emportez-vous à Maisons-Laffite Ce Boris Vian en 10/18? Je connais bien votre poignet Je connais vos mains, votre bracelet. J'aime la manière dont vous reposez Tristan Corbière sur le côté Qu'allez-vous donc penser de moi si J'attrape en rayon "Les années Platini"? Finalement, je préfère me rabattre Sur la NRF de 54 300 pages sur la guerre d'Espagne Le genre de chose qui nous éloigne Un vieux Sempé en Livre de poche Le genre de truc qui nous rapproche Guide du Routard du Sri Lanka Dieu soit loué, on ne se connaît pas. Hitchkock-Truffaut : les "Entretiens" Nous avons tant de choses en commun. 23 juillet, Paris s'éteint Et sur le Quai des Grands Augustins Nous tournons les pages à l'improviste Devant l'étalage d'un bouquiniste Je ne vous connais pas, je vous frôle, Là sur le Quai, épaule contre épaule. Sur les quatrièmes de couverture Nous cherchons la même aventure. Sur les quatrièmes de couverture... -------------------- Signature pas à jour du tout ! :D
#8957
Ouverture du CUPTC.
Bonsoir. ![]() Ce message a été modifié par Sacha - 27 Sep 2004, 01:00. -------------------- Signature pas à jour du tout ! :D
#8958
Fermeture du CUPTC..
Ouverture du CTC ! ![]() . o O ( n'importe quoi ! ![]() -------------------- Signature pas à jour du tout ! :D
#8959
Trois beaux posts de suite en solitaire. bonjoir Sacha, le Thierry Marie du CTC !
#8960
Lol
![]() Ouais, il faut bien s'occuper comme on peut. ![]() Bonsoir ManiX. -------------------- Signature pas à jour du tout ! :D
#8961
Eh ben ,c'est assez mort, le dimanche soir.
#8962
Tu m'étonnes, c'est la nuit des morts-vivants.
![]() Bonjour Pattt ![]() Que s'est-il passé pendant que j'avais le dos tourné. Tu me racontes ? ![]() -------------------- Signature pas à jour du tout ! :D
#8963
Salut sacha : ben j'ai rien remarqué
![]() [edit] je vais d'ailleurs te laisser peaufiner un belle fermeture et te souhaite une bonne journuit ![]() -------------------- MacBook Pro 13 début 2011 sous 10.13.6 qui en est à sa quatrième batterie (SSD de 500 Go, dur d'1 To invisible depuis la MàJ High Sierra 10.13.5 (mais est-ce lié ?), 16 Go de RAM - le graveur DVD est donc externe)
#8964
QUOTE(Pattt @ 27 Sep 2004, 04:12) Salut sacha : ben j'ai rien remarqué ![]() C'est bien ce qu'il m'avait semblé. ![]() Mais des fois on ne sait jamais. ![]() Merci et bonne journée à toi Pattt. -------------------- Signature pas à jour du tout ! :D
#8965
Bonne journuit le CTC.
![]() ![]() Peter Gabriel - Washing Of The Water River, river carry me on Living river carry me on River, river carry me on To the place where I come from So deep, so wide, will you take me on your back for a ride If I should fall, would you swallow me deep inside River, show me how to float I feel like I'm sinking down Thought that I could get along But here in this water My feet won't touch the ground I need something to turn myself around Going away, away towards the sea River deep, can you lift up and carry me Oh roll on though the heartland 'Til the sun has left the sky River, river carry me high 'Til the washing of the water make it all alright Let your waters reach me like she reached me tonight Letting go, it's so hard The way it's hurting now To get this love untied So tough to stay with thing 'Cause if I follow through I face what I denied I get those hooks out of me And I take out the hooks that I sunk deep in your side Kill that fear of emptiness, loneliness I hide River, oh river, river running deep Bring me something that will let me get to sleep In the washing of the water will you take it all away Bring me something to take this pain away -------------------- Signature pas à jour du tout ! :D
#8966
'Soir M'Sieurs Dames
![]() Ouverture du CUPTC ![]() -------------------- Vous voulez me faire chanter ? C'est ici !
#8967
![]() j'aurais voulu avoir un titre (le blues du bidouilleur) ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 1 998 Inscrit : 13 Mar 2003 Lieu : Là ou je me pose... Membre no 6 655 ![]() |
QUOTE(Lohuli @ 28 Sep 2004, 00:07) 'Soir M'Sieurs Dames ![]() Ouverture du CUPTC ![]() [right][snapback]863476[/snapback][/right] bonsoir le Normand de Lyon ...; ça va ty ? -------------------- Mac Pro 2,66GHz/iMac 5k full options//mac Mini/Macbook Pro 15"touch/iPhone 7/iPodG1 Sterpinisé/Macenstephisé/ipad pro 1st gen/2021
Satellite du CTC Olympus E-1, E-3,OM-D EM-1 + Zuiko gamme pro et top pro et M.Zuiko Pro. |
#8968
Bien et toi ? Mais tu as oublié, le Normand de Lyon expatrié à Marseille
#8969
![]() Le Baleineau (© Grognon) Groupe : Membres Messages : 30 Inscrit : 31 Mar 2003 Lieu : 45°45'57'' N 04°51'27'' E Membre no 6 924 ![]() |
Coucou, vas-y Lohu
![]() -------------------- Et glou et glou et glou
#8970
Yozatous !
Voici un petit iMix de ma composition. J'aime bien cette fonction de l'ITMS. Bises éclaires. -------------------- |
Nous sommes le : 14th September 2025 - 04:41 |
