29 Jan 2004, 18:15
![]() Méchant modérateur paranoïaque ![]() ![]() ![]() ![]() ![]() Groupe : Modérateurs Messages : 10 755 Inscrit : 24 Jan 2002 Lieu : Confoederatio Helvetica, Kanton Wallis Membre no 1 865 |
Technical Note
QUOTE Symptom
If an error condition is detected by one of the Apple LCD display products, the power light will display a series of short flashes. Products affected * Apple Studio Display (ADC) * Apple Studio Display 17 (ADC) * Apple Studio Display (LCD) * Apple Cinema Display (ADC) * Apple Cinema HD Display * Apple Cinema Display (20-inch) Solution Shut down the computer, disconnect and reconnect the display cable, then start up the computer again. This may be all that is necessary to resolve this issue if the error is caused by a loose connection. A sequence of two short flashes and a long flash indicate the display is detecting a backlight lamp error which may require service to correct. A repeating sequence of three short flashes indicates the display is detecting input in the wrong video format. Check that your display is compatible with the video card card and that supported versions of Mac OS and the display software are being used. -------------------- Nothing Else Matters
| Nous sommes le : 2nd May 2026 - 03:14 |
