2 Pages V  < 1 2
> Erreurs répétitives installation Big Sur
maya.ahh
posté 7 Dec 2020, 23:22
Message #31
Inscrit : 4 Dec 2020
Membre no 213 020
Merci !
Je pense que l’opération s’est bien passée, malgré les mêmes erreurs en sortie :
Code
mayaahh2:~ jeremy$ diskutil list
/dev/disk0 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *4.0 TB     disk0
   1:                        EFI EFI                     314.6 MB   disk0s1
   2:                 Apple_APFS Container disk2         2.0 TB     disk0s2
   3:                 Apple_APFS Container disk1         2.0 TB     disk0s3
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +2.0 TB     disk1
                                 Physical Store disk0s3
   1:                APFS Volume Big Sur - Données       11.9 GB    disk1s1
   2:                APFS Volume Preboot                 136.1 MB   disk1s2
   3:                APFS Volume Recovery                652.2 MB   disk1s3
   4:                APFS Volume VM                      20.5 KB    disk1s4
   5:                APFS Volume Big Sur                 32.8 KB    disk1s5
   6:                APFS Volume Update                  86.0 KB    disk1s6
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +2.0 TB     disk2
                                 Physical Store disk0s2
   1:                APFS Volume Macintosh HD - Données  799.9 GB   disk2s1
   2:                APFS Volume Preboot                 79.9 MB    disk2s2
   3:                APFS Volume Recovery                529.0 MB   disk2s3
   4:                APFS Volume VM                      1.1 GB     disk2s4
   5:                APFS Volume Macintosh HD            11.0 GB    disk2s5
mayaahh2:~ jeremy$ diskutil ap deletecontainer disk0s3
Started APFS operation on disk1
Deleting APFS Container with all of its APFS Volumes
Unmounting Volumes
Unmounting Volume "Big Sur - Données" on disk1s1
Unmounting Volume "Preboot" on disk1s2
Unmounting Volume "Recovery" on disk1s3
Unmounting Volume "VM" on disk1s4
Unmounting Volume "Big Sur" on disk1s5
Unmounting Volume "Update" on disk1s6
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Reformatting former APFS disks
Initialized /dev/rdisk0s3 as a 2 TB case-insensitive HFS Plus volume with a 155648k journal
Mounting disk
1 new disk created or changed due to APFS operation
Disk from APFS operation: disk0s3
Finished APFS operation on disk1
   3:                  Apple_HFS Untitled                2.0 TB     disk0s3
mayaahh2:~ jeremy$ diskutil eraseVolume free space disk0s3
Started erase on disk0s3 Untitled
Unmounting disk
Finished erase on disk0
mayaahh2:~ jeremy$ diskutil ap resizeContainer disk0s2 0b
Aligning grow delta to 2 001 907 707 904 bytes and targeting a new physical store size of 4 001 907 707 904 bytes
Determined the maximum size for the targeted physical store of this APFS Container to be 4 001 906 679 808 bytes
Resizing APFS Container designated by APFS Container Reference disk2
The specific APFS Physical Store being resized is disk0s2
Verifying storage system
Using live mode
Performing fsck_apfs -n -x -l -S /dev/disk0s2
Checking the container superblock
warning: container has been mounted by APFS version 1677.50.1, which is newer than 1412.141.1
warning: disabling overallocation repairs by default; use -o to override
Checking the EFI jumpstart record
Checking the space manager
Checking the space manager free queue trees
Checking the object map
Checking volume
Checking the APFS volume superblock
The volume Macintosh HD - Données was formatted by diskmanagementd (1412.141.1) and last modified by apfs_kext (1412.141.1)
Checking the snapshot metadata tree
Checking the extent ref tree
Checking the fsroot tree
warning: apfs_fs_alloc_count is not valid (expected 749796, actual 195297993)
Checking volume
The volume Preboot was formatted by diskmanagementd (1412.141.1) and last modified by apfs_kext (1412.141.1)
Checking volume
The volume Recovery was formatted by diskmanagementd (1412.141.1) and last modified by apfs_kext (1412.141.1)
Checking volume
The volume VM was formatted by diskmanagementd (1412.141.1) and last modified by apfs_kext (1412.141.1)
Checking volume
The volume Macintosh HD was formatted by diskmanagementd (1412.141.1) and last modified by apfs_kext (1412.141.1)
warning: apfs_fs_alloc_count is not valid (expected 41017, actual 2697534)
Verifying allocated space
warning: overallocation detected on Main device: (0x231a96+3) bitmap address (0xa6871)
[là, on a mille fois le même message, d’ailleurs, même le terminal en a marre, cf. au dessous]
warning: overallocation detected on Main device: (0x231c48+10) bitmap address (0xa6871)
Too many warnings of this type generated; suppressing subsequent ones
The volume /dev/disk0s2 appears to be OK
Storage system check exit code is 0
Growing APFS Physical Store disk0s2 from 2 000 000 000 000 to 4 001 907 707 904 bytes
Modifying partition map
Growing APFS data structures
   2:                 Apple_APFS Container disk2         4.0 TB     disk0s2
   0:      APFS Container Scheme -                      +4.0 TB     disk2
   1:                APFS Volume Macintosh HD - Données  800.3 GB   disk2s1
jeanjd63
posté 7 Dec 2020, 23:24
Message #32
Inscrit : 15 Nov 2007
Lieu : Auvergne-Rhône-Alpe.
Membre no 99 922
maya.ahh
posté 7 Dec 2020, 23:39
Message #33
Membre no 213 020
Aucun problème matériel d’après le diagnostic… Super ! je suis bien avancé...
J’en ai trop marre, et en plus je n’ai plus vraiment confiance dans cet ordinateur super cher et presque neuf !
Ce message a été modifié par maya.ahh - 7 Dec 2020, 23:42.
jeanjd63
posté 8 Dec 2020, 00:02
Message #34
Membre no 99 922
Pleure pas.....
Et en plus laisse aux autres le plaisir d'essuyer les plâtres sur Big Sur. C'est Big, c'est Sur et c'est Bug. laugh.gif
maya.ahh
posté 10 Dec 2020, 10:52
Message #35
Membre no 213 020
En fait, mon système est très instable. Il fait des kernel panic quasi quotidiennement. J’attend qu’il réussisse à faire une sauvegarde TM neuve et complète, et je vais tout réinstaller, à zéro y compris formater le disque, j’ai fait l’erreur de le mettre sensible à la casse, et je pense que ça n’aide pas ! Je pense installer directement BigSur avec un support USB. Le moment venu, je ferai un nouveau fil.
Bonne journée
jeanjd63
posté 10 Dec 2020, 11:31
Message #36
Membre no 99 922
Citation (maya.ahh @ 10 Dec 2020, 10:52) *
Bonne journée
baron
posté 10 Dec 2020, 14:33
Message #37
Inscrit : 22 Jul 2004
Membre no 21 291
Il ne serait pas mauvais d'indiquer le modèle de ton Mac et sa version d'OS dans Mes contrôles > Modifier ma signature.
maya.ahh
posté 11 Dec 2020, 21:38
Message #38
Membre no 213 020
C’est parti.
1. J’ai démarré en Recovery > Utilitaire Sécurité au démarrage > sécurité «  normale » et autoriser boot USB
2. Reboot +alt > démarrage sur le volume flash usb de démarrage créé auparavant, avec BigSur
3. Utilitaire de disque, effacement complet du Groupe de Volume, reormaté en AFPS (ni chiffré ni sensible à la casse).
4. Lancement de l’installation (je suis toujours sur la clef usb)…
CONCLUSION : je retombe sur la même erreur !!!
Je crée un nouveau fil…
Ce message a été modifié par maya.ahh - 11 Dec 2020, 21:41.
Bege57
posté 12 Dec 2020, 07:32
Message #39
Inscrit : 14 Oct 2020
Lieu : Rouhling (57)
Membre no 212 596
Citation (maya.ahh @ 7 Dec 2020, 23:39) *
je n'ai pas lu tous les posts, mais quand je lis le tiens ici ça me fait penser à mes "mésaventures", et plus j'y repense et plus
je me dis que les problèmes sont apparus après la mise à jour vers Big Sur sad.gif
MacBook Pro 16. - Iphone 15 Pro - Apple Watch SE 2ème génération
Mon site perso sur les machines à vapeur de collection, moteurs à air chaud type Stirling, radios anciennes (TSF) restaurées et travail du bois (tournage), Bonsaïs et mes chats :)
https://www.blooo.fr/index/
jeanjd63
posté 12 Dec 2020, 07:43
Message #40
Membre no 99 922
Hello.
Tu soulèves peut être un loup.
Il y a une mise à jour firmware embarquée avec Big Sur.
À voir si rapport de cause à effet.
Par contre ton nouveau MBP devrait, en toute logique être livré avec BS.
Kovak
posté 15 Dec 2020, 10:55
Message #41
Inscrit : 14 Nov 2019
Membre no 209 377
Je suis sous Mojave et j'avais voulu supprimer l'apparition d'une fenêtre «Votre ordinateur a été redémarré en raison d'un problème.» à chaque démarrage du mac alors j'avais installé BigSur sur une partition d'un DDE/SSD.
Tout était mauve… les couleurs pourries. J'ai redémarré depuis mon disque interne (Mojave) et les couleurs étaient également pourries, à dominance mauve ohmy.gif. J'ai supprimé cette partition BigSur et reformaté ce DDE et reformaté également mon disque dur interne puis réinstallé Mojave.
Tout est redevenu OK, la fenêtre «Votre ordinateur a été redémarré en raison d'un problème.» a disparu mais je me garde bien de réinstaller ce BigSur. Sans doute prochainement Catalina…
2 Pages V  < 1 2
Nous sommes le : 5th May 2026 - 08:16
