2 Pages V  < 1 2
> Création de partitions impossible (Samsung SSD T5) *RESOLU*
jeanjd63
posté 19 Apr 2021, 05:56
Message #31
Inscrit : 15 Nov 2007
Lieu : Auvergne-Rhône-Alpe.
Membre no 99 922
Petites précisions sur les containers et volumes apfs.
il existe la possibilité, lors de la création d'un volume APFS de lui imposer :
-soit une limite maximale d'espace disque utilisable (cas d'une sauvegarde Time Machine) via le paramètre -quota lors de la création du volume.
-soit de lui réserver une taille minimale (toujours lors de la création du volume) via le paramètre -reserve.
-soit de combiner les deux.
Ceci est expliqué dans la doc diskutil :
Code
man diskutil
Citation
APFS Volumes have no specified "size" (capacity). Instead, all APFS Volumes consume capacity out of the remaining free space of their
parent APFS Container, consuming or returning such capacity as user file data is added or deleted. Note that this means that all Volumes
within a Container compete for the Container's remaining capacity. However, you can manage Volume allocation with the optional reserve
and quota
size values.
The optional reserve size requests an assured minimum capacity for an APFS Volume. If successfully created, the Volume is guaranteed to
be able to store at least this many bytes of user file data. Note that beyond this, the Volume might be able to store even more until
constrained by reaching zero free space in its parent Container or by reaching a quota, if any. You can use a reserve to prevent running
out of capacity due to competition from other Volumes or from a Container shrink attempt.
The optional quota size applies a maximum capacity to an APFS Volume, placing a limit on the number of bytes of user file data which can
be stored on the Volume. Note that you might not be able to reach this limit if its parent Container becomes full first. You can use a
quota to enforce accounting or to manage against "unfair" premature filling-up of the parent Container due solely to this Volume at the
expense of sibling Volumes.
Malheureusement ces paramètres ne sont pas pris en compte par la partition de Backup Time Machine si elle est créée via le menu Time Machine. Par contre, à la mimine et via le terminal cela semble accepté :
Code
diskutil ap addvolume disk6 apfsx Time_Machine_BS -quota 30g -role T
puis pour les données
Code
diskutil ap addvolume disk6 apfs Donnees -reserve 30g
Et les résultats de :
Code
diskutil ap list disk6
Citation
+-- Container disk6 8C53B410-FC36-4221-9F13-F528C24CA4EC
APFS Container Reference: disk6
Size (Capacity Ceiling): 80000000000 B (80.0 GB)
Capacity In Use By Volumes: 36526084096 B (36.5 GB) (45.7% used)
Capacity Not Allocated: 43473915904 B (43.5 GB) (54.3% free)
+-< Physical Store disk3s5 D6E20B9A-34FF-462E-8AEE-5648523C1E5D
| APFS Physical Store Disk: disk3s5
| Size: 80000000000 B (80.0 GB)
+-> Volume disk6s2 7922D046-226C-4AA6-B464-D164962AF6E3
| APFS Volume Disk (Role): disk6s2 (No specific role)
| Name: Donnees (Case-insensitive)
| Mount Point: /Volumes/Donnees
| Capacity Consumed: 30000001024 B (30.0 GB)
| Capacity Reserve: 30000001024 B (30.0 GB)
| Capacity Quota: None
| Sealed: No
| FileVault: No
+-> Volume disk6s1 87F67483-A828-4CAF-A419-75EBE2601F82
APFS Volume Disk (Role): disk6s1 (Backup)
Name: Time_Machine_BS (Case-sensitive)
Mount Point: /Volumes/Time_Machine_BS
Capacity Consumed: 6403264512 B (6.4 GB)
Capacity Reserve: None
Capacity Quota: 30000001024 B (30.0 GB) (21.3% reached)
Sealed: No
FileVault: No
Un autre gros avantage du container unique est de pouvoir supprimer/créer des volumes à l'intérieur sans perturber l'existant. Si l'on compare avec le découpage en "tables ou lits séparés" laugh.gif
on s'aperçoit facilement qu'il n'est pas besoin d'utiliser scie ou hache et colle pour reconstituer un espace à ses besoins.
Ne pas oublier que dans le cas des containers séparés, on retombe dans les joyeusetés des partitions avec tous les problèmes de récupération d'espace libre, précédent un container par exemple, qu'il est impossible de récupérer pour l'ajouter au container suivant, sinon à tout sauvegarder et restaurer.
Bien entendu, quand je parle de container unique, j'entends container de données.
Dans le cas du système ou d'un clone, là je conseille de ne pas y ajouter de volumes perso.
Edit.
J'ai fait qq essais de sauvegardes TM en ajoutant des installateurs Mac Os X, sauvegarder, puis supprimer et ajout d'autres jusqu'à voir si TM gérait bien la suppression des anciennes sauvegardes sur un volume limité par "quota" et ça fonctionne bien d'après mes essais. smile.gif
Ce message a été modifié par jeanjd63 - 19 Apr 2021, 19:56.
Neylats
posté 19 Apr 2021, 09:14
Message #32
Inscrit : 18 Apr 2021
Membre no 213 850
Merci pour tous ces details. Je comprends mieux l'avantage/inconvenient de l'apfs. Effectivement c'est pour une sauvegarde time machine et je n'aimerai pas qu'il m'empeche de mettre des donnees sur la partition dédiée.
Du coup j'aimerai faire deux parties une de 250go Apfs espace max dedie ou autre format pour Time machine et une de 750go en Apfs pour ensuite creer plusieurs parties dedans si j'ai bien tout compris.
D'ailleurs je suis étonné de ne pas pouvoir le faire directement depuis utilitaire de disque avec le SSD T5 samsung sad.gif Ne connaissant pas les commandes terminal c'est pas evident du coup.
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme 500.3 GB disk0
1: Apple_APFS_ISC ⁨⁩ 524.3 MB disk0s1
2: Apple_APFS ⁨Container disk3⁩ 494.4 GB disk0s2
3: Apple_APFS_Recovery ⁨⁩ 5.4 GB disk0s3
/dev/disk3 (synthesized):
0: APFS Container Scheme - +494.4 GB disk3
Physical Store disk0s2
1: APFS Volume ⁨Macintosh HD⁩ 15.1 GB disk3s1
2: APFS Snapshot ⁨com.apple.os.update-...⁩ 15.1 GB disk3s1s1
3: APFS Volume ⁨Preboot⁩ 428.6 MB disk3s2
4: APFS Volume ⁨Recovery⁩ 1.1 GB disk3s3
5: APFS Volume ⁨Data⁩ 104.8 GB disk3s5
6: APFS Volume ⁨VM⁩ 3.2 GB disk3s6
/dev/disk4 (external, physical):
0: FDisk_partition_scheme *1.0 TB disk4
1: Apple_HFS ⁨Jordane⁩ 1.0 TB disk4s1
Ce message a été modifié par Neylats - 19 Apr 2021, 09:22.
jeanjd63
posté 19 Apr 2021, 11:02
Message #33
Membre no 99 922
Donc tu tentes l'opération un container ou deux?
Quand tu dis "une de 750go en Apfs pour ensuite créer plusieurs parties dedans" tu penses à un container 750 Go dans lequel tu vas créer plusieurs volumes ou un volume de 750 Go dans lequel tu auras plusieurs répertoires?
Dans le premier cas on peut créer 2 containers : un de 250 Go pour le volume TM et un de 750 Go pour le reste.
Dans le second cas on peut créer un container avec 2 Volumes limités à 250 Go pour TM et 750 Go pour le reste.
Pour éviter l'usage du terminal, tu peux en effet passer par l'utilitaire de disques. Là il faut depuis le menu Présentation "Afficher tous les appareils", sélectionner le SSD externe "complet" puis "Effacer".
Attention l'utilitaire de disque ne donne pas toujours accès à toutes les options de la commande diskutil smile.gif que je préfère évidemment biggrin.gif
Par exemple, il sera impossible de créer un volume Time Machine avec quota par ce biais (ce que permet le terminal).
Ce message a été modifié par jeanjd63 - 19 Apr 2021, 11:17.
Neylats
posté 19 Apr 2021, 13:01
Message #34
Membre no 213 850
super merci pour la précision de "Présentation" ca me permet de faire plus comme j'avais l'habitude et sans passer par le Terminal smile.gif
Alors du coup j'ai opté pour un format APFS avec 2 conteneurs un pour time machine 300go et un pour les données 700go - du coup je pense que j'aurai 2 conteneurs avec cette manip avec lesquels je vais pouvoir ajouter des volumes dans le conteneur "donnees" format APFS. Ma question etant est ce que je peux creer un volume ExFat ( meme si a priori j'ai pas besoin de passer des données sur Pc ) pour permettre le transfert de données Mac/Pc ? ou est ce que c'est le conteneur qui doit etre ExFat ?
jeanjd63
posté 19 Apr 2021, 13:11
Message #35
Membre no 99 922
Par contre tu ne pourras pas créer un volume autre qu'APFS dans un container APFS.
Neylats
posté 19 Apr 2021, 13:15
Message #36
Membre no 213 850
Ok du coup c'est le conteneur lui meme que je devrais modifier en ExFat. Oui ca parait logique puisque c'est le conteneur qui fait le format.
Bien evidémment c'est pas fifou d'avoir un DD qui fasse Time Machine + données et que le mieux est d'avoir un DD qui fasse TM et un autre qui fasse données ( physique je parle ^^)
jeanjd63
posté 19 Apr 2021, 13:28
Message #37
Membre no 99 922
Dans ce cas il faut partager le disque en :
1) un container apfs
2) une partition "classique"
Perso je ne vois pas trop l'intérêt.
Dans le cas d'échange Windows Mac, mieux vaut privilégier une clé USB.
baron
posté 19 Apr 2021, 13:43
Message #38
Inscrit : 22 Jul 2004
Membre no 21 291
Citation (Neylats @ 19 Apr 2021, 14:15) *
Bien évidemment c'est pas fifou d'avoir un DD qui fasse Time Machine + données et que le mieux est d'avoir un DD qui fasse TM et un autre qui fasse données ( physique je parle ^^)
Bien sûr, d'autant que se pose aussi la question de la sauvegarde de ces données… sleep.gif
@jeanjd63 : merci beaucoup pour tes précisions sur ces options Quota et Reserve (et surtout d'avoir recopié le man auquel je n'avais pas accès, faute d'un système récent).
Nul doute que tu pourras en tirer profit pour aider l'un ou l'autre comme tu le fais si bien.
canaan
posté 15 Mar 2026, 23:23
Message #39
Inscrit : 3 Apr 2005
Lieu : paris 11
Membre no 36 455
Salut
Je relance ce post car je n'ai jamais été très à l'aise avec les commandes du terminal
Je souhaite partitionner un SSD externe Samsung T7 2To en deux partitions de 1To
Je précise que c'est uniquement pour des données réparties sur 2 disques durs distincts sur mon bon vieux MacPro 5.1 en vue d'une sauvegarde hors domicile.
Impossible avec l'utilitaire disque, ni via Carbon Copy Cloner que je compte utiliser (pas de Time Machine pour ça)
En l'état il est formaté en Mac OS étendu (journalisé), non sensible à la casse
Si quelqu'un peut me préciser la démarche / codes du terminal à rentrer
MacPro 5.1 2x 2.93 GHz 6 core (2010-2012) - Ram 52 Go - OS 10.13.6 - DD 2x 4To + DD 8To + SSD 2To + SSD 1To - ATI Radeon HD 5870
Macbook Pro M5 Pro 14" (2026) / CPU 15 cœurs / GPU 16 cœurs / 24Go mémoire unifiée / 1To ssd
Macbook Pro M1 Pro 14" (2021) / CPU 8 cœurs / GPU 14 cœurs / 16Go mémoire unifiée / 512 go ssd
Macbook Pro Retina 13" (early 2015) / 2.7 Ghz core i5 / Ram 8 Go / SSD 256Go / OS 10.15.7 [en sommeil...]
MacPro 3.1 2x 2.8 GHz (2008) - Ram 14 Go - OS 10.8.5 - DD 4x 2 To - Pioneer 117F un vieux graveur ide Samsung (pas glop) - ATI Radeon HD 5770 [en sommeil...]
jeandemi
posté 16 Mar 2026, 09:42
Message #40
Inscrit : 20 Aug 2020
Lieu : Belgique
Membre no 212 269
Pas besoin de commande terminal :
Dans l'utilitaire disques, tu fais "afficher tous les périphériques", puis tu sélectionne le T5 et tu le partitionne
Attention à bien être en type de partition GUID / GPT et pas MBR
canaan
posté 16 Mar 2026, 21:54
Message #41
Lieu : paris 11
Membre no 36 455
Bonjour jeandemi
Le problème c'est que l'option n'est pas valide dans l'utilitaire disque.
Je viens de re-re-vérifier : pour le SSD externe (Samsung T7 de 2To) les seules options sont "restaurer", "démonter", "sos" et "effacer"
à la différence des autres DD et SSD (internes) où "partitionner" et "convertir" sont également possibles.
J'ai essayé aussi via Carbon Copy Cloner : même punition wink.gif
C'est pour ça que je mentionnais les codes / terminal au vu de ce qui était dit plus haut dans ce post.
Cela dit, je viens de retrouver un autre SSD (WD MyPasseport) où la partition est possible !
Il est formaté NTFS, ceci explique sans doute cela ?
Mais il fait seulement 1To, trop petit pour être partitionner pour mes besoins.
Du coup, je me demandais si je devais reformater le Samsung (actuellement en MacOS) en Fat ou Ex-Fat pour pouvoir le partitionner ?
jeandemi
posté 16 Mar 2026, 23:11
Message #42
Lieu : Belgique
Membre no 212 269
Peut-être que s'il est déjà en GPT + APFS, il considère qu'il ne faut pas faire de partitions, mais des lecteurs dans le conteneur APFS.
Essaye de faire "effacer", éventuellement en ExFAT, de partitionner, puis de formater en HFS+
canaan
posté 17 Mar 2026, 00:31
Message #43
Lieu : paris 11
Membre no 36 455
ok, je vais effectivement reformater en Ex-Fat puis HFS+
je reviens aux nouvelles bientôt pour confirmer ou infirmer
merci
canaan
posté 17 Mar 2026, 17:38
Message #44
Lieu : paris 11
Membre no 36 455
re-bonjour jeandemi
je suis toujours bloqué sur cette histoire de partition
rien à faire même une fois reformaté en Ex-Fat (sans possibilité de basculer sur du HFS+)
par contre dans la présentation de l'utilitaire disque, si j'affiche "tous les appareils" (et pas seulement les "volumes")
apparaît aussi les 3 options pour le "schéma" : "table de partition GUID", "MBR" (en l'état actuel / par défaut ?), "table de partition Apple"
j'avoue que ça dépasse mes maigres connaissances, mais est-ce que la solution est là ?
merci
baron
posté 17 Mar 2026, 23:10
Message #45
Membre no 21 291
Une fois "Tous les appareils" affichés, tu sélectionnes le niveau hiérarchique supoérieur (l'appareil lui-même et non un de ses volumes) et tu choisis table de partition GUID (MBR, c'est pour les PC…).
canaan
posté 18 Mar 2026, 02:46
Message #46
Lieu : paris 11
Membre no 36 455
Re-Bonjour Baron
Merci bcp pour ces précisions, c'est nickel, j'étais vraiment bloqué sur cette manip.
Ca paraît évident après coup, j'ai presque honte... Quand je pense que je suis sur Mac depuis l'Apple IIe… wink.gif
Merci encore. A+
baron
posté 18 Mar 2026, 09:40
Message #47
Membre no 21 291
Quand on doit faire les choses pour soi-même, on est parfois pris de doutes qu'on pourrait croire irrationnels. On est heureux alors de trouver un peu d'assistance…
jeandemi
posté 18 Mar 2026, 18:08
Message #48
Lieu : Belgique
Membre no 212 269
Citation (jeandemi @ 16 Mar 2026, 09:42) *
Citation (canaan @ 17 Mar 2026, 17:38) *
re-bonjour jeandemi
merci
C'est ce que je t'avais noté au début...
canaan
posté 19 Mar 2026, 20:37
Message #49
Lieu : paris 11
Membre no 36 455
re-bonjour jeandemi
oui désolé, et je te re-remercie également pour tes infos,
mais j'étais resté perdu dans l'utilitaire disque (alors que c'était en évidence devant moi !), d'où ma relance wink.gif
2 Pages V  < 1 2
Nous sommes le : 14th May 2026 - 12:06
