El Capitan - disk1: alignment error, iMac 27" s'éteint aléatoirement |
12 Mar 2016, 21:15
Nouveau Membre Groupe : Membres Messages : 7 Inscrit : 12 Mar 2016 Membre no 198 332 |
bonjour,
mon iMac 27" mi-2010 depuis le passage sous El Capitan s'éteint aléatoirement sans raison apparente en consultant la console, j'ai relevé les messages juste avant l'extinction CODE 12/03/2016 18:23:41,642 launchservicesd[74]: SecTaskLoadEntitlements failed error=22 12/03/2016 18:23:41,000 kernel[0]: disk1: alignment error. 12/03/2016 18:23:41,000 kernel[0]: disk1: alignment error. 12/03/2016 18:23:41,948 mds[59]: (Volume.Normal:2464) volume:0x7ff99a810800 ********** Bootstrapped Creating a default store:1 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/1984-1989 12/03/2016 18:23:41,986 mds[59]: (Volume.Error:577) vsd:0x7ff99a87d000 Open failed. failureCount:0 (null) 12/03/2016 18:23:42,644 launchservicesd[74]: SecTaskLoadEntitlements failed error=22 12/03/2016 18:23:42,839 iconservicesagent[289]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7fbba35103f0>. 12/03/2016 18:23:42,839 quicklookd[511]: Error returned from iconservicesagent: (null) 12/03/2016 18:23:58,238 mds[59]: (Volume.Normal:166) vsd:0x7ff99a87d000 DisabledStore recycle:0 context:{ DisabledRecycleCount = 1; } 12/03/2016 18:23:58,269 mds[59]: (Volume.Error:577) vsd:0x7ff999158000 Open failed. failureCount:1 { DisabledRecycleCount = 1; } 12/03/2016 18:24:03,028 iconservicesagent[289]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7fbba3714f60>. 12/03/2016 18:24:03,029 quicklookd[511]: Error returned from iconservicesagent: (null) 12/03/2016 18:24:29,620 mds[59]: (Volume.Normal:166) vsd:0x7ff999158000 DisabledStore recycle:2 context:{ DisabledRecycleCount = 2; } 12/03/2016 18:24:29,650 mds[59]: (Volume.Error:577) vsd:0x7ff9990b8000 Open failed. failureCount:2 { DisabledRecycleCount = 2; } 12/03/2016 18:24:59,235 mdworker[537]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,236 mdworker[538]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,237 mdworker[539]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,240 mdworker[514]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,241 mdworker[516]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,243 mdworker[520]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,244 mdworker[521]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,246 mdworker[546]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:24:59,246 mdworker[557]: (ImportBailout.Error:1325) Asked to exit for Diskarb 12/03/2016 18:25:20,446 launchservicesd[74]: SecTaskLoadEntitlements failed error=22 12/03/2016 18:25:21,817 com.apple.xpc.launchd[1]: (com.apple.quicklook[573]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook 12/03/2016 18:25:21,966 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.quicklookd.573) Path not allowed in target domain: type = pid, path = /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app 12/03/2016 18:25:22,021 com.apple.SecurityServer[76]: Session 100030 created 12/03/2016 18:25:22,108 sandboxd[129]: ([574]) QuickLookSatelli(574) deny mach-lookup com.apple.DiskArbitration.diskarbitrationd 12/03/2016 18:25:22,294 com.apple.SecurityServer[76]: Killing auth hosts 12/03/2016 18:25:22,294 com.apple.SecurityServer[76]: Session 100027 destroyed 12/03/2016 18:25:23,457 QuickLookUIHelper[570]: [18:25:23.457] <<<< Boss >>>> figPlaybackBossPrerollCompleted: unexpected preroll-complete notification 12/03/2016 18:32:23,000 bootlog[0]: BOOT_TIME 1457803943 0 y'a notamment au début "kernel[0]: disk1: alignment error" qui ne me plaît pas en cherchant des infos sur cette erreur, je suis tombé sur une ligne de commande à lancer dans le terminal pour vérifier les disques "syslog -k Sender kernel -k Message RCeq 'corestorage|disk' -k Time ge -3d" résultat du terminal CODE iMac-de-NICOLAS:~ Nicolas$ syslog -k Sender kernel -k Message RCeq 'corestorage|disk' -k Time ge -3d Mar 9 20:12:01 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 41 times --- Mar 9 23:40:36 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 9 23:40:36 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 1 Mar 9 23:40:47 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 43036672 to: 43720704 (joffset 0x3a38000) Mar 9 23:40:48 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 9 23:40:52 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 9 23:40:52 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 545280 to: 1781760 (joffset 0x2e1000) Mar 9 23:40:53 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 9 23:40:54 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 9 23:42:26 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(289) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 10 07:33:35 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Recovery HD on device disk0s4 Mar 10 07:33:36 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Recovery HD on device disk0s4 Mar 10 14:39:52 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: coreduetd(67) deny(1) file-read-metadata /Applications/Utilities/Disk Utility.app --- last message repeated 4 times --- Mar 10 18:33:07 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 41 times --- Mar 10 22:32:48 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 10 22:32:48 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 1 Mar 10 22:32:57 localhost kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 10 22:32:59 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 49569792 to: 50405376 (joffset 0x3a38000) Mar 10 22:33:01 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 10 22:33:05 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 10 22:33:05 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 1781760 to: 2903552 (joffset 0x2e1000) Mar 10 22:33:06 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 10 22:33:07 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 10 22:37:03 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 9 times --- Mar 10 22:56:43 iMac-de-NICOLAS kernel[0] <Notice>: disk1s14s2: alignment error. Mar 10 22:56:54 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Opendisc on device disk1s14s2 Mar 10 22:56:59 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Opendisc on device disk1s14s2 Mar 10 22:56:59 iMac-de-NICOLAS kernel[0] <Notice>: disk1s14s2: alignment error. Mar 10 22:57:02 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Opendisc on device disk1s14s2 Mar 10 22:57:03 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 10 23:01:36 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Opendisc on device disk1s14s2 Mar 10 23:03:13 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 10 23:03:13 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 1 Mar 10 23:03:26 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 10 23:03:27 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 10 23:05:33 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 10 23:05:33 iMac-de-NICOLAS kernel[0] <Notice>: disk1s14s2: alignment error. Mar 10 23:06:13 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Opendisc on device disk1s14s2 Mar 10 23:11:10 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 3 times --- Mar 11 02:22:49 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Opendisc on device disk1s14s2 Mar 11 07:34:17 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 11 07:34:17 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 2 Mar 11 07:34:27 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 55214080 to: 55951360 (joffset 0x3a38000) Mar 11 07:34:27 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 11 07:34:31 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 11 07:34:31 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 645632 to: 1919488 (joffset 0x2e1000) Mar 11 07:34:33 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 11 07:34:34 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 11 07:34:54 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Recovery HD on device disk0s4 Mar 11 07:34:54 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Recovery HD on device disk0s4 Mar 11 09:51:25 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 115 times --- Mar 11 16:22:38 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 11 16:22:38 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 3 Mar 11 16:22:51 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 11 16:22:54 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 67682304 to: 68423680 (joffset 0x3a38000) Mar 11 16:22:56 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 11 16:22:59 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 11 16:22:59 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 1919488 to: 3040768 (joffset 0x2e1000) Mar 11 16:23:00 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 11 16:23:00 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 11 16:23:58 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(308) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 11 16:32:28 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 27 times --- Mar 11 19:19:59 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted ActiveTcl-8.6 on device disk2s2 Mar 11 19:20:40 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on ActiveTcl-8.6 on device disk2s2 Mar 11 19:23:13 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 3 times --- Mar 11 21:10:04 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 11 21:10:04 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 3 Mar 11 21:10:19 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 75042816 to: 75915264 (joffset 0x3a38000) Mar 11 21:10:20 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 11 21:10:24 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 11 21:10:24 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 3040768 to: 4174848 (joffset 0x2e1000) Mar 11 21:10:25 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 11 21:10:25 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 11 21:37:20 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 63 times --- Mar 12 10:35:46 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Recovery HD on device disk0s4 Mar 12 10:35:46 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Recovery HD on device disk0s4 Mar 12 10:39:04 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 15 times --- Mar 12 11:21:56 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 12 11:21:56 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 4 Mar 12 11:22:03 localhost kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 12 11:22:08 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 93208576 to: 93814784 (joffset 0x3a38000) Mar 12 11:22:09 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 12 11:22:14 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 11:22:14 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 7745024 to: 1625088 (joffset 0x2e1000) Mar 12 11:22:15 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 12 11:22:15 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 12 11:23:14 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(371) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 12 11:28:18 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 5 times --- Mar 12 11:52:19 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Musique HD on device disk0s2 Mar 12 11:52:29 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 11:52:30 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on Musique HD on device disk0s2 Mar 12 11:52:32 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 11:53:39 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on 100GO HD on device disk0s5 Mar 12 11:53:42 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 12 11:53:43 iMac-de-NICOLAS kernel[0] <Notice>: hfs: unmount initiated on 100GO HD on device disk0s5 Mar 12 11:53:44 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 12 12:14:21 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 7 times --- Mar 12 13:00:23 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(702) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 12 13:02:24 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 5 times --- Mar 12 13:04:10 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(735) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 12 13:17:35 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 12 13:49:47 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(770) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 12 13:51:18 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 5 times --- Mar 12 13:57:52 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: QuickLookSatelli(803) deny(1) mach-lookup com.apple.DiskArbitration.diskarbitrationd Mar 12 14:13:13 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 41 times --- Mar 12 17:41:28 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 12 17:41:28 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 3 Mar 12 17:41:33 localhost kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 12 17:41:38 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 109969408 to: 110485504 (joffset 0x3a38000) Mar 12 17:41:38 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 12 17:41:43 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 17:41:43 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 5315072 to: 6297088 (joffset 0x2e1000) Mar 12 17:41:43 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 12 17:41:44 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 12 17:59:50 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 5 times --- Mar 12 18:12:10 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: coreduetd(67) deny(1) file-read-metadata /Applications/Utilities/Disk Utility.app --- last message repeated 4 times --- Mar 12 18:23:41 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 12 18:32:51 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 12 18:32:51 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 3 Mar 12 18:32:55 localhost kernel[0] <Notice>: disk1: alignment error. --- last message repeated 1 time --- Mar 12 18:33:04 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 113913856 to: 114614272 (joffset 0x3a38000) Mar 12 18:33:05 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 12 18:33:09 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 18:33:10 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 6297088 to: 8342528 (joffset 0x2e1000) Mar 12 18:33:11 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 12 18:33:11 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 12 18:34:44 iMac-de-NICOLAS kernel[0] <Notice>: Sandbox: coreduetd(67) deny(1) file-read-metadata /Applications/Utilities/Disk Utility.app --- last message repeated 4 times --- Mar 12 18:35:43 iMac-de-NICOLAS kernel[0] <Notice>: disk1: alignment error. --- last message repeated 5 times --- Mar 12 19:59:00 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 12 19:59:00 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 3 Mar 12 19:59:16 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 19:59:16 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 Mar 12 20:03:22 localhost kernel[0] <Notice>: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/HD2@3 Mar 12 20:03:22 localhost kernel[0] <Notice>: BSD root: disk0s3, major 1, minor 2 Mar 12 20:03:31 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: replay_journal: from: 118755328 to: 119070720 (joffset 0x3a38000) Mar 12 20:03:32 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s2: journal replay done. Mar 12 20:03:36 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted Musique HD on device disk0s2 Mar 12 20:03:36 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: replay_journal: from: 2880512 to: 3456000 (joffset 0x2e1000) Mar 12 20:03:37 iMac-de-NICOLAS kernel[0] <Notice>: jnl: disk0s5: journal replay done. Mar 12 20:03:38 iMac-de-NICOLAS kernel[0] <Notice>: hfs: mounted 100GO HD on device disk0s5 avec l'utilitaire de disques j'ai lancé la réparation de tous les disques visibles dans la colonne à gauche, aucune anomalie trouvée j'ai redémarré le mac avec cmd + R, lancé utilitaire de disque et de nouveau réparé tout le monde y compris le disk1 accessible uniquement en mode recovery, rien à signaler de plus le mac est passé y'a une quinzaine au genius bar pour nettoyage et dépoussiérage (pour info, même 5 ans après et donc hors garantie c'est gratuit), ils ont vérifié l'iMac de A à Z et n'ont trouvé aucune anomalie j'ai aussi réinstallé El Capitan avec formatage du disque avant installation, nada l'iMac continue à s'éteindre aléatoirement merci de votre aide car je reste dubitatif |
13 Mar 2016, 12:02
Macbidouilleur d'Or ! Groupe : Membres Messages : 3 810 Inscrit : 20 Nov 2001 Lieu : vitry sur seine (94) Membre no 1 346 |
essaye en désactivant totalement spotlight (mds dans la log)
met tous les disques en exception. c'est quoi ton disque exactement ? tu as plusieurs partitions ? Code sudo Diskutil list
-------------------- macpro 2008 quad core +8Go +
Desktop - CPU : AMD Ryzen 3600XT@4,6Ghz - RAM 16 Go - CM: Gygabyte X570-Aorus Pro CG : GeForce GTX 970- Audio: AMD Starship/Matisse HD Manjaro 23.1 xfce (testing) |
13 Mar 2016, 23:31
j'ai désactivé spotlight sur les 3 partitions de mon disque interne
je n'ai pas désactivé totalement spotlight avec le terminal mon disque est un Hitachi HDS722020ALA330 2To avec 3 partition HFS+ journalisé résultat de Diskutil CODE iMac-de-NICOLAS:~ Nicolas$ sudo Diskutil list /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *2.0 TB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS Musique HD 1.5 TB disk0s2 3: Apple_HFS OS X EL CAPITAN HD 399.5 GB disk0s3 4: Apple_Boot Recovery HD 650.0 MB disk0s4 5: Apple_HFS 100GO HD 98.6 GB disk0s5 /dev/disk1 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: CD_partition_scheme Boheme *452.4 MB disk1 1: CD_DA 19.1 MB disk1s1 2: CD_DA 55.9 MB disk1s2 3: CD_DA 44.6 MB disk1s3 4: CD_DA 49.3 MB disk1s4 5: CD_DA 33.5 MB disk1s5 6: CD_DA 33.2 MB disk1s6 7: CD_DA 13.2 MB disk1s7 8: CD_DA 35.3 MB disk1s8 9: CD_DA 43.6 MB disk1s9 10: CD_DA 45.5 MB disk1s10 11: CD_DA 30.5 MB disk1s11 12: CD_DA 48.8 MB disk1s12 iMac-de-NICOLAS:~ Nicolas$ |
15 Mar 2016, 22:18
salut,
l'iMac s'est de nouveau éteint brusquement sans volonté de ma part, il n'y avait personne devant les messages de la console juste avant la coupure brutale CODE 15/03/2016 20:40:30,734 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x594 15/03/2016 20:40:32,921 Safari[2103]: tcp_connection_tls_session_error_callback_imp 132 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 15/03/2016 20:41:01,031 Safari[2103]: tcp_connection_destination_handle_tls_close_notify 126 closing socket due to TLS CLOSE_NOTIFY alert 15/03/2016 20:41:01,032 Safari[2103]: tcp_connection_destination_handle_tls_close_notify 129 closing socket due to TLS CLOSE_NOTIFY alert 15/03/2016 20:41:01,032 Safari[2103]: tcp_connection_tls_session_error_callback_imp 129 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 15/03/2016 20:41:17,768 WindowServer[152]: Surface testing disallowed updates for 10 sequential attempts... 15/03/2016 20:41:17,782 WindowServer[152]: Surface test allowed updates after 12 attempts (48 ms) 15/03/2016 20:41:23,958 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x594 15/03/2016 20:41:25,339 Safari[2103]: tcp_connection_tls_session_error_callback_imp 139 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 15/03/2016 20:41:30,048 XLD[2160]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces. 15/03/2016 20:41:31,581 iconservicesagent[281]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7f8d90d16ba0>. 15/03/2016 20:41:31,582 quicklookd[2443]: Error returned from iconservicesagent: (null) 15/03/2016 20:41:33,774 iconservicesagent[281]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7f8d90c09fb0>. 15/03/2016 20:41:33,774 quicklookd[2443]: Error returned from iconservicesagent: (null) 15/03/2016 20:41:35,536 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:41:48,369 Safari[2103]: tcp_connection_destination_handle_tls_close_notify 136 closing socket due to TLS CLOSE_NOTIFY alert 15/03/2016 20:41:48,369 Safari[2103]: tcp_connection_tls_session_error_callback_imp 136 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 15/03/2016 20:41:48,933 Safari[2103]: tcp_connection_destination_handle_tls_close_notify 138 closing socket due to TLS CLOSE_NOTIFY alert 15/03/2016 20:41:48,933 Safari[2103]: tcp_connection_tls_session_error_callback_imp 138 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 15/03/2016 20:41:53,283 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:06,145 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:11,557 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:17,470 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:18,154 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:19,304 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:30,947 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:35,951 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:40,521 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:42:46,000 syslogd[42]: ASL Sender Statistics 15/03/2016 20:42:46,004 com.apple.cts[240]: com.apple.suggestd.persist-stats: scheduler_evaluate_activity told me to run this job; however, but the start time isn't for 600 seconds. Ignoring. 15/03/2016 20:42:46,133 com.apple.cts[240]: com.apple.suggestd.persist-stats: scheduler_evaluate_activity told me to run this job; however, but the start time isn't for 600 seconds. Ignoring. 15/03/2016 20:43:43,097 XLD[2160]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces. 15/03/2016 20:43:46,298 QuickLookSatellite[2444]: [20:43:46.298] MoovParseByteStream signalled err=-12848 (kFigFormatReaderError_ParsingFailure) (moov atom could not be parsed) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.33/Prototypes/FormatHandlers/Movie/MovieAtomParsing.c line 4746 15/03/2016 20:43:46,298 QuickLookSatellite[2444]: [20:43:46.298] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/Nicolas/Desktop/XLD%20Rip%20CD/03%20Florent%20Pagny%20-%20Y'a%20pas%20un%20homme%20qui%20soit%20ne%CC%81%20pour%20c%CC%A7a.m4a FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12848 15/03/2016 20:43:46,298 QuickLookSatellite[2444]: [20:43:46.298] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12848 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.33/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 15/03/2016 20:43:46,302 iconservicesagent[281]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7f8d90e0f250>. 15/03/2016 20:43:46,302 quicklookd[2443]: Error returned from iconservicesagent: (null) 15/03/2016 20:46:03,002 com.apple.cts[240]: com.apple.suggestd.persist-stats: scheduler_evaluate_activity told me to run this job; however, but the start time isn't for 403 seconds. Ignoring. 15/03/2016 20:46:28,621 XLD[2160]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces. 15/03/2016 20:46:29,782 iconservicesagent[281]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7f8d90e19da0>. 15/03/2016 20:46:29,782 quicklookd[2443]: Error returned from iconservicesagent: (null) 15/03/2016 20:46:52,799 sandboxd[129]: ([286]) storeaccountd(286) deny file-write-create /Users/Nicolas/Library/Caches/com.apple.spotlight 15/03/2016 20:46:52,804 sandboxd[129]: ([286]) storeaccountd(286) deny file-write-create /Users/Nicolas/Library/Caches/com.apple.spotlight 15/03/2016 20:47:06,690 sandboxd[129]: ([286]) storeaccountd(286) deny file-write-create /Users/Nicolas/Library/Caches/com.apple.Safari/ProductionBag 15/03/2016 20:47:38,436 Safari[2103]: tcp_connection_tls_session_error_callback_imp 140 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 15/03/2016 20:47:39,665 WindowServer[152]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x7fe3a990bc00(2001) 15/03/2016 20:47:39,772 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: notification observer: com.apple.iChat notification: __CFNotification 0x7fdc436502d0 {name = _NSDoNotDisturbEnabledNotification} 15/03/2016 20:47:39,774 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: notification observer: com.apple.FaceTime notification: __CFNotification 0x7fcd0340de70 {name = _NSDoNotDisturbEnabledNotification} 15/03/2016 20:47:39,799 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: NC Disabled: NO 15/03/2016 20:47:39,799 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: NC Disabled: NO 15/03/2016 20:47:39,812 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: DND Enabled: YES 15/03/2016 20:47:39,812 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: DND Enabled: YES 15/03/2016 20:47:39,812 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: Updating enabled: NO (Topics: ( )) 15/03/2016 20:47:39,812 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: Updating enabled: NO (Topics: ( )) 15/03/2016 20:47:39,851 WindowServer[152]: device_generate_lock_screen_screenshot: authw 0x0(0)[inf, inf, 0, 0] shield 0x7fe3a990bc00(2001), dev [2560,1440] 15/03/2016 20:47:44,930 XLD[2160]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces. 15/03/2016 20:47:46,147 WindowServer[152]: CGXDisplayDidWakeNotification [108204161432648]: posting kCGSDisplayDidWake 15/03/2016 20:47:46,147 WindowServer[152]: handle_will_sleep_auth_and_shield_windows: Deferring. 15/03/2016 20:47:46,265 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: notification observer: com.apple.iChat notification: __CFNotification 0x7fdc4364b120 {name = _NSDoNotDisturbDisabledNotification} 15/03/2016 20:47:46,266 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: notification observer: com.apple.FaceTime notification: __CFNotification 0x7fcd03637f00 {name = _NSDoNotDisturbDisabledNotification} 15/03/2016 20:47:46,287 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: NC Disabled: NO 15/03/2016 20:47:46,287 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: NC Disabled: NO 15/03/2016 20:47:46,297 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: DND Enabled: NO 15/03/2016 20:47:46,297 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: DND Enabled: NO 15/03/2016 20:47:46,297 imagent[305]: <IMMacNotificationCenterManager: 0x7fcd03720ab0>: Updating enabled: YES (Topics: ( "com.apple.ess", "com.apple.private.ac" )) 15/03/2016 20:47:46,297 identityservicesd[295]: <IMMacNotificationCenterManager: 0x7fdc4340a300>: Updating enabled: YES (Topics: ( "com.apple.private.alloy.icloudpairing", "com.apple.private.alloy.continuity.encryption", "com.apple.private.alloy.continuity.activity", "com.apple.ess", "com.apple.private.ids", "com.apple.private.alloy.phonecontinuity", "com.apple.madrid", "com.apple.private.ac", "com.apple.private.alloy.phone.auth", "com.apple.private.alloy.keychainsync", "com.apple.private.alloy.fmf", "com.apple.private.alloy.sms", "com.apple.private.alloy.screensharing", "com.apple.private.alloy.maps", "com.apple.private.alloy.thumper.keys", "com.apple.private.alloy.continuity.tethering" )) 15/03/2016 20:47:46,925 QuickLookSatellite[2444]: [20:47:46.925] MoovParseByteStream signalled err=-12848 (kFigFormatReaderError_ParsingFailure) (moov atom could not be parsed) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.33/Prototypes/FormatHandlers/Movie/MovieAtomParsing.c line 4746 15/03/2016 20:47:46,925 QuickLookSatellite[2444]: [20:47:46.925] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/Nicolas/Desktop/XLD%20Rip%20CD/04%20Florent%20Pagny%20-%20Un%20mot%20de%20Pre%CC%81vert.m4a FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12848 15/03/2016 20:47:46,925 QuickLookSatellite[2444]: [20:47:46.925] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12848 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.33/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 15/03/2016 20:47:46,929 iconservicesagent[281]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7f8d90d16ba0>. 15/03/2016 20:47:46,929 quicklookd[2443]: Error returned from iconservicesagent: (null) 15/03/2016 20:47:51,188 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:48:31,237 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 15/03/2016 20:48:50,386 WindowServer[152]: _CGXRemoveWindowFromWindowMovementGroup: window 0x593 is not attached to window 0x595 merci d'avance |
18 Mar 2016, 21:26
bon , a mon avis retour au genius bar avec un AUTRE intervenant
verification Carte mere & Alim & video je doute que cela soit les DD ou un des DD as tu un moyen de superviser les temperatures ( cpu , DD , video , Ram , etc ) cela se coupe t-il au debut ou après plusieurs heures ? as tu activé l'hibernation ? as tu du wifi ? bluetooth ? -------------------- macpro 2008 quad core +8Go +
19 Mar 2016, 21:00
bon après surveillance et vérification à chaque plantage de la console, des dernières actions faites, je soupçonne ... Safari
Safari livré avec El Capitan aurait pas mal de problèmes CODE 19/03/2016 18:41:38,646 com.apple.xpc.launchd[1]: (com.apple.WebKit.Networking.32AAC3EC-C2A1-48BC-85DF-E5FCF81C6559[444]) Service exited with abnormal code: 1 19/03/2016 18:41:47,758 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x28 19/03/2016 18:41:51,409 Safari[247]: tcp_connection_tls_session_error_callback_imp 54 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 19/03/2016 18:42:02,567 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:42:03,753 Safari[247]: tcp_connection_destination_handle_tls_close_notify 50 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:03,753 Safari[247]: tcp_connection_destination_handle_tls_close_notify 51 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:03,754 Safari[247]: tcp_connection_tls_session_error_callback_imp 51 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:42:03,754 Safari[247]: tcp_connection_destination_handle_tls_close_notify 49 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:03,754 Safari[247]: tcp_connection_tls_session_error_callback_imp 49 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:42:07,938 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:42:10,347 iTunes[449]: ApplePushService: APSConnection being used without a delegate queue 19/03/2016 18:42:16,749 apsd[74]: MessageTracer: load_domain_prefix_whitelist:120: Missing default whitelist file: /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Resources/SubmitDiagInfo.default.domains 19/03/2016 18:42:43,342 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x28 19/03/2016 18:42:45,334 Safari[247]: tcp_connection_tls_session_error_callback_imp 61 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 19/03/2016 18:42:53,528 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:42:59,729 Safari[247]: tcp_connection_destination_handle_tls_close_notify 59 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:59,729 Safari[247]: tcp_connection_destination_handle_tls_close_notify 57 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:59,730 Safari[247]: tcp_connection_tls_session_error_callback_imp 59 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:42:59,730 Safari[247]: tcp_connection_tls_session_error_callback_imp 57 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:42:59,745 Safari[247]: tcp_connection_destination_handle_tls_close_notify 58 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:59,760 Safari[247]: tcp_connection_destination_handle_tls_close_notify 60 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:42:59,760 Safari[247]: tcp_connection_tls_session_error_callback_imp 60 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:43:12,919 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:43:38,082 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:43:38,958 WindowServer[155]: CoreAnimation: context hosting changed while locked! 19/03/2016 18:43:39,416 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:43:42,019 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:43:42,726 Safari[247]: tcp_connection_destination_handle_tls_close_notify 65 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:43:42,745 Safari[247]: tcp_connection_destination_handle_tls_close_notify 62 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:43:42,757 Safari[247]: tcp_connection_destination_handle_tls_close_notify 64 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:43:42,757 Safari[247]: tcp_connection_tls_session_error_callback_imp 64 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:44:08,191 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:13,453 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:15,330 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:22,987 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:26,356 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:35,174 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x28 19/03/2016 18:44:36,938 Safari[247]: tcp_connection_tls_session_error_callback_imp 68 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 19/03/2016 18:44:37,432 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:40,185 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:44:50,627 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:45:40,403 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:45:46,041 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:46:28,594 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:46:42,069 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x28 19/03/2016 18:46:43,757 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:46:43,801 Safari[247]: tcp_connection_tls_session_error_callback_imp 75 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 19/03/2016 18:46:59,703 Safari[247]: tcp_connection_destination_handle_tls_close_notify 72 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:46:59,713 Safari[247]: tcp_connection_destination_handle_tls_close_notify 73 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:46:59,713 Safari[247]: tcp_connection_tls_session_error_callback_imp 73 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:46:59,728 Safari[247]: tcp_connection_destination_handle_tls_close_notify 74 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:47:40,004 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:47:57,553 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:48:01,923 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:48:53,134 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:49:03,259 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:49:39,106 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:49:42,660 com.apple.WebKit.Plugin.64[454]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable 19/03/2016 18:49:42,660 com.apple.WebKit.Plugin.64[454]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable 19/03/2016 18:49:48,170 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x28 19/03/2016 18:49:49,811 Safari[247]: tcp_connection_tls_session_error_callback_imp 82 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22 19/03/2016 18:49:50,333 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:49:58,689 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:50:01,058 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:50:15,603 Safari[247]: tcp_connection_destination_handle_tls_close_notify 81 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:50:15,603 Safari[247]: tcp_connection_tls_session_error_callback_imp 81 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:50:15,627 Safari[247]: tcp_connection_destination_handle_tls_close_notify 80 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:50:15,627 Safari[247]: tcp_connection_tls_session_error_callback_imp 80 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:50:15,772 Safari[247]: tcp_connection_destination_handle_tls_close_notify 78 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:50:15,772 Safari[247]: tcp_connection_tls_session_error_callback_imp 78 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32 19/03/2016 18:50:17,343 Safari[247]: tcp_connection_destination_handle_tls_close_notify 76 closing socket due to TLS CLOSE_NOTIFY alert 19/03/2016 18:50:24,829 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:50:27,431 WindowServer[155]: _CGXRemoveWindowFromWindowMovementGroup: window 0x12 is not attached to window 0x24 19/03/2016 18:50:27,000 syslogd[43]: ASL Sender Statistics en recherchant avec "tcp_connection_tls_session_error_callback_imp 81 __tcp_connection_tls_session_callback_write_block_invoke.434 error 32", j'ai vu que ce problème était bien connu sans trouver de solution donc j'ai décidé de ne plus utiliser Safari mais Firefox à la place et par défaut donc je vous dirais s'il y a du mieux, en tout cas la console s'est bien calmée depuis |
27 Mar 2016, 19:30
salut,
je crois avoir enfin trouvé la source des extinctions sans raison et répétées de mon iMac le problème est avec iconservicesagent, avec certains fichiers, surtout ceux issus du monde windows, il n'arrive pas à dessiner l'icône et affiche l'icône générique et l'iMac plante et s'éteint CODE 27/03/2016 19:13:00,445 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b4141e0>. 27/03/2016 19:13:00,445 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:13:00,452 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b707ec0>. 27/03/2016 19:13:00,452 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:13:01,480 QuickLookUIHelper[412]: HWJPEG not avaialble on this platform 27/03/2016 19:14:08,825 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b6184e0>. 27/03/2016 19:14:08,825 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:08,843 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b503cb0>. 27/03/2016 19:14:08,843 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:08,867 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b5040f0>. 27/03/2016 19:14:08,867 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:08,894 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b412840>. 27/03/2016 19:14:08,894 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:08,905 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b618060>. 27/03/2016 19:14:08,906 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:08,932 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b707cd0>. 27/03/2016 19:14:08,932 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,042 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b617be0>. 27/03/2016 19:14:09,042 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,057 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b412c00>. 27/03/2016 19:14:09,057 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,080 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b618060>. 27/03/2016 19:14:09,080 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,101 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b503cb0>. 27/03/2016 19:14:09,101 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,125 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b412760>. 27/03/2016 19:14:09,125 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,155 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b5045a0>. 27/03/2016 19:14:09,155 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,175 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b708250>. 27/03/2016 19:14:09,175 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,193 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b412c00>. 27/03/2016 19:14:09,193 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,212 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b4143b0>. 27/03/2016 19:14:09,212 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,233 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b617cc0>. 27/03/2016 19:14:09,233 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,248 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b618660>. 27/03/2016 19:14:09,249 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:14:09,266 iconservicesagent[276]: -[ISGenerateImageOp generateImageWithCompletion:] Failed to composit image for descriptor <ISBindingImageDescriptor: 0x7ff40b5040f0>. 27/03/2016 19:14:09,266 quicklookd[278]: Error returned from iconservicesagent: (null) 27/03/2016 19:15:03,000 bootlog[0]: BOOT_TIME 1459098903 0 27/03/2016 19:15:31,000 syslogd[43]: Configuration Notice: ASL Module "com.apple.AccountPolicyHelper" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. 27/03/2016 19:15:31,000 syslogd[43]: Configuration Notice: ASL Module "com.apple.Accounts" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. et j'ai aussi un souci avec les jpeg de grande taille CODE 27/03/2016 19:13:01,480 QuickLookUIHelper[412]: HWJPEG not avaialble on this platform pourtant ce dysfonctionnement est normalement réglé depuis Yosémite maintenant que le problème est isolé, je n'ai plus qu'à essayer de trouver une solution ou de tenter la dernière màj des fois que bonne soirée à tous |
Nous sommes le : 3rd June 2024 - 19:48 |
