Firefox 32.0.x..., ...met un temps fou à quitter!!! |
1 May 2016, 21:02
Macbidouilleur d'Or ! Groupe : Membres Messages : 7 382 Inscrit : 1 Apr 2004 Lieu : 74 Membre no 17 041 |
Nouveau crash, comme il se doit, il y a deux minutes. Contenu de la console (c'est du chinois pour moi):
CODE 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x1001110e0 of class NSCFString autoreleased with no pool in place - just leaking
01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.868 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x1001110e0 of class NSCFString autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x100111570 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.973 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x100111570 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x1001115d0 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.973 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x1001115d0 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x100115120 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.974 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x100115120 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x1001151d0 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.974 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x1001151d0 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x100115270 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.975 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x100115270 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x100115930 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.975 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x100115930 of class NSPathStore2 autoreleased with no pool in place - just leaking 01/05/16 21:59:38 crashreporter[19311] *** __NSAutoreleaseNoPool(): Object 0x100115a00 of class NSCFData autoreleased with no pool in place - just leaking 01/05/16 21:59:38 [0x0-0x5c45c4].org.mozilla.firefox[16439] 2016-05-01 21:59:38.976 crashreporter[19311:903] *** __NSAutoreleaseNoPool(): Object 0x100115a00 of class NSCFData autoreleased with no pool in place - just leaking 01/05/16 21:59:39 com.apple.launchd.peruser.502[124] ([0x0-0x5c45c4].org.mozilla.firefox[16439]) Exited with exit code: 1 01/05/16 21:59:41 crashreporter[19311] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find: /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper Ce message a été modifié par baron - 1 May 2016, 21:56.
Raison de l'édition : Inséré CodeBox
-------------------- Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 et El Capitan - CS2.3 - LiveBox Sagem • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.6.8 | Photo: Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
2 May 2016, 09:33
Macbidouilleur d'Or ! Groupe : Membres Messages : 10 122 Inscrit : 28 Aug 2004 Lieu : Villers-La-Ville (Belgique) Membre no 22 631 |
Divers sites signalent des problèmes de mémoires insuffisantes mais également avec d'autres applications que Firefox.
Pas très clair pour une solution. Il semble également que Adblock ou tout autre plugin puisse être responsable. Cela n'apporte pas de solution hélas. On revient au problème qu'il faut tester sans aucun plugin ni toolbar et ce dans un autre compte utilsateur. Peux pas t'aider, désolé. -------------------- IMac 27 - 3.4 GHz - Mémoire 16 GB - Fusion + 2 thunderbold 3 To + 1 USB 1 To - OsX 10.12.6
* HP OfficeJet Pro 9012 - Airport extrème - iPhone 5 - IOS 10.3.4 - iPhone 5s - IOS 12.5.5 - Apple TV Système 8.4.2 - Logiciel 7.2.2 - iPad Air 2 - iPadOS 15.4.0 |
2 May 2016, 09:46
Divers sites signalent des problèmes de mémoires insuffisantes mais également avec d'autres applications que Firefox. Pas très clair pour une solution. Il semble également que Adblock ou tout autre plugin puisse être responsable. Cela n'apporte pas de solution hélas. On revient au problème qu'il faut tester sans aucun plugin ni toolbar et ce dans un autre compte utilsateur. Peux pas t'aider, désolé. Merci, tu as déjà bien assez fait. J'ai déjà testé sans plugin, mais pas encore sous un autre utilisateur. J'ai refait un test hier soir, en vidant l'historique (donc le cache aussi) avant de quitter. Ça a mis au moins 3 bonnes minutes, avec la roue multicolore, avant finalement de crasher royalement. Je pourrais m'en foutre et me dire que je n'ai qu'à forcer à quitter, ça irait en tout cas plus vite que d'attendre le crash. Mais ce qui est chiant, c'est qu'au fil des heures, la mémoire vive utilisée augmente jusqu'à ne plus laisser de libre qu'une trentaine de mégas, et ça me ralentit tout le reste. Vider le cache ne rend pas la mémoire, ce qui est aussi un comble. Bref, va falloir vivre avec ce problème, mais il y a bien pire. Bonne journée! Ah, et merci à Baron d'avoir mis mon charabia en mode Code... Ce message a été modifié par castor74 - 2 May 2016, 09:50. -------------------- Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 et El Capitan - CS2.3 - LiveBox Sagem • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.6.8 | Photo: Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
6 Feb 2017, 16:15
Bonjour, je reviens sur ce sujet, après avoir testé sous un autre utilisateur. Je trouve que Firefox met quand même du temps à quitter, mais ne plante apparemment plus. J'ai donc copié le dossier Firefox (User > Bibliothèque > Application Support) que j'ai mis à la place de celui de mon compte principal. Firefox ne plante plus, mais met toujours un temps anormal pour quitter. Sauf que j'ai essayé un truc: si je ne coche pas Vider le Cache dans Vider l'historique de Firefox à la fermeture, ça quitte – lentement – sans planter. Par contre, si je coche Vider le cache (en plus de Vider l'historique), là ça met un temps fou à quitter et ça finit, 9 fois sur 10, par planter. J'en conclus donc que Vider le cache prend un temps si long que ça finit par faire crasher Firefox. Mais pourquoi donc???
6 Feb 2017, 16:44
Toujours pour la version 32.0.x ? Pour le reste pas de problème chez moi avec la version 51.0.1. Il m'arrive aussi de temps en temps de faire un petit nettoyage avec cette option dans le menu : [attachment=54544:z__2017_...16.36.35.png] Pour le reste voici les paramètres : Vie privée et vider l'historique lors de la fermeture (détails ci-après). [attachment=54543:z__2017_...16.31.20.png] Si cela peu aider. -------------------- IMac 27 - 3.4 GHz - Mémoire 16 GB - Fusion + 2 thunderbold 3 To + 1 USB 1 To - OsX 10.12.6
6 Feb 2017, 16:59
#36
Merci, toujours là pour aider!
J'en suis à la dernière version pour Snow Leopard, soit la 48.0.2. Mêmes soucis qu'avec la 38.x. Je ne coche pas Supprimer les cookies, ni, désormais, Vider le cache. Donc, ça quitte bien, lentement, apparemment sans planter. Si je coche Vider le cache, ça prend 2 minutes minimum avant finalement de crasher... Et ça, sur un compte principal ET sur un autre compte... Dernière précision, mais je crois l'avoir déjà dit: si je supprime toutes les extensions et les plug-ins tiers, c'est pareil !!! -------------------- Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 et El Capitan - CS2.3 - LiveBox Sagem • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.6.8 | Photo: Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
6 Feb 2017, 17:01
#37
Macbidouilleur d'Or ! Groupe : Membres Messages : 7 398 Inscrit : 8 Feb 2005 Lieu : Lutécien n'étant rien et sans dents Membre no 32 633 |
Même chose chez moi 10.6 et 48.0.02 je suis obligé de forcer à quitter
-------------------- signature éditée car non conforme aux recommandations après plus de 6 ans d'utilisation il était effectivement temps…
6 Feb 2017, 17:39
#38
Même chose chez moi 10.6 et 48.0.02 je suis obligé de forcer à quitter Ah ben tiens... Je n'irai pas jusqu'à dire que ça me fait plaisir, mais au moins je ne suis pas seul... Essaie donc en décochant «Vider le cache», pour voir... -------------------- Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 et El Capitan - CS2.3 - LiveBox Sagem • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.6.8 | Photo: Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
6 Feb 2017, 19:41
#39
Cela ne freeze pas en décochant… (au passage je découvre intel et le 10.6.8 pour le moment… )
7 Feb 2017, 07:51
#40
Cela ne freeze pas en décochant… (au passage je découvre intel et le 10.6.8 pour le moment… ) Voilà. J'ai fait le même constat. Si on vide le cache en quittant, ça plante... Il y a donc bien un bug, là-dessous!!! -------------------- Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 et El Capitan - CS2.3 - LiveBox Sagem • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.6.8 | Photo: Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
25 Feb 2017, 18:33
#41
Je remonte le sujet pour faire un constat. Depuis plusieurs jours (voire plusieurs semaines) Firefox ne plante plus en quittant, parce que dans les paramètres d'effacement de l'historique, la case Cache n'est pas cochée. Le navigateur quitte donc sans planter, même s'il met parfois 10 ou 20 secondes pour quitter. Si je coche la case Cache, ça plante quasiment 9 fois sur 10. Quelqu'un a-t-il une idée ce que peut bien se passer avec ce foutu vidage de cache???
2 Sep 2017, 08:55
#42
Je remonte ce sujet pour savoir si d'autres que moi ont le même souci. Toujours plantage quand je vide le cache et que je quitte, mais pas si je laisse le cache plein.
11 Mar 2018, 19:25
#43
Macbidouilleur de vermeil ! Groupe : Membres Messages : 1 062 Inscrit : 14 Jun 2005 Lieu : Saintes (17) Membre no 40 909 |
Je n'ai pas tout lu, mais les derniers messages correspondent en partie à ce qui m'arrive.
De temps en temps, Firefox quitte sans moufter. Mais souvent il met un temps fou à quitter, si bien que je dois le forcer. J'ai remarqué que quand l'imprimante est restée allumée, ça met plus de temps. Mais aussi parfois quand ce sont des traitements de texte… Et quelquefois, je quitte sans problème, et je reçois un message comme quoi Firefox a planté !!! C'est d'une grande fantaisie. A noter que ma version est la 48.0.2 Eh oui, on fait pas toujours ce qu'on veut… J'ai aussi parfois beaucoup de mal à vider le cache (j'ai augmenté la gestion du cache à 800Mo, sinon les vidéos avaient du mal à tourner), ça prend du temps, le résultat ne s'affiche pas, etc. Si je recharge la page, ça va parfois un peu plus vite, mais pas toujours… C'est folk !!! J'ai un autre problème avec Firefox, je vais ouvrir un autre post (gestion de la barre de recherche). Ce message a été modifié par Anibé - 11 Mar 2018, 19:29. -------------------- Pourquoi MacIntosh ? Parce que !!! (depuis 1984)
11 Mar 2018, 19:28
#44
Je n'ai pas tout lu, mais les derniers messages correspondent en partie à ce qui m'arrive. De temps en temps, Firefox quitte sans moufter. Mais souvent il met un temps fou à quitter, si bien que je dois le forcer. J'ai remarqué que quand l'imprimante est restée allumée, ça met plus de temps. Mais aussi parfois quand ce sont des traitements de texte… C'est d'une grande fantaisie. A noter que ma version est la 48.0.2 Eh oui, on fait pas toujours ce qu'on veut… J'ai aussi parfois beaucoup de mal à vider le cache (j'ai augmenté la gestion du cache à 800Mo, sinon les vidéos avaient du mal à tourner) J'ai un autre problème avec Firefox, je vais ouvrir un autre post (gestion de la barre de recherche). Bonsoir, ça fait toujours plaisir de voir qu'on n'est pas seul... Je vide l'historique et ça va à peu près, mais si je vide AUSSI le cache en quittant, ça mouline un max et ça plante. -------------------- Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 et El Capitan - CS2.3 - LiveBox Sagem • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.6.8 | Photo: Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
11 Mar 2018, 20:44
#45
Macbidouilleur de bronze ! Groupe : Membres Messages : 332 Inscrit : 21 Jun 2005 Lieu : Paris dans le 9ème Membre no 41 271 |
Tu pourrais aussi essayer au départ d'un nouveau compte utilisateur pour voir si ce problème existe aussi. Oui, je peux faire ça. Je te tiendrai au courant... J'utilise toujours Firefox mais de plus en plus Opera qui me semble plus rapide. -------------------- Imac 2017 27"5K core I7 à 4,2 Ghz SSD NVMe 500Go (Ventura)/ MacPro 2008 /Quad 2x2.8 Ghz (Mojave et Linux Mint)/Mac Mini 2011 core I5 2,3 Ghz (El Capitan)/2 X Imac 2011 core I5 (Catalina et Linux Mint), Imac 2011 core I5 (High Sierra ) Imac G5 (Tiger).Macbook Pro 2019 core I5 (Sonoma) Ecrans Apple Cinéma Display plexi 22"et 23"/Apple cinéma HD Alu 20" et 23", NAS Qnap . |
Nous sommes le : 10th June 2024 - 23:43 |
