2 Pages V  < 1 2
> RC5-72 for Newbies
blueG3
posté 5 Apr 2003, 09:03
Message #31
Inscrit : 20 Nov 2001
Lieu : vitry sur seine (94)
Membre no 1 346
et en laissant le client caché ?
( Pomme - H)
folding@home ne prends que 0,5 a 1 % pour la partie graphique...
Desktop - CPU : AMD Ryzen 3600XT@4,6Ghz - RAM 16 Go - CM: Gigabyte X570-Aorus Pro CG : GeForce GTX 970- Audio: AMD Starship/Matisse HD Manjaro 25.1 xfce (unstable)
AMD Ryzen 9900x + Ram 32Go CM : Gigabyte X870 Elite Wifi 7 Cg : Radeon 9070 XT Gigabyte + Os Linux ( Archlinux )
apprenti bidouil...
posté 6 Apr 2003, 07:55
Message #32
Inscrit : 25 Jan 2003
Lieu : Avranches, 50
Membre no 5 837
J'ai téléchargé aussi dnetcx mais quand je le démarre et que j'appuie sur le bouton calculer, j'ai ça :
distributed.net client for Mac OS X Copyright 1997-2003, distributed.net
RC5-72 PowerPC and AltiVec assembly by Didier Levet
Please visit http://www.distributed.net/ for up-to-date contest information.
dnetc v2.9003-481-CTR-03022001 for Mac OS X (Darwin 6.4).
Please provide the *entire* version descriptor when submitting bug reports.
The distributed.net bug report pages are at http://www.distributed.net/bugs/
Using email address (distributed.net ID) '[email protected]'
[Apr 06 06:55:40 UTC] Automatic processor detection found 2 processors.
[Apr 06 06:55:40 UTC] Loading crunchers with work...
[Apr 06 06:55:40 UTC] Automatic processor type detection found
a PowerPC 7450 (G4) processor.
[Apr 06 06:55:40 UTC] RC5-72: using core #7 (KKS 7450).
[Apr 06 06:55:40 UTC] RC5-72: Loaded 53:9681FB98:00000000:1*2^32 (65.50% done)
[Apr 06 06:55:40 UTC] RC5-72: Loaded 53:92681BAB:00000000:1*2^32 (65.70% done)
[Apr 06 06:55:40 UTC] RC5-72: 0 packets remain in buff-in.r72
[Apr 06 06:55:40 UTC] RC5-72: 57 packets (57.00 stats units) are in
buff-out.r72
[Apr 06 06:55:40 UTC] 2 crunchers ('a' and 'b') have been started.
[Apr 06 06:55:40 UTC] Connected to euro.v29.distributed.net:2064...
[Apr 06 06:55:40 UTC] Net::write: error 61: Connection refused
[Apr 06 06:55:40 UTC] Connection closed.
pourtant magré tout, il calcule, est-ce normal ?
PierreB
posté 6 Apr 2003, 08:37
Message #33
Inscrit : 7 Oct 2002
Lieu : Cholet (49)
Membre no 4 005
je crois qu'il ne faite pas le calculs mais en tout cas ton fichier de sortie est plein et il n'arrive pas à ce connecter au serveur pour les envoyer, ressaye plus tart car le serveur est saturé. :wink:
MacBook CD/ 160 Go/1 Go de RAM/ MacOS X.4.11/Lecteur Zip 250 Mo USB/ Epson Stylus C 70 et C 86 /Base airport Extreme
Mathiasr
posté 6 Apr 2003, 11:17
Message #34
Inscrit : 26 Feb 2003
Lieu : Strasbourg
Membre no 6 410
QUOTE
Il calcule bien mais sur des blocks aléatoires, il n'a apparement jamais réussi à se connecter aux serveurs de distributed.net
Est-ce que ta connexion au net est bien active lorsque tu lances le client ?
Si tu n'es pas trop frileux avec le terminal tu peux essayer de faire une série de "./dnetc -fetch" dans le dossier où se trouve le client jusqu'à ce qu'il arrive à se connecter.
yobi
posté 6 Apr 2003, 11:43
Message #35
Inscrit : 7 Nov 2001
Lieu : Toulouse
Membre no 1 233
J'ai le même problème et le même resultat avec le terminal :-?
bad_duck
posté 6 Apr 2003, 12:01
Message #36
MacBidouilleur d'Or !
Groupe : Admin
Inscrit : 2 Mar 2002
Membre no 2 171
Je viens d'installer DnetX sur l'imac de ma soeur, et il n'a pas voulu se connecter, meme probleme, je pense que le serveur est saturé.
MaJ =>
Pour chatter avec des macbidouilleurs, rejoignez le chan IRC #macbidouille , plus d'infos et Webchat: par ici ;)
Et n'oubliez pas, vos amis sont toujours là pour vous: Google, man, how to, RTFM mais aussi FAQ et Recherche
Suivez MacBidouille sur Twitter ------------------------------------------------------>> http://twitter.com/macbid
yobi
posté 6 Apr 2003, 12:02
Message #37
Lieu : Toulouse
Membre no 1 233
Bisarrement j'ai essayé de lancer DnetcX avec en même temps dnetc sur le Terminal, j'ai eu 40% et 40% du CPU (avec top), puis j'ai killer le dnetc du terminal et maintenant DnetcX marche parfaitement ohmy.gif coup de bol surement, a moins qu'il faille l'initialiser ???
yobi
posté 6 Apr 2003, 12:03
Message #38
Lieu : Toulouse
Membre no 1 233
Je viens de lire ton message, donc ça se confirme c'était juste un coup de bol laugh.gif
Mathiasr
posté 6 Apr 2003, 14:24
Message #39
Lieu : Strasbourg
Membre no 6 410
Si les problèmes de connexion persistes vous pouvez spécifier d'utiliser les serveurs situés en amérique du nord, ça devrait contourner les serveurs européens éventuellement saturés :
./dnetc -a us.v29.distributed.net -update
mackamikase
posté 8 Apr 2003, 07:53
Message #40
Inscrit : 10 Oct 2001
Lieu : ici et ailleurs, vous pouvez pas comprendre...
Membre no 1 003
est ce qu'un FireWall peut compromettre la connection au serveur ?
PB 17". T68i. G5 dual+ATI 9800, le tout en Airport et bluetooth, que du bonheur.
Muggsy
posté 8 Apr 2003, 15:13
Message #41
Dreadman des forums
Inscrit : 10 Feb 2003
Membre no 6 091
Quand je fais "I want to join this team" ça met ça :
There was an error processing your request
We can"t find the email address that you entered, "".
datestamp: Apr 08 2003 14:14:59
:pleur2:
Membre du conseil de sécurité du CTC
http://muggsy-studio.com/
2 éditions de Jeux de 7 familles créés par des artistes sont en vente, envoyez moi un MP ! (édition très limitée 1000 exemplaires non retirés)
3x7
posté 8 Apr 2003, 20:13
Message #42
Inscrit : 9 Sep 2001
Lieu : Vive les cigales !
Membre no 764
Salut !
J'ai utilisé Dnetcx qui marche tout seul (préconfiguré pour l'équipe Macbidouille)
Je l'ai installé sur huit G4 mirror bi-867 à mon boulot (mes collègues techos sont au courant bien sûr).
Les machines sont en route 24h/24, sept jours sur sept.
Suivant l'utilisation, ca sort entre 200 et 300 paquets par jour par machine (je viens de commencer).
donc entre 1600 et 2400 paquets au total.
J'ai essayé sur une autre machine identique, j'ai eu droit à un kernel panic ! Bizarre, cet ordi là serait plus pointilleux que les autres et n'aime point la chaleur ?
Unix, PC, et surtout du Mac
• MBP 14 pouces 2021 - M1 3,2ghz - 32 go - SSD 1to (21e mac)
MacBook Pro 13", iPhone 6sPlus-128go iPad 2 64go
Stockage externe RAID Drobo 5 baies x2
Et par ordre chronologique, j'ai eu depuis 1989 :
Macintosh Plus 68000 8Mhz boosté à 4mo (fallait couper un composant pour qu'il reconnaisse plus de 2,5 mo) / Macintosh LC 68020 16Mhz / Mac IIci 68040 25Mhz (+ carte accélératrice à 50mhz) / Powerbook 165c 68030 33Mhz / Powerbook 5300 603e-100Mhz / Powerbook 1400c 603e-133Mhz / PowerMac 7600 120Mhz / PowerMac 8600 250Mhz / PowerMac 9600 350Mhz / PowerMac G3 desktop 350Mhz / iMac G3-400Mhz / iBook G3-300Mhz / PowerMac G4-400 (overclock 500Mhz!) / PowerMac G4 bi-500mhz / PowerMac G4 bi-833Mhz / PowerMac G4 bi 1,25ghz / PowerMac G5 bi 1,8Ghz / PowerMac G5 bi 2 Ghz / MacbookPro 15 core duo 1,8Ghz / MacbookPro 15 Core2duo 2,4Ghz / MacbookPro 13 Core2duo 2,4Ghz / iMac 27 pouces i7 3,4Ghz Carte vidéo remplacée en 2013…/ MacBookPro rétina 2012 Carte mère changée en 2018 suite à dysfonctionnement carte vidéo… Prise en charge Apple 100% un mois avant la fin de la période OUF !
Mathiasr
posté 8 Apr 2003, 23:40
Message #43
Lieu : Strasbourg
Membre no 6 410
QUOTE
Oui s'il bloque le port 2064, mais on peut configurer le client pour qu'il utilise le port 80 (comme un navigateur) à la place.
Mathiasr
posté 8 Apr 2003, 23:44
Message #44
Lieu : Strasbourg
Membre no 6 410
QUOTE
Tu as bien tapé ton adresse mail sans erreur ?
Tu n'utilise pas un navigateur trop exotique ? Par ailleurs en général il faut complètement vider les caches, ou quitter et relancer le navigateur pour accéder à une page derrière un mot de passe sur distributed.net si on s'est planté une fois.
Mathiasr
posté 8 Apr 2003, 23:50
Message #45
Lieu : Strasbourg
Membre no 6 410
QUOTE
C'est possible, dnetc exploite l'AltiVec sans relache car il n'y a pratiquement pas d'accès mémoire (aucun cycle d'attente d'une donnée), donc le processeur doit atteindre sa température maximale.
Ça permet de trouver les limites d'un overclock assez rapidement.
Si tu vérifies la machine avec le CD de diagnostic qui était livré avec ça donne quoi ?
bad_duck
posté 9 Apr 2003, 07:22
Message #46
Groupe : Admin
Membre no 2 171
QUOTE
QUOTE
J'ai NetBarrier, et DnetcX (v1.3), toutes les requettes de l'exterieurs sont bloquées (sauf les ports que j'utilise) et je n'ai pas de problme de connection sur le serveur :fou:
pimus
posté 13 Apr 2003, 17:07
Message #47
Inscrit : 8 Sep 2001
Lieu : Banlieue Sud Ankh Morpork
Membre no 758
J'ai le problème suivant :
dnetc (pas dnetcx) installé sans problème sur 2 Macs sous 10.2.4.
Tout fonctionne très bien à part la fonction -install qui installe bien un dossier dnetc dans le dossier Livbrary/Startup mais pas moyen d'avoir un lancement automatique au démarrage.
Réparation des autorisations, désinstallation totale (-uninstall et manuelle) et réinstallation sur les 2 Macs.
Même symptome! :-? Pas de dnetc avec top dans le terminal.
Je l'ai pourtant fait de la même manière sur 2 ordis du bureau sans problème.
Non, vérification faite, ces 2 là ne démarrent pas non plus en lançant dnetc.
<span style='font-size:8pt;line-height:100%'>La théorie, c'est quand on sait tout et que rien ne fonctionne. La pratique, c'est quand tout fonctionne et que personne ne sait pourquoi. Ici, nous avons réuni théorie et pratique : Rien ne fonctionne... et personne ne sait pourquoi !</span>
3x7
posté 3 Jul 2003, 11:37
Message #48
Membre no 764
Si tu vérifies la machine avec le CD de diagnostic qui était livré avec ça donne quoi ?[/quote]
Après plusieurs mois de calculs, je n'ai plus eu du tout de kernel panic
J'ai constaté la chose suivante :
Dnetc lancé + l'économiseur d'écran "Flurry" = ca peut planter.
Avec un économiseur d'écran simple = aucun problème
kenobie
posté 5 Jul 2003, 10:14
Message #49
Inscrit : 10 Sep 2002
Lieu : Poitiers & Coubron (93)
Membre no 3 447
Je voudrais savoir si le message qui m'est retourné par DnetcX est positif quand je clique sur "envoyer" (tiens, au passage, faut-il cliquer sur arreter avant d'envoyer?) car ça fait plus de 48 h que je l'ai lancé, et rien dans ma boîte mail...est-ce que le travail que je fais sera compté pour la team ou il faut attendre l'inscription ?
QUOTE
[Jul 05 09:03:49 UTC] 1 cruncher has been started.
[Jul 05 09:12:34 UTC] *Break* Shutting down...
[Jul 05 09:12:34 UTC] Shutting down...
[Jul 05 09:12:34 UTC] Waiting for crunchers to stop...
[Jul 05 09:12:34 UTC] RC5-72: Saved CA:59DC297C:00000000:1*2^32 (84.00% done)
0.00:08:45.12 - [828,272 keys/s]
[Jul 05 09:12:34 UTC] RC5-72: 24 packets (24.00 stats units) are in
buff-in.r72
[Jul 05 09:12:34 UTC] RC5-72: 0 packets are in buff-out.r72
[Jul 05 09:12:34 UTC] Shutdown complete.
RC5-72 PowerPC assembly by Malcolm Howell and Didier Levet
Enhancements for 604e CPUs by Roberto Ragusa
RC5-72 Altivec assembly by Didier Levet
dnetc v2.9005-484-CTR-03042809 for Mac OS X (Darwin 6.0).
[Jul 05 09:12:35 UTC] Automatic processor detection found 1 processor.
[Jul 05 09:12:35 UTC] Automatic processor type detection found
a PowerPC 740/750 (G3) processor.
[Jul 05 09:12:35 UTC] RC5-72: using core #8 (MH 1-pipe).
[Jul 05 09:12:35 UTC] RC5-72: Loaded CA:59DC297C:00000000:1*2^32 (84.00% done)
[Jul 05 09:12:35 UTC] RC5-72: 23 packets (23.00 stats units) remain in
buff-in.r72
[Jul 05 09:12:35 UTC] RC5-72: 0 packets are in buff-out.r72
[Jul 05 09:12:36 UTC] 1 cruncher has been started.
On ne peut pas changer le monde, mais on peut toujours y laisser une trace ! [url="http://www.lemonway.fr"]
iMac G5 15' - X.5.8
PB 1,5 GHZ - 1024 Mo - Tiger
bad_duck
posté 5 Jul 2003, 10:18
Message #50
Groupe : Admin
Membre no 2 171
Salut :fou:
En fait, tu ne recois pas de Mail automatiquement, il faut que tu ailles sur le site, que tu cherches ta page de stats a l'aide de ton Mail, et sur cette page, tu auras un boutton pour demander ton pass.
Ensuite, tu vas sur la page de la team MB et tu t'inscris.
MaJ, j'ai cherché avec ton Mail qui est dans ton profil.
Ta page de stats
=> http://stats.distributed.net/participant/p..._id=8&id=423604
Maintenant, en bas de la page, tu peux demander ton pass, puis ensuite, t'inscire.
=> http://stats.distributed.net/participant/p...?team=940186478
2 Pages V  < 1 2
Nous sommes le : 22nd December 2025 - 06:15
