94 Pages V  « < 83 84 85 86 87 > »
> Team RC5-72 MacBidouille
Tchou
posté 18 Nov 2005, 16:55
Message #2511
Inscrit : 13 Mar 2003
Lieu : Là ou je me pose...
Membre no 6 655
QUOTE(cpsykopat @ 18 Nov 2005, 16:05)
je ne sais pas si c'est a cause du nombre de core, voila un extrait :
[Nov 18 14:49:19 UTC] Automatic processor detection found 4 processors.
[Nov 18 14:49:19 UTC] Loading crunchers with work...
[Nov 18 14:49:19 UTC] The keyserver says: "proxy1.red.wa.us.proxy.distributed
                      dot net"
[Nov 18 14:49:19 UTC] Retrieved project state data from server. (cached)
[Nov 18 14:50:26 UTC] RC5-72: Retrieved 96 packets (96.00 stats units) from server.
[Nov 18 14:50:26 UTC] Automatic processor type detection did not
                      recognize the processor (id: 68)
[Nov 18 14:50:26 UTC] RC5-72: using core #4 (KKS 7450).
[Nov 18 14:50:26 UTC] RC5-72 #a: Loaded CB:222AD00F:00000000:1*2^32
[Nov 18 14:50:26 UTC] RC5-72 #b: Loaded CB:222AD013:00000000:1*2^32
[Nov 18 14:50:26 UTC] RC5-72 #c: Loaded CB:222AD016:00000000:1*2^32
[Nov 18 14:50:26 UTC] RC5-72 #d: Loaded CB:222AD019:00000000:1*2^32
[Nov 18 14:50:26 UTC] RC5-72: 92 packets (92.00 stats units) remain in
                      buff-in.r72
[Nov 18 14:50:26 UTC] RC5-72: 0 packets are in buff-out.r72
[Nov 18 14:50:26 UTC] 4 crunchers ('a'-'d') have been started.
[Nov 18 14:54:26 UTC] RC5-72 #b: Completed CB:222AD013:00000000 (1.00 stats units)
                      0.00:03:59.63 - [17,923,078 keys/s]
[Nov 18 14:54:26 UTC] RC5-72 #b: Loaded CB:222AD0C5:00000000:1*2^32
[Nov 18 14:54:26 UTC] RC5-72 #a: Completed CB:222AD00F:00000000 (1.00 stats units)
                      0.00:03:59.56 - [17,928,689 keys/s]
[Nov 18 14:54:26 UTC] RC5-72 #a: Loaded CB:222AD0C9:00000000:1*2^32
[Nov 18 14:54:26 UTC] RC5-72: Summary: 2 packets (2.00 stats units)
                      0.00:05:06.94 - [27.99 Mkeys/s]
[Nov 18 14:54:26 UTC] RC5-72: 90 packets (90.00 stats units) remain in
                      buff-in.r72
                      Projected ideal time to completion: 0.01:29:37.00
[Nov 18 14:54:26 UTC] RC5-72: 2 packets (2.00 stats units) are in
                      buff-out.r72
[Nov 18 14:54:27 UTC] RC5-72 #d: Completed CB:222AD019:00000000 (1.00 stats units)
                      0.00:03:59.88 - [17,904,773 keys/s]
[Nov 18 14:54:27 UTC] RC5-72 #d: Loaded CB:222AD153:00000000:1*2^32
[Nov 18 14:54:27 UTC] RC5-72 #c: Completed CB:222AD016:00000000 (1.00 stats units)
                      0.00:04:00.11 - [17,887,547 keys/s]
[Nov 18 14:54:27 UTC] RC5-72 #c: Loaded CB:222AD163:00000000:1*2^32
[Nov 18 14:54:27 UTC] RC5-72: Summary: 4 packets (4.00 stats units)
                      0.00:05:07.95 - [55.79 Mkeys/s]
[Nov 18 14:54:27 UTC] RC5-72: 88 packets (88.00 stats units) remain in
                      buff-in.r72
                      Projected ideal time to completion: 0.01:27:38.00
[Nov 18 14:54:27 UTC] RC5-72: 4 packets (4.00 stats units) are in
                      buff-out.r72
[right][snapback]1424695[/snapback][/right]
Et côté chauffage ça marche bien ?
Satellite du CTC
cpsykopat
posté 18 Nov 2005, 18:47
Message #2512
Inscrit : 6 Aug 2002
Lieu : Athis Mons
Membre no 3 091
Je ne sais pas si les capteur sont placés différemment, mais ca m'affiche 20°C de moins pour la même utilisation intensive ...
Il est tellement silencieux en utilisation intensive que je me demande si il fonctionne vraiment ( quand je dis silencieux, c'ets par rapport au 2x2,5Ghz )
kakace
posté 18 Nov 2005, 19:20
Message #2513
Inscrit : 15 Mar 2003
Lieu : Périgord vert
Membre no 6 698
Le serveur de stats connait de gros soucis. L'origine de la panne concerne le RAID 10. Au moins 3 disques sont defectueux et vont être remplacés dans les prochains jours (échange sous garantie), mais il n'est pas exclu que la carte contrôleur soit aussi endommagée. A priori, l'ensemble RAID s'est dégradé progressivement et insidieusement (il est statistiquement exclu que 3 disques tombent en panne au même moment).
Dès que ce problème sera réglé, les stats seront récupérées depuis le dernier backup et complétées jusqu'au jour J (donc les blocs calculés ne sont pas perdus). En revanche, toute modification récente apportée aux comptes utilisateurs ou aux équipes est probablement perdue.
En ce qui concerne les dual dual-core :
"[Nov 18 14:50:26 UTC] Automatic processor type detection did not
recognize the processor (id: 68)"
Le client ne reconnait pas explicitement les processeurs (id inconnu). Cela n'a pas d'importance (autre que cosmétique) puisque le client détermine la présence des unités AltiVec par un autre moyen, et donc sélectionne le moteur optimal.
Mac Mini M4 32 Go
popboy
posté 18 Nov 2005, 20:46
Message #2514
Inscrit : 30 Jun 2002
Lieu : Genève à bicyclette.
Membre no 2 804
Ravi de voir du monde smile.gif ça faisait longtemps, ça commence à durer cette panne de stat,
mais les "plan" sont mis à jour régulièrement, nous verrons bien.
G5 bi 1,8, BiproMDD 1G ,MacBookPro, MacMini 1,25 X 2, Newton 2100
looping19
posté 20 Nov 2005, 12:11
Message #2515
Inscrit : 18 Sep 2002
Lieu : Normandie
Membre no 3 575
Pour les stat,avec une absences aussi longue le retour va faire plaisir.
imac 21" i5 X.9
iBook G4 14" 1.4 Ghz +1Go+60Go sous X.5.8
G4 1.33 digital audio+1536 mo+160Go+ATI 9000 128mo+ 17"+ X.5.8
Mac Pro 2x3 Quad+8Go+1To+2to+2to+2to+ext 500Go+Nvidia 8800GT+20"sous 10.8.5
Une petite visite chez moi? Merci
Dahood
posté 20 Nov 2005, 12:29
Message #2516
Inscrit : 3 Dec 2001
Lieu : Mulhouse dans le 68 !
Membre no 1 493
Salut tout le monde, je passe dire un coucou, je sais pas quelle place je tiens, je dois pas etre loin du 6eme ou 7eme.
Au menu 2 Dual 2.5Ghz, un Dual 1.42 et un Quicksilver Dual 800 (serveur), ca tourne bien, je suis content. Je garde mon Dual 1.42 perso et mon iBookG3 en reserve, juste en cas d'attaque tongue.gif
Vivement le retour des stats,
a++
Ce message a été modifié par Dahood - 20 Nov 2005, 12:29.
PC : Phanteks P200a / Ryzen 5800x / ASUS ROG Impact VIII / 32Go RAM / Radeon RX6800 FE / Corsair RM850
iPad Pro 12,9
AppleTV 4K+ Homepod mini / Apple TV HD
iMac M1 2022
iMac Core2Duo late 2009/ 8Go / 9400M + Mod SSD
Mes vieux Macs :
MacBook CoreDuo
PowermacG5 Dual 2.5Ghz / 5Go / nVidia 6800 UltraDDL
PowerMac G4 Dual 1.42Ghz / 1,5Go / Radeon9800 Pro MacEdition+ATIsilencer mod/ 250Go RAID0
PowerMac G4 Quicksiler 2x800Mhz
iBook G3 600 Late2001 /HD 5400tr / Ubuntu
xBox360+Wii
Nintendo Switch + Switch Lite
xBox Series X
popboy
posté 20 Nov 2005, 23:13
Message #2517
Membre no 2 804
Forcément personne ne sait, la surprise risque de durer (je dirais encore une semaine) le temps de recevoir la carte pour les disques...
patpan
posté 21 Nov 2005, 00:07
Message #2518
Inscrit : 3 Jul 2004
Lieu : paris
Membre no 20 678
QUOTE(popboy @ 21 Nov 2005, 00:13)
[right][snapback]1427391[/snapback][/right]
bonsoir,
si trois disques sont perdus, alors le RAID 10, cela sert à quoi?
un copain venu ce soir, ingénieur chez IBM se marre!
il vend du R10 à ses plus gros comptes!
Pat
Ce message a été modifié par patpan - 21 Nov 2005, 00:09.
MacPro 8 cores, 20Go RAM, 12To, CG:X1900XT (silencieuse!) Dell 30'...,OS
MacBook Pro 17, [i]OS X.7.4] 4Go Ram..
ctrl_alt_suppr
posté 21 Nov 2005, 18:20
Message #2519
Touche d'originalité
Inscrit : 23 Sep 2003
Lieu : Grenoble
Membre no 9 784
QUOTE(patpan @ 21 Nov 2005, 00:07)
Pat
[right][snapback]1427459[/snapback][/right]
QUOTE(kakace @ 18 Nov 2005, 19:20)
[right][snapback]1424948[/snapback][/right]
Ce message a été modifié par ctrl_alt_suppr - 21 Nov 2005, 18:20.
G3 BB 400 transformé en G4 800MHz !, Radeon 7000, DVR-A106, Graphire 3, iPod3 20G, 10.4, Airport Express, Freebox v4
TiBook 800MHz DVI, Mighty Mouse, Guitar Rig, Carte WiFi Belkin 802.11g, iSight
Mac Pro 2,66GHz + Bluetooth :)
Wii !
CUPTCiste occasionnel - membre du team RC5-72 Le Pommier - Votez BigManu sous peine de titrage ! - Invitations Gmail
Grenoblois, viendez-tous - Inscrivez-vous sur Apple-expo.info
patpan
posté 22 Nov 2005, 00:26
Message #2520
Lieu : paris
Membre no 20 678
QUOTE(ctrl_alt_suppr @ 21 Nov 2005, 19:20)
[right][snapback]1428548[/snapback][/right]
Bonsoir à toutes et à tous,
Désolé pour ma réponse trop rapide,
il paraît évident que cela provient de la carte "contrôleur"!
Si kakace, cher ami, tu pouvais nous fournir plus d'infos, elles seraient les bienvenues!
Pat
popboy
posté 23 Nov 2005, 18:37
Message #2521
Membre no 2 804
Ils ont reçu le contrôleur, bientôt le retour des "stats" fraîches smile.gif
cpsykopat
posté 26 Nov 2005, 15:48
Message #2522
Lieu : Athis Mons
Membre no 3 091
Il y a du nouveau pour le retour des stats ?
ctrl_alt_suppr
posté 27 Nov 2005, 13:12
Message #2523
Lieu : Grenoble
Membre no 9 784
http://n0cgi.distributed.net/cgi/dnet-fing...gi?user=decibel
Ils doivent réinstaller le serveur fritz dans un data center pour que les stats soient de nouveau en ligne.
Wii !
looping19
posté 27 Nov 2005, 16:25
Message #2524
Lieu : Normandie
Membre no 3 575
Encore du boulot en perspective.
imac 21" i5 X.9
cpsykopat
posté 28 Nov 2005, 06:13
Message #2525
Lieu : Athis Mons
Membre no 3 091
popboy
posté 28 Nov 2005, 07:23
Message #2526
Membre no 2 804
vlurk
posté 28 Nov 2005, 17:33
Message #2527
Inscrit : 25 Sep 2003
Lieu : Montreal, Canada
Membre no 9 853
Je suis bien content de voir les stats de retour: j'ai travailler fort en leur absence et j'avais bien hâte de voir le résultat! biggrin.gif D'ailleurs, ils sont très satisfaisants: je suis enfin passé dans le top 100! cool.gif
Maintenant, j'ai une question à vous soumettre, si personne n'y vois d'objection: quelqu'un est-il au courrant de ce qu'il est advenu du client Windows 64bits (x86-64)? J'ai fait mes devoirs et constaté qu'il y avait déjà une question "officielle" à ce sujet ici, et on mentionne qu'il existe un client parmis ceux en phase de tests. Toutefois, il ne se trouve pas sur la page officielle.
Est-ce que j'ai manqué quelque chose? J'ai pensé soumettre la question ici avant de la soumettre à distributed.net...
Ce message a été modifié par vlurk - 28 Nov 2005, 17:52.
-ThinkPad X1 Carbon 3rd Gen; dual boot Win10 / Ubuntu 16.04 LTS.
-Google Pixel 2 perso, iPhone 8 pour le bureau.
-Core i7 7800x, 32GB RAM, GeForce 1070 GTX, Windows 10 Pro.
-pare-feu pfSense sur plateforme Habey BIS-6634.
popboy
posté 28 Nov 2005, 18:33
Message #2528
Membre no 2 804
Ce sont des versions dites "prerelease pour test", tu ne cours pas grand risque à essayer,
ce ne sont pas des beta d'ailleurs (contrairement à ce que je pensais).
Ce message a été modifié par popboy - 28 Nov 2005, 18:34.
vlurk
posté 28 Nov 2005, 19:09
Message #2529
Membre no 9 853
Justement: je voudrais bien l'essayer puisque je dispose d'un PC équipé de Windows XP Pro 64bits. smile.gif Mais je n'arrive pas à trouver le client: contrairement à ce qui est indiqué le lien n'est pas donné sur la page des clients en pre-release. huh.gif Et naturellement, il ne figure pas parmis les clients officiellement disponibles. Je ne sais plus où regarder... unsure.gif
Ce message a été modifié par vlurk - 28 Nov 2005, 19:10.
altai
posté 28 Nov 2005, 19:20
Message #2530
Inscrit : 19 Apr 2005
Lieu : K-Rouge, Genève
Membre no 37 441
Pour information les statistiques ne sont pas à jour.
Data shown reflects all blocks received as of 24-Nov-2005 at 23:59 UTC. Current time is 28-Nov-2005 18:12:52.
PM G5 Dual 2.3 Ghz RAM 1.5 Gb DD 250 Gb CG Radeon X800XT BT et Airport, iSight, écran Dell 2405FPW, OS 10.4.6 iPod Color 20G, Souris MX510, Nostromo Speedpad N52, Enceinte TEAC, Imprimante laser couleur Epson C1100
MacBook White 2 GHZ 1Gb 60 Go
world so cold
posté 28 Nov 2005, 21:30
Message #2531
Inscrit : 23 Jul 2003
Lieu : Sur MacBidouille
Membre no 8 736
Je me suis inscrit il y a quelque jours déjà, et il ne veule pas m'envoyer mon mot de passe,donc je ne peux pas rejoindre la team de macbidouille, donc je suis deg sad.gif
kakace
posté 28 Nov 2005, 22:23
Message #2532
Membre no 6 698
QUOTE(vlurk @ 28 Nov 2005, 17:33)
Il a été retiré (bug majeur). De toute façon, il était plus lent que la version 32-bit.
Quant aux stats, elles sont à jour. Il fallait juste être un peu patient (22:05:22: dctievent: (statsbox-iv/r72) Daily processing for 20051127 has completed) tongue.gif
Mac Mini M4 32 Go
nektarfl
posté 28 Nov 2005, 22:34
Message #2533
Inscrit : 17 Feb 2003
Lieu : pommeuse (77)
Membre no 6 239
il ne faut pas être dégouté, tes blocks calculés iront à l'équipe quand tu t'inscrira, il n'y a donc rien de perdu...
quand tu vas sur cette page tu rentres ton mail dans le champs vide avant le bouton search.
Normalement, ça affiche ta page de stats, puis dans le bas de cette page là, tu as un bouton : Please email me my password
Tu appuies dessus, et tu reçois ton mot de passe dans les 5 à 20 minutes plus tard.
world so cold
posté 28 Nov 2005, 22:35
Message #2534
Membre no 8 736
QUOTE(nektarfl @ 28 Nov 2005, 22:34)
[right][snapback]1439556[/snapback][/right]
vlurk
posté 29 Nov 2005, 00:20
Message #2535
Membre no 9 853
QUOTE(kakace @ 28 Nov 2005, 17:23)
[right][snapback]1439534[/snapback][/right]
Merci kakace. Je suis un peu déçu, mais conserve l'espoir qu'en temps et lieu un client Windows 64bits (x86-64) performant verra le jour. Enfin, l'avenir est au processeur 64bits quand même. rolleyes.gif
En attendant, je vais essayer de me bidouiller une Kubuntu LiveCD pour AMD64 avec le client optimisé...
world so cold
posté 29 Nov 2005, 10:56
Message #2536
Membre no 8 736
C'est moi ou les stats sont une fois de plus down?
looping19
posté 29 Nov 2005, 17:24
Message #2537
Lieu : Normandie
Membre no 3 575
QUOTE(world so cold @ 29 Nov 2005, 10:56)
[right][snapback]1440234[/snapback][/right]
Je pense aussi.
Je ne peus pas y aller.
Message safari "car le serveur ne répond plus."
imac 21" i5 X.9
vlurk
posté 29 Nov 2005, 20:52
Message #2538
Membre no 9 853
Elles sont "officiellement" hors ligne. Des détails sont fournis sur le plan de Decibel: http://n0cgi.distributed.net/cgi/dnet-fing...gi?user=decibel
popboy
posté 30 Nov 2005, 13:40
Message #2539
Membre no 2 804
C'est un peu le chat de chester, elles sont la, elles ne sont plus la...
patpan
posté 3 Dec 2005, 19:35
Message #2540
Lieu : paris
Membre no 20 678
En essais avec dnetc, il me donne du 74,02Mkeys/s, ce qui va redonner un peu de punch à mes scores!
Pat
Nous sommes le : 11th November 2025 - 04:35
