Adepte de Macbidouille ![]() Groupe : Membres Messages : 184 Inscrit : 7 Jun 2005 Lieu : Vétraz-Monthoux Membre no 40 558 ![]() |
Je viens de vitaminer un iMac G3 DV 400MHz et suis assez content du résultat:
- changement du processeur de la carte-mère G4-550MHz (7450) et passage du cache L2 à 1Mo (512K noté dans les paramètres système) - remplacement du DD d'origine (Quantum 12Go) par un Seagate Barracuda 120Go - augmentation de la mémoire à 768 Mo(512+256) - remplacement du lecteur DVD d'origine par un Superdrive Fastmac Voici les résultats de Xbench: Results 67.12 System Info Xbench Version 1.1.3 System Version 10.4.2 (8C46) Physical RAM 768 MB Model PowerMac2,1 Processor PowerPC G4 @ 550 MHz Version 7410 (Nitro) v1.4 L1 Cache 32K (instruction), 32K (data) L2 Cache 512K @ 220 MHz Bus Frequency 100 MHz Video Card ATY,Rage128VR Drive Type ST3120026A CPU Test 61.83 GCD Loop 56.18 2.19 Mops/sec Floating Point Basic 68.43 247.47 Mflop/sec AltiVec Basic 45.29 1.32 Gflop/sec vecLib FFT 61.35 952.43 Mflop/sec Floating Point Library 99.30 3.97 Mops/sec Thread Test 50.57 Computation 34.78 469.59 Kops/sec, 4 threads Lock Contention 92.61 1.16 Mlocks/sec, 4 threads Memory Test 65.63 System 64.21 Allocate 344.45 224.69 Kalloc/sec Fill 62.99 501.40 MB/sec Copy 35.79 178.95 MB/sec Stream 67.11 Copy 68.21 498.64 MB/sec [altivec] Scale 66.98 494.35 MB/sec [altivec] Add 65.20 417.30 MB/sec [altivec] Triad 68.12 416.19 MB/sec [altivec] Quartz Graphics Test 67.60 Line 50.76 1.29 Klines/sec [50% alpha] Rectangle 63.41 4.46 Krects/sec [50% alpha] Circle 64.09 1.48 Kcircles/sec [50% alpha] Bezier 75.80 823.65 beziers/sec [50% alpha] Text 103.07 1.68 Kchars/sec OpenGL Graphics Test 64.16 Spinning Squares 64.16 44.90 frames/sec User Interface Test 127.78 Elements 127.78 41.10 refresh/sec Disk Test 67.09 Sequential 52.85 Uncached Write 28.61 11.93 MB/sec [4K blocks] Uncached Write 72.62 29.74 MB/sec [256K blocks] Uncached Read 76.68 12.14 MB/sec [4K blocks] Uncached Read 71.81 29.02 MB/sec [256K blocks] Random 91.82 Uncached Write 91.87 1.38 MB/sec [4K blocks] Uncached Write 102.93 23.21 MB/sec [256K blocks] Uncached Read 92.30 0.61 MB/sec [4K blocks] Uncached Read 82.45 16.97 MB/sec [256K blocks] Je ne vais utiliser cette machine que pour du classement de photos-iPhoto, de CD-iTunes et du montage vidéo (transfert Hi8--->DVD) avec iMovie. Ca fonctionnait assez bien sous 9.2 mais c'est beaucoup plus sympa maintenant sous Tiger avec cette configuration. J'utilise un stick USB-Wifi pour la connexion internet et un disque firewire externe LaCie 60Go. C'est compact, le son est correct et l'affichage bien que restreint (15" 1024X768) est d'excellente qualité. Le silence de fonctionnement est très très agréable car le système de refroidissement est vraiment ingénieux et le Barracuda très silencieux. Donc pour conclure, si vous êtes attaché à votre iMac G3 DV Slot Load et que vous pensez le migrer sur Tiger, l'investissement de $200 pour le changement de processeur me semble intéressant. -------------------- MacBook C2D + iPad 3G
![]() Nouveau Membre Groupe : Membres Messages : 20 Inscrit : 13 Jun 2005 Lieu : Quito - Equateur Membre no 40 872 ![]() |
Waouh ! Impressionnant. Memory et CPU quasi triplé. J'ai un iMac G3 DV 400 slot load également avec 512 Mb et voici le XBench:
Results 37.82 System Info Xbench Version 1.1.3 System Version 10.3.9 (7W98) Physical RAM 512 MB Model PowerMac2,1 Processor PowerPC 750 @ 400 MHz L1 Cache 32K (instruction), 32K (data) L2 Cache 512K @ 160 MHz Bus Frequency 100 MHz Video Card ATY,Rage128VR Drive Type QUANTUM FIREBALL lct10 10.2A CPU Test 27.24 GCD Loop 42.02 1.64 Mops/sec Floating Point Basic 64.19 232.12 Mflop/sec vecLib FFT 10.84 168.30 Mflop/sec Floating Point Library 65.79 2.63 Mops/sec Thread Test 35.42 Computation 25.59 345.53 Kops/sec, 4 threads Lock Contention 57.51 721.93 Klocks/sec, 4 threads Memory Test 24.73 System 28.07 Allocate 307.96 200.89 Kalloc/sec Fill 27.85 221.66 MB/sec Copy 14.77 73.85 MB/sec Stream 22.10 Copy 20.43 149.34 MB/sec Scale 20.26 149.51 MB/sec Add 23.66 151.41 MB/sec Triad 24.74 151.18 MB/sec Quartz Graphics Test 55.08 Line 44.19 1.12 Klines/sec [50% alpha] Rectangle 52.01 3.66 Krects/sec [50% alpha] Circle 53.65 1.24 Kcircles/sec [50% alpha] Bezier 55.62 604.37 beziers/sec [50% alpha] Text 81.33 1.33 Kchars/sec OpenGL Graphics Test 49.29 Spinning Squares 49.29 34.49 frames/sec User Interface Test 69.97 Elements 69.97 22.50 refresh/sec Disk Test 37.07 Sequential 34.34 Uncached Write 29.70 12.38 MB/sec [4K blocks] Uncached Write 28.66 11.74 MB/sec [256K blocks] Uncached Read 67.54 10.69 MB/sec [4K blocks] Uncached Read 30.21 12.21 MB/sec [256K blocks] Random 40.26 Uncached Write 31.26 0.47 MB/sec [4K blocks] Uncached Write 37.23 8.40 MB/sec [256K blocks] Uncached Read 61.33 0.40 MB/sec [4K blocks] Uncached Read 41.33 8.51 MB/sec [256K blocks] . -------------------- Imac G4 17" 800 MHz/768Mb/160Go en OsX 4.2 + Airport Extreme et Airport Express + LaCie Big Disk 500Go + iMac G3 400 MHz/512Mb
Le tout utilisé à mille cent pour cent -------------- C'est quand on utilise vraiment les ordinateurs qu'on est bien content de se retrouver sur Mac |
Effectivement je ne pensais pas que la cure de vitamines serait aussi efficace. J'ai eu un petit soucis avec la carte-mère qui avait souffert pendant le voyage du retour mais Fastmac m'en a retourné une neuve sans demander d'explication. J'en ai profitté pour leur demander une offre intéressante sur le le lecteur Superdrive .
![]() ![]() -------------------- MacBook C2D + iPad 3G
Juste une question indiscrète. Tu parles de 200 $, mais ça c'est juste le processeur, non. Il faut encore ajouter le DD, la mémoire et le super drive. Ça doit faire quand pas mal au bout du compte.
QUOTE(ecuamac @ 30 Jul 2005, 00:39) Juste une question indiscrète. Tu parles de 200 $, mais ça c'est juste le processeur, non. Il faut encore ajouter le DD, la mémoire et le super drive. Ça doit faire quand pas mal au bout du compte. [right][snapback]1258877[/snapback][/right] Exact, j'avais le DD sous le coude avec la mémoire et le Superdrive m'a aussi couté $200. -------------------- MacBook C2D + iPad 3G
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 2 327 Inscrit : 27 Mar 2005 Lieu : 0x4C6F6E64726573 Membre no 36 014 ![]() |
au niveau performance sa ne change pas grde chose pour les iMac G3 600Mhz d'apres Xbench
il suffit juste de rajouter de la ram 768Mo et un jolie graveur et sa fai a peu pres pareil voici le test xbench d'un G3 600Mhz il a un gain certe mais surtout du au disque dur et à la ram Results 50.74 System Info Xbench Version 1.1.3 System Version 10.4.2 (8C46) Physical RAM 512 MB Model PowerMac4,1 Processor PowerPC G3 @ 600 MHz Version Goldfinger v3.1 L1 Cache 32K (instruction), 32K (data) L2 Cache 256K @ 600 MHz Bus Frequency 100 MHz Video Card ATY,Rage128Pro2 Drive Type ST380011A CPU Test 34.38 GCD Loop 61.20 2.39 Mops/sec Floating Point Basic 85.97 310.91 Mflop/sec vecLib FFT 12.96 201.26 Mflop/sec Floating Point Library 89.00 3.56 Mops/sec Thread Test 52.88 Computation 36.85 497.53 Kops/sec, 4 threads Lock Contention 93.58 1.17 Mlocks/sec, 4 threads Memory Test 27.40 System 32.93 Allocate 229.28 149.56 Kalloc/sec Fill 46.73 371.97 MB/sec Copy 15.30 76.51 MB/sec Stream 23.47 Copy 21.70 158.64 MB/sec Scale 21.58 159.29 MB/sec Add 25.12 160.80 MB/sec Triad 26.16 159.81 MB/sec Quartz Graphics Test 64.68 Line 44.94 1.14 Klines/sec [50% alpha] Rectangle 68.45 4.82 Krects/sec [50% alpha] Circle 65.97 1.52 Kcircles/sec [50% alpha] Bezier 46.98 510.47 beziers/sec [50% alpha] Text 250.39 4.08 Kchars/sec OpenGL Graphics Test 68.85 Spinning Squares 68.85 48.18 frames/sec User Interface Test 100.16 Elements 100.16 32.21 refresh/sec Disk Test 74.00 Sequential 66.22 Uncached Write 68.83 28.69 MB/sec [4K blocks] Uncached Write 70.76 28.98 MB/sec [256K blocks] Uncached Read 58.34 9.24 MB/sec [4K blocks] Uncached Read 68.48 27.67 MB/sec [256K blocks] Random 83.85 Uncached Write 74.10 1.11 MB/sec [4K blocks] Uncached Write 89.78 20.25 MB/sec [256K blocks] Uncached Read 90.22 0.60 MB/sec [4K blocks] Uncached Read 83.45 17.17 MB/sec [256K blocks] -------------------- |---|rMacBook Pro i9 2,3Ghz / 16Go/ 512Go SSD / AMD 5500M / macOS Catalina & Windob 10
|---|cMacBook Pro i7 2,7Ghz Anti-reflet + High-Res/ 16Go/ 1To + 1To SSD Crucial M550/ Nvidia 650M GT/ OS X Mojave |--|MacPro |-|Une flopée d'anciens Macs de l'Apple IIe au PowerMac G4 -Mon site Yourmac.fr |
C'est quand même nettement meilleur sur le CPU (61.83 contre 34.38) et sur le system (64.21 contre 32.93) . Par contre le Seagte Barracuda 120 Go semble légèrement inférieur au tien (67.09 contre 71). Ce qui serait plus intéressant de mesurer c'est le temps d'acquisition d'un CD dans iTunes ou la gravure avec iDVD d'une bande vidéo.
La théorie est une chose mais la pratique en est une autre. -------------------- MacBook C2D + iPad 3G
![]() Modérateur multitâche ![]() ![]() ![]() ![]() ![]() Groupe : Modérateurs Messages : 11 682 Inscrit : 23 Dec 2001 Lieu : Paris Membre no 1 682 ![]() |
QUOTE(PHM74100 @ 2 Aug 2005, 09:54) C'est quand même nettement meilleur sur le CPU (61.83 contre 34.38) C'est dû à l'Altivec, XBench le privilégie beaucoup... -------------------- MacBook Air mid-2013 / Core i7 1.7 GHz / 8 Go / SSD 256 Go + SD 128 Go / OS X Yosemite 10.10
![]() Fumeur de processeurs ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 4 536 Inscrit : 22 May 2001 Lieu : Vive la bretagne! Membre no 282 ![]() |
Faut pas oublier le peu de fiabilité d'xbench...
Une différence de même pas 10 points sur un score de disque dur ne veut rien dire, en refaisant les tests, les scores peuvent être inversés. Surtout qu'un test de disque n'est vraiment fiable que sur un disque vide. -------------------- MacPro Nehalem 2.93 GHz 6 Go 2x150Go Velociraptor RAID Radeon HD4890 OC ; MBP CD 2.16 2Go 200Go@7200rpm
MacXtrem, l'overclock sur Mac. - Base de donnée d'overclock sur Mac - Overclocker un Titanium DVI - Overclocker un Powerbook Alu iClan : CoD-UO / UT / JdS / WoW - Powered by MacBidouille. |
QUOTE(Gamoul @ 2 Aug 2005, 12:59) Faut pas oublier le peu de fiabilité d'xbench... Une différence de même pas 10 points sur un score de disque dur ne veut rien dire, en refaisant les tests, les scores peuvent être inversés. Surtout qu'un test de disque n'est vraiment fiable que sur un disque vide. [right][snapback]1262465[/snapback][/right] Suis assez d'accord avec toi, pour être vraiment objectif j'avais pensé tester une opération de référence (par ex: encodage d'un CD dans iTunes) avant et après; mais j'ai oublié de chronométrer avant de démonter ma carte... -------------------- MacBook C2D + iPad 3G
Suis assez d'accord ... avec tout le monde. L'altivec est priviligié dans Xbench et c'est lui qui fait une grosse différence. Une différence de 10 point sur un disque ne veut rien dire. Mais, il faut comparer ce qui est comparable. Donc mon iMac G3 400 Dv et celui de PHM74100 qui a été vitaminé. Dans les XBench respectifs CPU et System ont quand même quasi triplés + 34 points et + 36 points. Si tu veux PHM je fait un encodage d'un CD dans iTunes et toi aussi et on aura des comparaisons plus parlantes. Mais là tout va jouer: la vitesse de mon DD, de mon lecteur, etc,..
le point le plus important avec l'upgrade du G4 c'est le gain de bande passante mémoire.
QUOTE(ecuamac @ 2 Aug 2005, 18:05) Suis assez d'accord ... avec tout le monde. L'altivec est priviligié dans Xbench et c'est lui qui fait une grosse différence. Une différence de 10 point sur un disque ne veut rien dire. Mais, il faut comparer ce qui est comparable. Donc mon iMac G3 400 Dv et celui de PHM74100 qui a été vitaminé. Dans les XBench respectifs CPU et System ont quand même quasi triplés + 34 points et + 36 points. Si tu veux PHM je fait un encodage d'un CD dans iTunes et toi aussi et on aura des comparaisons plus parlantes. Mais là tout va jouer: la vitesse de mon DD, de mon lecteur, etc,.. [right][snapback]1263087[/snapback][/right] Oui, là ça serait beaucoup plus parlant, fais l'opération avec un CD bien rempli et j'en cherche un avec le même nombre de morceaux et un minutage équivalent (style best of...) . Comme ça on poura mieux se faire une idée. -------------------- MacBook C2D + iPad 3G
Pour que le test soit valable, n'oubliez pas de convertir les morceaux en AIFF sur le disque avant. Si vous faites le test a partir du lecteur CD, ça ne vaudra pas grand chose.
Je viens de faire quelques tests pour ceux qui sont intéressés par cet upgrade. J'ai utilisé un PowerBook 12" 1.5GHz-512Mo comme machine de comparaison mais ecuamac pourra aussi nous donner quelques points de comparaison avec son iMac G3, le morceau est "Welcome to the pleasure dome" de Frankie goes to Hollywood 13:39 et 137.8Mo
Test 1 Importation dans iTunes depuis le CD iMac G3-G4 157sec PowerBoook 128sec Test 2 Copie du fichier sur disque iMac G3-G4 72sec PowerBook 129sec Je suis assez très satisfait de ce résultat, je voulais convertir le fichier un fois copié sur le disque (AIFF) mais il est grisé et je ne peux pas le sélectionner... Donc d'après ce que je comprends l'écart devrait être plus important mais le iMac compense grace à la rapidité du lecteur et du DD. Il faut donc tester à partir du DD pour avoir une comparaison du processeur. -------------------- MacBook C2D + iPad 3G
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 7 015 Inscrit : 13 Jul 2004 Lieu : 83 Membre no 20 969 ![]() |
Pour 200 $ ou 162 , cela me semble être vraiment une très bonne opération.
Dommage qu'il ne soit pas possible de changer la carte vidéo. -------------------- Macbook Air 13" M1 8 Go SSD 256 Go Mac os Sonoma 14.2.1 et Apple TV 4K tvOS 15.2 |
![]() Macbidouilleur d'Or ! ![]() ![]() ![]() ![]() ![]() Groupe : Membres Messages : 3 882 Inscrit : 29 Mar 2003 Lieu : Sud 77 (France) Membre no 6 884 ![]() |
QUOTE Pour 200 $ ou 162 , cela me semble être vraiment une très bonne opération. Tout à fait d'accord, on peu imaginer que fastmac réalise le même genre d'upgrade pour les MacMini et autre iMac G4 avec la prochaine génération de G4 bicore peut-être. QUOTE Dommage qu'il ne soit pas possible de changer la carte vidéo. C'est le point noir de cet upgrade....mais cela aurais aussi certainement causé une hausse de prix -------------------- Elle & lui:
- MacBook 12" Early 2015 Intel Core M@1,1Ghz Catalina - MacPro - 1st iPhone Edge / iPhone 8 / iPhone 13 / iPhone 13 Pro / iPhone 15 Pro Max / iPod Classic 160Go / Watch Série 1 & 7 Titane Vintage & Collection: PWM G3 B&W @450Mhz / 2xCube (500Mhz & 7448@1,7Ghz) / G4 Gigabit Sonnet @2x1,3Ghz / G4 DA OWC @2x1,4Ghz / G4 QS @2x1Ghz / PWB G4 Ti@1Ghz / iMac G4 15"@1Ghz / MDD FW800 @2x1,42Ghz / G4 MDD Sonnet MDX @2x1.83Ghz / (VRAI) MacMini G4@1,5Ghz / PWB G4 DLSD-HR@1,67Ghz / G5 2x2,7Ghz / G5 Quad@2,5Ghz / iMac G5 20"@2,1Ghz etc... |
![]() Macbidouilleur de vermeil ! ![]() ![]() ![]() ![]() Groupe : Membres Messages : 1 376 Inscrit : 25 Jun 2003 Lieu : Bruxelles Membre no 8 250 ![]() |
Et ou peut on trouver une carte mere + proc g4 550 Mhz?
-------------------- MacBook Pro 13' Core i5 2,3 Ghz - 8 Go - 750 Go (Momentus XT) - OS X Mountain Lion
iPhone 4 32 Gb Apple TV 3 Ancien matos: Macintosh SE/30, Macintosh Performa 6400/200, iMac DV G3 500 Mhz, iBook 12' G3 500 Mhz, iBook 14' G4 1.33 Ghz, Macbook Pro 15' 1.83 Ghz, Macbook Pro 13' unibody Core2Duo 2.26 Ghz, Macbook Pro 13' unibody Core2Duo 2.4 Ghz |
QUOTE(iMacX @ 9 Aug 2005, 09:52) Et ou peut on trouver une carte mere + proc g4 550 Mhz? [right][snapback]1270916[/snapback][/right] Bonjour, Probablement ici ![]() En fait il s'agit d'un échange standard http://www.fastmac.com/ProductPage/g4slimacup.php -------------------- Macbook Air 13" M1 8 Go SSD 256 Go Mac os Sonoma 14.2.1 et Apple TV 4K tvOS 15.2 |
QUOTE(iMacX @ 9 Aug 2005, 10:52) Et ou peut on trouver une carte mere + proc g4 550 Mhz? [right][snapback]1270916[/snapback][/right] Tu peux commander online chez Fastmac, le démontage est assez simple mais prends soin de bien protéger la carte pour l'envoi et d'installer le dernier firmware avant (4.1.9). J'ai mis une heure pour changer le lecteur DVD/CD, remonter la carte-mère et charger Tiger. Par contre j'attire ton attention sur le fait que j'ai aussi changé le DD, le lecteur DVD et doublé la mémoire (128+256--->512+256) donc l'ensemble donne des performances assez sympa c'est vrai. Dernier point à prendre en considération, c'est la carte ATI Rage pro (8M0...)qui reste telle quelle donc pas de jeux ni d'applications qui la soliciteraient. Est-ce que cette opération est financièrement raisonnable pour une machine qui garde une carte video de 1999 ? Pour moi oui mais c'est à chacun de juger en fonction de ses besoins ![]() -------------------- MacBook C2D + iPad 3G
Merci du renseignements mais une question, il renvoi une nouvelle carte mere ou il change simplement le proc de l'ancienne?
C'est vrai que c'est tentant... -------------------- MacBook Pro 13' Core i5 2,3 Ghz - 8 Go - 750 Go (Momentus XT) - OS X Mountain Lion
En parlant de booster le Mac
![]() Franchement pour 200 $ je me serais bien laissé tenter par çà : http://www.macway.com/product_info.php?cPa...roducts_id=3261 Pour mon G4 400 PCI, histoire de le remettre un peu dans la course ![]() Mais à 400 euros çà ne vaut pas le coup, le MINI MAC est à 500 euros. Ce message a été modifié par bob II - 9 Aug 2005, 14:08. -------------------- Macbook Air 13" M1 8 Go SSD 256 Go Mac os Sonoma 14.2.1 et Apple TV 4K tvOS 15.2 |
Fastmac change le processeur et ajoute de la mémoire cache L2 (1Mo au lieu de 512Ko) sur la carte-mère et te la renvoie. La mienne a été endommagée au retour et ils m'en ont envoyé une neuve, c'est comme ça que j'ai eu le Superdrive à un très bon prix
et ton iMac repond mieu sur Tiger je suppose!!(dashboard exposer....)
les jeux aussi?? sa été difficile de retirer ta carte mère?? en combien de jour tu as reçu la nouvelle carte?? lorsque je vais sur le site de fastmac et que je regarder les compatibiliter j'ai un iMac 600Mhz et il n'y figure pas!!!! à votre avi c'est possible de l'ugrapter en G4 550Mhz?? (le mien, voire signature) Ce message a été modifié par superparati - 18 Aug 2005, 16:17. -------------------- |---|rMacBook Pro i9 2,3Ghz / 16Go/ 512Go SSD / AMD 5500M / macOS Catalina & Windob 10
QUOTE(superparati @ 18 Aug 2005, 17:11) et ton iMac repond mieu sur Tiger je suppose!!(dashboard exposer....) les jeux aussi?? sa été difficile de retirer ta carte mère?? en combien de jour tu as reçu la nouvelle carte?? lorsque je vais sur le site de fastmac et que je regarder les compatibiliter j'ai un iMac 600Mhz et il n'y figure pas!!!! à votre avi c'est possible de l'ugrapter en G4 550Mhz?? (le mien, voire signature) [right][snapback]1283579[/snapback][/right] Oui, il fonctionne très bien sous Tiger 10.4.2, aucun soucis, avec dashboad aussi. Pour retirer la carte mère c'est 15-20 minutes j'ai collé les vis au scotch de carrossier sur le dossier à chaque étape pour ne pas les mélanger. Pareil pour le remontage. J'ai reçu ma carte 18 jours après l'avoir postée, elle part pour la Californie. Pour ton iMac, le mieux c'est de leur poser la question ils sont vraiment pro et sympa. -------------------- MacBook C2D + iPad 3G
oki merci
mais comment je peux leurs poser la question?? Ont-ils un Mail?? est-ce celui-la: [email protected] Ce message a été modifié par superparati - 19 Aug 2005, 09:42. -------------------- |---|rMacBook Pro i9 2,3Ghz / 16Go/ 512Go SSD / AMD 5500M / macOS Catalina & Windob 10
QUOTE(superparati @ 19 Aug 2005, 10:40) oki merci mais comment je peux leurs poser la question?? Ont-ils un Mail?? est-ce celui-la: [email protected] [right][snapback]1284346[/snapback][/right] Oui, vas-y ou d'une manière générale [email protected] dans une société le support va te répondre. Ou alors à la vente [email protected] mais en anglais. -------------------- MacBook C2D + iPad 3G
Je confirme au passage pour ceux qui sont intéressés que le graveur DVD interne Fastmac est complètement compatible avec iDVD et autres iApps
![]() Macbidouilleur de bronze ! ![]() ![]() Groupe : Membres Messages : 439 Inscrit : 26 Apr 2001 Lieu : Meudon Membre no 192 ![]() |
DayStar le propose aussi mais avec un G4 600.
http://4daystar.com/index.asp?PageAction=VIEWPROD&ProdID=317 Pour le iMac G4 700/800 jusqu'à 1,35Ghz et 1,92Ghz ![]() http://4daystar.com/index.asp?PageAction=VIEWPROD&ProdID=496 Et aussi le Titanium en G4 550 : http://4daystar.com/index.asp?PageAction=VIEWPROD&ProdID=241 Pas mal un iMac G4 à 1,92 Ghz, bon un peu cher quand même... |
et cela est possible pour un iMac G3 600Mhz???
je veux l'augmenté et aucun moyen ![]() -------------------- |---|rMacBook Pro i9 2,3Ghz / 16Go/ 512Go SSD / AMD 5500M / macOS Catalina & Windob 10
Nous sommes le : 13th June 2024 - 09:58 |
