> Sed et suppression retour chariot [Résolu], Comment supprimer \n avec sed
malou50
posté 30 Jun 2005, 08:54
Inscrit : 17 Dec 2003
Membre no 12 577
J'essaye de supprimer le \n , retour chariot, en fin de certaine ligne avec sed mais je n'y
arrive pas.
je l'utilise comme suivant :
CODE
sed "s/\n//g" test1.txt > test2.txt
Le problème est qu'il ne me remplace pas les \n par "rien" ni même autre chose, j'ai essayé.
Auriez vous une idée.
Si je ne suis pas assez claire n'hesitez pas à me le dire.
merci
Ce message a été modifié par malou50 - 30 Jun 2005, 08:54.
_Olivier_
posté 30 Jun 2005, 09:15
- Macbidouilleur d'Or !
Inscrit : 23 Aug 2002
Lieu : Grandmetz (Belgique, Leuze)
Membre no 3 222
Trouvé dans la FAQ sed
CODE
5.10. Why can't I match or delete a newline using the \n escape               |
     sequence? Why can't I match 2 or more lines using \n?                   |
  The \n will never match the newline at the end-of-line because the         |
  newline is always stripped off before the line is placed into the          |
  pattern space. To get 2 or more lines into the pattern space, use          |
  the 'N' command or something similar (such as 'H;...;g;').                 |
  Sed works like this: sed reads one line at a time, chops off the           |
  terminating newline, puts what is left into the pattern space where        |
  the sed script can address or change it, and when the pattern space        |
  is printed, appends a newline to stdout (or to a file). If the             |
  pattern space is entirely or partially deleted with 'd' or 'D', the        |
  newline is *not* added in such cases. Thus, scripts like                   |
     sed 's/\n//' file       # to delete newlines from each line             |
     sed 's/\n/foo\n/' file  # to add a word to the end of each line         |
  will NEVER work, because the trailing newline is removed _before_          |
  the line is put into the pattern space. To perform the above tasks,        |
  use one of these scripts instead:                                          |
     tr -d '\n' < file              # use tr to delete newlines              |
     sed ':a;N;$!ba;s/\n//g' file   # GNU sed to delete newlines             |
     sed 's/$/ foo/' file           # add "foo" to end of each line          |
  Since versions of sed other than GNU sed have limits to the size of        |
  the pattern buffer, the Unix 'tr' utility is to be preferred here.         |
  If the last line of the file contains a newline, GNU sed will add          |
  that newline to the output but delete all others, whereas tr will          |
  delete all newlines.                                                       |
  To match a block of two or more lines, there are 3 basic choices:          |
  (1) use the 'N' command to add the Next line to the pattern space;         |
  (2) use the 'H' command at least twice to append the current line          |
  to the Hold space, and then retrieve the lines from the hold space         |
  with x, g, or G; or (3) use address ranges (see section 3.3, above)        |
  to match lines between two specified addresses.                            |
  Choices (1) and (2) will put an \n into the pattern space, where it        |
  can be addressed as desired ('s/ABC\nXYZ/alphabet/g'). One example         |
  of using 'N' to delete a block of lines appears in section 4.13            |
  ("How do I delete a block of _specific_ consecutive lines?"). This         |
  example can be modified by changing the delete command to something        |
  else, like 'p' (print), 'i' (insert), 'c' (change), 'a' (append),          |
  or 's' (substitute).                                                       |
  Choice (3) will not put an \n into the pattern space, but it _does_        |
  match a block of consecutive lines, so it may be that you don't            |
  even need the \n to find what you're looking for. Since GNU sed            |
  version 3.02.80 now supports this syntax:                                  |
     sed '/start/,+4d'  # to delete "start" plus the next 4 lines,           |
  in addition to the traditional '/from here/,/to there/{...}' range         |
  addresses, it may be possible to avoid the use of \n entirely.             |
Donc, un tr -d '\n' < file > file_sans_CR fonctionne...
C'était une question intéressante !
* Rejoignez-nous sur le chan IRC de MacBidouille !
malou50
posté 30 Jun 2005, 09:29
Membre no 12 577
Merci beaucoup pour la réponse, ça marche
Ce message a été modifié par malou50 - 30 Jun 2005, 09:33.
_Olivier_
posté 30 Jun 2005, 09:35
Membre no 3 222
Ah diable... sous Mac OS X, la commande sed ':a;N;$!ba;s/\n//g' file ne fonctionne pas.
malou50
posté 30 Jun 2005, 09:48
Membre no 12 577
enlève les '
Nous sommes le : 30th October 2025 - 05:51
