CLIX : un nouvel utilitaire pour MacOs X, Freeware |
12 Apr 2004, 11:18
Macbidouilleur d'Or ! Groupe : Modérateurs Messages : 3 058 Inscrit : 18 May 2002 Lieu : Base de la tranquilité/Planéte Lune/Cratére n°3. Membre no 2 501 |
Lu ce jour dans ADC News:
CLIX 1.1 from Rixstep is an command-line interface for Mac OS X with an Aqua look-and-feel. It includes 344 system commands for investigating and cleaning your system, improving security, and more. Version 1.1 adds over 80 new commands. CLIX veut dire : Command Line Interface for OS X Téléchargeable Ici Nombreuses fonctions (je recopie ci dessous la page du site, je n'ai pas encore testé): The full list of CLIX commands. Global Settings Beep Feedback - turn it on, off, read the current setting. Color Variant - set to Aqua, graphite, read the current setting. Scroll Bar - set to single, double both, double max, double min, read the current setting. Address Book Debug Menu - turn it on, off, read the current setting. Clean-ups Clean .DS_Store files. Clean .localized files. Clean .MCXLC files. Clean Interface Builder, Project Builder, Xcode preferences. Clean caches. Clean Calculator files. Clean Camino files. Clean CUPS files. Clean Desktop files. Clean DVD scripts. Clean file panel preferences, read current settings. Clean finder preferences. Clean Full Circle files Clean icon caches. Clean launch services caches. Clean log files. Clean Mail files. Clean preference panes caches. Clean receipts. Clean recent folders, read current settings. Clean Safari files. Clean temporary files. Developer Show default GCC specs. Show default GCC version info. Disk Check a RAID set for errors. Show free disk space. Show fixed disk info. Show disk usage statistics. Enable, disable disk journaling. Verify, repair volume structures. Verify, repair volume permissions. Get information on boot volume. Show mounted drive info. DiskCopy Expert Mode - turn it on, off, read the current setting. Dock Autohide - turn it on, off, read the current setting. Launch Animation - turn it on, off, read the current setting. Magnification - turn it on, off, read the current setting. Mineffect - use Genie, Scale, Suck, the default, read the current setting. Orientation - put dock at bottom, left, right top, read the current setting. Show persistent apps. Pinning - pin the dock at the start, middle, end, read the current setting. QuitFinder - show/hide Quit menu item for Finder in Dock, read the current setting. Shadow - show/hide shadow in Dock, read the current setting. Show All Files - show/hide all files in Dock, read the current setting. Show Hidden - show/hide hidden files in Dock, read the current setting. DVD Player Debug Menu - enable, disable, read the current setting. Finder Animate Info Panes - enable, disable, read the current setting. Animate Window Zoom - enable, disable, read the current setting. Finder Quit - show/hide Quit menu item, read the current setting. Maximum Label Lines - set to 1, 2, 3, the default, read the current setting. Show All Files - show/hide all files, read the current setting. Zoom Rects - enable, disable, read the current setting. Lists List all .DS_Store files in home directory. List all .DS_Store files on hard drive. List all .app packages in home directory. List all .app packages on hard drive. List contents of backups directory. List contents of cron directory. List contents of etc directory. List file types in /bin. List file types in /sbin. List file types in standard system directories. List file types in /usr/bin. List frameworks in home directory. List frameworks at root. List all library directories. List lsof version info. List contents of NetInfo directory. List all NIBs in home directory. List all NIBs on hard drive. List open files. List contents of openldap directory. List open network files. List open Unix domain sockets. List fixed disk partitions. List all plists in home directory. List all plists on hard drive. List all preferences directories. List contents of private directory. List contents of root home directory. List contents of samba directory. List screen savers in home directory. List screen savers on hard drive. List set IDs in standard system directories. List set gids in /bin. List set gids in /sbin. List set gids in standard system directories. List set gids in /usr/bin. List set uids in /bin. List set uids in /sbin. List set uids in standard system directories. List set uids in /usr/bin. List contents of spool directory. List contents of sudo directory. List symlinks in /sbin. List symlinks in /usr/bin. List contents of temporary directory. List contents of .Trash directory. List contents of .Trashes directory. List contents of var directory. List contents of vm directory. Log View CUPS access log. View CUPS error log. View daily.out log. View console log. View monthly.out log. View system log. View weekly.out log. View NetInfo log. Network Curl Apple front page. Curl Rixstep front page. Show network status per process. Show network status of routing tables. Show network status. Show NFS status. Ping root-servers. Show current Samba connections. Process Show process status. Show system usage statistics. Purge Purge .DS_Store files. Purge .localized files. Purge .MCXLC files. Purge Interface Builder, Project Builder, Xcode preferences. Purge caches. Purge Calculator files. Purge Camino files. Purge CUPS files. Purge Desktop files. Purge DVD scripts. Purge file panel preferences, read current settings. Purge finder preferences. Purge Full Circle files Purge icon caches. Purge launch services caches. Purge log files. Purge Mail files. Purge preference panes caches. Purge receipts. Purge recent folders, read current settings. Purge Safari files. Purge temporary files. Safari Anti-aliasing, smooth fonts - set values high, low, restore defaults, read the current settings. IE Favorites Imported - set on, off, read the current setting. Include Debug Menu - enable, disable, read the current setting. Netscape/Mozilla Favorites Imported - set on, off, read the current setting. System Show local date and time. Show local and UTC date and time. Show UTC date and time. Show all defaults. Show global defaults. Show launch services defaults. Show root defaults. Show user defaults. Show system message buffer. Show file status. Show name of current host system. Dump entire I/O Kit registry to disk and open in text editor. Purge intermediate dump file. Show I/O Kit registry with busy state and retain count. Show I/O Kit registry. Show I/O statistics. Show status of kernel extensions. Show available devices and drivers. Show CUPS status information. Show machine type. Show command path. Run all periodic functions. Run daily periodic function. Run monthly periodic function. Run weekly periodic function. Show info on open files. Show info on terminals. Show info on active vnodes. View environment variables. Flush file caches to disk. Show system and build versions. Get kernel state. Show hardware statistics. Show kernel statistics. Show network statistics. Read system logs. Show timeslicing quantum (microseconds). Show table of terminfo entries. Show operating system name. Show how long system has been running. Show name and uid for current user. Show NetInfo dump file. View contents of root hidden file. View SystemConfiguration preferences. Show MACH virtual memory statistics. Show who is logged in Show effective user ID. -------------------- Hackeur vaillant ... rien d'impossible ! Mac Pro "corbeille" 2013 3,7 Ghz, SSD 500 Go, + Ecran Nec 30"/ iMac Retina 2014, 4 GHz, écran 27 " / Mac Pro "camion" 2008 / Imac G4 Tournesol 1,25 GHz 20" , modifié Mac Mini M1/ Cube G4 boosté à 1,8Ghz avec carte Gigadesign +Geforce 6200+AppleDisplay 23" / Spartacus upgradé G3 / MacBook polycarbonate 2011 / MacBook pro 17 pouces / Freebox Révolution V6 / Wifi Mesh avec 4 boitiers Tenda Nova MW6 |
12 Apr 2004, 11:24
Macbidouilleur d'Or ! Groupe : Membres Messages : 1 582 Inscrit : 2 Dec 2002 Lieu : Geneva by Night Membre no 4 980 |
Ok quelles sont les comamndes qu'il faut exécuter pour tenter d'améliorer les perfs du système?
-------------------- [MacBook 1,83Ghz ] Email: [email protected] - MSN: [email protected] - IChat: [email protected] Mac - Medecine |
14 Apr 2004, 09:24
Macbidouilleur d'Or ! Groupe : Membres Messages : 2 238 Inscrit : 4 Jul 2002 Lieu : Le Mans Membre no 2 835 |
Chez moi le lien download me rend une page qui n'existe pas...
-------------------- " - chuis fatigué... T'es pas fatigué toi ?
- Je frise le coma" |
14 Apr 2004, 09:33
QUOTE (malhomme @ 14 Apr 2004, 09:24) Chez moi le lien download me rend une page qui n'existe pas... Curieux...Je viens de le re-tester = ça marche chez moi J'en profite pour préciser que Clix utilise les commandes du terminal, en les visualisant telles que, donc c'est un bon truc pour apprendre le langage de ce Terminal.. -------------------- Hackeur vaillant ... rien d'impossible ! Mac Pro "corbeille" 2013 3,7 Ghz, SSD 500 Go, + Ecran Nec 30"/ iMac Retina 2014, 4 GHz, écran 27 " / Mac Pro "camion" 2008 / Imac G4 Tournesol 1,25 GHz 20" , modifié Mac Mini M1/ Cube G4 boosté à 1,8Ghz avec carte Gigadesign +Geforce 6200+AppleDisplay 23" / Spartacus upgradé G3 / MacBook polycarbonate 2011 / MacBook pro 17 pouces / Freebox Révolution V6 / Wifi Mesh avec 4 boitiers Tenda Nova MW6 |
Guest_Avid_* |
14 Apr 2004, 15:48
Effectivement, j'apprécie !... c'est riche d'enseignements
Voilà le genre de soft qui encourage à aller encore plus loin dans la connaissance du système... Pour ce qui est du lien de téléchargement, c'est vrai il semble cassé. En revanche, celui qui est en bas de cette page fonctionne > ICI |
14 Apr 2004, 23:32
Macbidouilleur de vermeil ! Groupe : Membres Messages : 1 285 Inscrit : 7 Jul 2003 Lieu : 77 Membre no 8 476 |
Les 2 liens fonctionnent. Ça donne le fichier CLIX.tar 2.bz2
Mais je télécharge en OS9... qui est mon système 95% du temps à la maison! -------------------- The best way to get rid of a temptation is to yield to it!
G4 AGP 400 MHz |
12 Jun 2004, 10:08
Une nouvellle version est sortie, la 1.2 :
CLIX 1.2 from Rixstep is an command-line interface for Mac OS X with an Aqua look-and-feel. Version 1.2 adds over 400 startup commands. http://rixstep.com/4/0/clix/ -------------------- Hackeur vaillant ... rien d'impossible ! Mac Pro "corbeille" 2013 3,7 Ghz, SSD 500 Go, + Ecran Nec 30"/ iMac Retina 2014, 4 GHz, écran 27 " / Mac Pro "camion" 2008 / Imac G4 Tournesol 1,25 GHz 20" , modifié Mac Mini M1/ Cube G4 boosté à 1,8Ghz avec carte Gigadesign +Geforce 6200+AppleDisplay 23" / Spartacus upgradé G3 / MacBook polycarbonate 2011 / MacBook pro 17 pouces / Freebox Révolution V6 / Wifi Mesh avec 4 boitiers Tenda Nova MW6 |
12 Jun 2004, 11:22
Macbidouilleur de bronze ! Groupe : Membres Messages : 313 Inscrit : 18 May 2004 Lieu : Bruxelles Membre no 18 957 |
heu... pardon de poser une question débile, mais comment on fait pour rentrer son mot de passe quand il le demande ???
Par exemple, quand on fait "verify disk" -------------------- Apple MacBook Pro mid-2012 i7 2,6 GHz
Apple iPhone 6S plus 128GB Sideral grey |
12 Jun 2004, 15:14
Macbidouilleur de vermeil ! Groupe : Membres Messages : 1 063 Inscrit : 28 Sep 2002 Lieu : St-Quentin-en-Yvelines (78) Membre no 3 818 |
Salut
Le password est saisi via le menu "Edit" puis "Sudo..." Cordialement Ritchi -------------------- iMac Alu 24" Mid-2007 , Core2Duo 2,4GHz / 6Go / 1To - El Capitan MacBook Pro 15" Mid-2010, Core i5 2.53Ghz / 8Go / 500Go - Sierra (pour ma p'tite femme chérie) MacBook Pro 13" Mid-2011, Core i5 2,3 GHz / 8Go / 1To, Sierra MacBook Blanc 13" - Snow Leopard - Batterie HS iMac G4 17" 1,25GHz, 1024Mo, 160Go interne, Leopard (libre service) FreeBox V6 Scanner Epson Perfection 610 Imprimante HP LaserJetPro M203dn (Laser Monochrome) Et le tout en réseau Ethernet et ça gazouille impeccablement ... ____ Membre du club des AIPBP (Anciens Inscrits Pas Beaucoup de Posts) Voir la liste |
12 Jun 2004, 15:31
thanks a lot
Nous sommes le : 28th April 2024 - 11:14 |
