[Résolu] Applications défaillantes, Certaines apps plantent spontanément. |
19 Oct 2023, 11:11
Macbidouilleur de vermeil ! Groupe : Membres Messages : 1 314 Inscrit : 12 Aug 2012 Lieu : Vraisemblablement face à un ordinateur. Membre no 178 135 |
Salut ! Alors, ma restauration s'est plutôt bien déroulée, mais un autre soucis étrange se profile.
Depuis ma restauration en catastrophe de Sonoma à Ventura 13.5.1, certaines applications ne fonctionnent plus. Si j'ouvre l'exécutable UNIX du "truc.app/Content/MacOS/", les messages que j'obtiens sont toujours similaires : Voici par exemple ce qui se passe avec l'application XPeria Companion : Code ❯ /Applications/Xperia\ Companion.app/Contents/MacOS/Xperia\ Companion; exit; objc[2014]: Class MTPCommunicationMac is implemented in both /Applications/Xperia Companion.app/Contents/Frameworks/phonebrowser.framework/Versions/A/phonebrowser (0x109e9da18) and /Applications/Xperia Companion.app/Contents/MacOS/Xperia Companion (0x109a8ff60). One of the two will be used. Which one is undefined. [1019/115943.363797:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 1 time(s) [1019/115943.392311:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 2 time(s) [1019/115943.419298:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 3 time(s) [1019/115943.447838:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 4 time(s) [1019/115943.474074:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 5 time(s) [1019/115943.500331:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 6 time(s) [1019/115943.527053:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 7 time(s) [1019/115943.556525:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 8 time(s) [1019/115943.588371:WARNING:gpu_process_host.cc(1205)] The GPU process has crashed 9 time(s) [1019/115943.588425:FATAL:gpu_data_manager_impl_private.cc(897)] The display compositor is frequently crashing. Goodbye. [1] 2014 trace trap /Applications/Xperia\ Companion.app/Contents/MacOS/Xperia\ Companion Saving session...[1019/115943.599468:ERROR:mach_port_broker.mm(48)] bootstrap_look_up com.sonymobile.Xperia-Companion.rohitfork.1: Unknown service name (1102) [1019/115943.601077:ERROR:mach_port_rendezvous.cc(307)] bootstrap_look_up com.sonymobile.Xperia-Companion.MachPortRendezvousServer.1: Unknown service name (1102) completed. Voici ce qui se passe avec le Minecraft Launcher : Code /Applications/Minecraft.app/Contents/MacOS/launcher; exit; ❯ /Applications/Minecraft.app/Contents/MacOS/launcher; exit; 2023-10-19 12:17:30.489 launcher[3036:46976] Claimed it found a path: /Applications/Minecraft.app/Contents/MacOS/launcher (/Applications/Minecraft.app/Contents/MacOS/launcher) 4096 [1019/121733.782649:INFO:main_context.cpp(131)] CEF initialized successfully. [1019/121733.829977:INFO:main_context.cpp(133)] CEF version: 99.2.14+g3f796b8+chromium-99.0.4844.84 [1019/121734.803218:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121734.803298:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 1 time(s) [1019/121735.026790:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.120242:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.238789:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121735.238862:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 2 time(s) [1019/121735.295451:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.346653:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.394859:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.443885:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.448974:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121735.449035:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 3 time(s) [1019/121735.493067:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.545123:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.591970:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.640220:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.688055:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.737243:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.775890:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121735.775944:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 4 time(s) [1019/121735.785820:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.836466:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.890969:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.942666:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121735.993297:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.003671:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121736.003737:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 5 time(s) [1019/121736.044012:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.093843:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.188379:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.237859:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121736.237907:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 6 time(s) [1019/121736.240222:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.289073:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.338034:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.403801:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.426626:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121736.426677:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 7 time(s) [1019/121736.455523:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.507806:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.555139:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.601720:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121736.601776:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 8 time(s) [1019/121736.609548:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.663058:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.714874:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.767079:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service. [1019/121736.783122:ERROR:gpu_process_host.cc(972)] GPU process exited unexpectedly: exit_code=9 [1019/121736.783174:WARNING:gpu_process_host.cc(1277)] The GPU process has crashed 9 time(s) [1019/121736.783203:FATAL:gpu_data_manager_impl_private.cc(447)] GPU process isn't usable. Goodbye. [1] 3036 trace trap /Applications/Minecraft.app/Contents/MacOS/launcher On dirait qu'il y a un soucis avec la prise en charge de ma Radeon RX480. Elle est bien identifiée par le système, avec toute sa VRAM, et j'utilise la dernière version de WateverGreen. J'ai l'impression que toutes les applications incriminées utilisent Elecrton. Cependant, Discord, qui utilise aussi Electron, fonctionne parfaitement. Donc pas sûr que ça aide à trouver une solution. Il s'agit d'un Hackintosh Clover 5155. Que je n'ai jamais réussi à faire passer sous OpenCore. Il n'a jamais démarré avec malgré de nombreux essais. Ce message a été modifié par Sirix1995 - 4 Nov 2023, 08:10. -------------------- PowerMac G5 Fin 2005 975MP dual core 2 Ghz, 8 Go DDR2 RAM, 2xGeForce 6600(LE) 128/256 Mo VRAM, SuperDrive, HDD 150 Go et 500 Go Mac OS 10.4.11/10.5.8, 7 à 9/XP via émulateurs et Classic
20 Oct 2023, 07:35
Macbidouilleur d'Or ! Groupe : Membres Messages : 1 904 Inscrit : 20 Aug 2020 Lieu : Belgique Membre no 212 269 |
Est-ce que tu as patch particulier pour ta Radeon ? (Framebuffer, fake ID ou autre)
-------------------- Hackintosh13 "Photo" : Asus Gryphon Z87 i7-4770K 2x8GB DDR3, XFX RX6800XT, SSD SATA 4TB WD Red, MacOS 12.7.1 Monterey, Clover 5146
21 Oct 2023, 12:12
Non, rien du tout, juste WateverGreen. Ah, j'ai peut-être aussi le kext RadeonBoost, je sais pas si je l'ai retiré. Mais avant ça marchait avec.
21 Oct 2023, 17:47
Je n'utilise pas ces applications, je ne saurais dire
Juste que je n'ai pas un bon feeling avec Sonoma, je vais repasser à Monterey -------------------- Hackintosh13 "Photo" : Asus Gryphon Z87 i7-4770K 2x8GB DDR3, XFX RX6800XT, SSD SATA 4TB WD Red, MacOS 12.7.1 Monterey, Clover 5146
24 Oct 2023, 08:50
Personnellement comme je disais, je suis revenu à Ventura, où tout fonctionnait, mais il y a eu visiblement un soucis avec la restauration...
27 Oct 2023, 08:09
Re ! J'ai tenté, sur conseil de la communauté Reddit Anglohpne, de réinstaller macOS. L'install s'est bien passée, mais le soucis n'est pas résolu. Cependant, il m'est venu une idée que je vais essayer ce soir : créer un nouveau compte et voir ce qu'il se trame dessus.
28 Oct 2023, 09:36
Bon, depuis une autre session, ça ne fonctionne pas non plus. Du coup, j'ai relancé le vieil utilitaire de rapport de MacBidouille. Est-ce que ça peut aider ? Voilà le résultat !
https://cdn.discordapp.com/attachments/6055...9b80d388c5& -------------------- PowerMac G5 Fin 2005 975MP dual core 2 Ghz, 8 Go DDR2 RAM, 2xGeForce 6600(LE) 128/256 Mo VRAM, SuperDrive, HDD 150 Go et 500 Go Mac OS 10.4.11/10.5.8, 7 à 9/XP via émulateurs et Classic
30 Oct 2023, 13:45
Personne ? Je désespère un peu, avec ce soucis...
4 Nov 2023, 08:09
Re ! Finalement, j'ai trouvé la cause du soucis. C'était un argument de démarrage que j'avais mis pour tenter de faire marcher Sonoma qui visiblement mettait le bazar ! Il s'agissait de -amfi=0x80. Je ne sais pas trop ce qu'est l'amfi. Je connais le SIP (ou crsutil), mais ça, je sais pas, j'avais trouvé l'astuce sur Reddit. Enfin, au moins on sait ce qu'il se passe.
4 Nov 2023, 08:25
Jamais entendu parler de cet argument. Mon Hackintosh no12 tourne avec Sonoma sans ça
Cool que tu aies trouvé -------------------- Hackintosh13 "Photo" : Asus Gryphon Z87 i7-4770K 2x8GB DDR3, XFX RX6800XT, SSD SATA 4TB WD Red, MacOS 12.7.1 Monterey, Clover 5146
4 Nov 2023, 08:52
Jamais entendu parler de cet argument. Mon Hackintosh no12 tourne avec Sonoma sans ça Cool que tu aies trouvé Ce boot arg (sans le "-" ) est utilisé avec OpenCore (en lien avec le Kext AMFIPass) pour, au sein d'une procédure décrite ici, activer le Wifi de cartes Broadcom non prises en charge par Sonoma. Cette procédure n'est pas (pour le moment !) compatible avec Clover et l'utilisation de boot args ou (et) Kexts concernés par ladite procédure peut, en effet, engendrer des dysfonctionnements... Ce message a été modifié par mbournau - 4 Nov 2023, 08:56. -------------------- Gigabyte Z390 Designare : Core i9-9900K 3.6GHz ; 32Go RAM ; Radeon RX 580 8Go // OC 0.9.9 & Clover 5157 (MacPro7,1) :
4 Nov 2023, 16:35
Ah, ok. Je n'en ai pas besoin, vu que je n'utilise pas le Wifi
Merci pour cette précision |
Nous sommes le : 27th April 2024 - 09:12 |
