[Need support] [Advise EFI] Z370-E I7-8700 and RX480, Support advise EFI to optimal the system. |
7 Mar 2020, 12:44
Nouveau Membre Groupe : Membres Messages : 3 Inscrit : 6 Mar 2020 Membre no 210 844 |
My friend shared his EFI working well, but it takes long time to boot up.
And it take ~10seconds to enter clover show that: "Starting AppleUISupport ver 2.0.9... AIFTimerBoostInit Current time is 10000 gST --> ConIn AFB36918 vs found AFB36918 " Can I disable and optimal my clover EFI? Anyone can review my EFI folder and advise? here is my EFI: https://1drv.ms/u/s!AmRivw5g2-U5g9MyJ_D...tw46AQ?e=Gg6aH4 My Build: Asus Strix Z370E I7-8700es saphire RX480 Ce message a été modifié par IamCuCai - 7 Mar 2020, 12:47. |
7 Mar 2020, 18:52
I'm sorry but this is an exclusively French speaking Forum. If you need help, I invite you to post your issue on InsanelyMac Forum or any English speaking Forum of your choice. FYI, This topic is now closed. Best regards, The moderator team -------------------------------------------------- Bonjour, Désolé mais ce Forum est exclusivement francophone. Si vous avez besoin d'aide, je vous invite à poster votre problème sur InsanelyMac ou tout autre Forum anglophone de votre choix. Pour information, ce sujet est désormais fermé. Cordialement, L'équipe de modération -------------------- Un Mac • macOS 10.15.7 MacBook Air mi-2012 Core i5 1,7 GHz Intel HD 4000 SSD 64 Go
Nous sommes le : 28th April 2024 - 17:18 |
