[Résolu] Faire fonctionner Sage 4.6 |
17 Nov 2010, 16:19
Nouveau Membre Groupe : Membres Messages : 20 Inscrit : 31 May 2008 Membre no 115 148 |
j'ai téléchargé le programme Sage 4.6 sous Mac OS X (Intel) qui est en open source. Il s'agit d'un logiciel de mathématiques. Mais lorsque j'ai double-cliqué sur "terminal" j'ai obtenu ce message: /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 58: .BUILDSTART: Permission denied mkdir: /Users/local: Permission denied mkdir: /Users/local: No such file or directory usage: cp [-R [-H | -L | -P]] [-fi | -n] [-pvX] source_file target_file cp [-R [-H | -L | -P]] [-fi | -n] [-pvX] source_file ... target_directory mkdir: /Users/spkg: Permission denied /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 105: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 108: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 111: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 120: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 123: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 126: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 129: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 132: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 135: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 138: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 141: standard/newest_version: No such file or directory /Volumes/sage-4.6-OSX-64bit-10.6-i386-Darwin/sage/spkg/install: line 144: standard/newest_version: No such file or directory Error determining package name using spkg/standard/newest_version script. logout Ce logiciel ne serait pas libre? Ce message a été modifié par tachoupi - 19 Nov 2010, 17:51. |
17 Nov 2010, 16:43
Macbidouilleur d'Or ! Groupe : Membres Messages : 2 241 Inscrit : 27 Oct 2006 Lieu : Toulouse Membre no 71 475 |
Salut
Je pense que l'installation doit se faire en mode root pour avoir les permissions nécessaires pour créer les différents répertoires lance l'install en tapant sudo xxxxxxx et tape ton password quand il te le demandera. En principe la devrait le faire -------------------- ******
(\__/) Mac Mini G4 1.25 Ghz, 1Go RAM, DD 120Go/Mini Partner 500Go/Ecran plat Philips 19" (='.'=) Macbook Blanc C2D 2ghz,4Go ram,DD 500Go + Ecran Samsung 24" (")_(") Ibook G4 1.33 Ghz, 1.25 Go RAM, DD 160Go Merci à Neuf50 pour m'avoir permis de le ressusciter ****** Shuffle 2g 1Go/Ipod Nono 8Go/Ipod 5g 30 Go Black/Ipod 5g 80 Go Black |
17 Nov 2010, 18:41
Macbidouilleur de vermeil ! Groupe : Membres Messages : 1 336 Inscrit : 19 May 2003 Lieu : Vendée Membre no 7 668 |
Mais lorsque j'ai double-cliqué sur "terminal" Double-cliquer sur Terminal, ça ne veut pas dire grand chose. Le terminal est fait pour y saisir des lignes de commandes. Par exemple, pour installer un paquet open source, le plus souvent, il faut saisir les commandes: configure, puis make ou make install. Je suppose qu'il y a dans le paquet un fichier du type README dans lequel la procédure d'installation est indiquée. -------------------- [size=1]iMac 24", M1, 1To, 16 Go, Sonoma 14.1
iMac 24', 650 Go, Ram 4 Go, Intel Core 2 Duo 3.06 GHz, OS X 10.10.5 Airport Express 7.6.1 - Time Capsule 2 To 7.6.1 - iPod classic 160 Go |
18 Nov 2010, 18:25
Volià ce qu'il me dit:
Select to run it with "Terminal": Choose Applications, then select "All Applications" in the "Enable:" drop down. Change the "Applications" drop down to "Utilities". On the left, scroll and select "Terminal". Click "Open", then in the next dialog select "Update". J'ai donc ouvert Terminal mais choisir applications, je n'arrive pas à le faire. Et encore moins d'aller sur "Enable". J'ai testé la commande "Enable" mais il m'indique que ce n'est pas un shell builtin. |
18 Nov 2010, 19:19
En clair, il explique comment ouvrit le Terminal: aller dans le répertoire Applications, descendre au bas de la fenêtre, aller dans le répertoire Utilitaires et cliquer sur Terminal pour l'ouvrir. Par contre, je ne vois pas ce qu'il veut dire par Update: faut-il commencer par lancer une mise à jour de Sage?
Pour faire fonctionner le programme, il faut placer le répertoire sage dans Applications. Ensuite, avec le terminal, aller dans le répertoire /Applications/sage, puis taper la commande ./sage, puis notebook(). Là le programme demande un mot de passe et sa confirmation. Si le navigateur web est ouvert, une fenêtre s'ouvre pour faire fonctionner sage. Récapitulatif des commandes de terminal: Code % cd /Applications/sage % ./sage ---------------------------------------------------------------------- | Sage Version 4.6, Release Date: 2010-10-30 | | Type notebook() for the GUI, and license() for information. | ---------------------------------------------------------------------- sage: notebook() The notebook files are stored in: sage_notebook.sagenb Please choose a new password for the Sage Notebook 'admin' user. Do _not_ choose a stupid password, since anybody who could guess your password and connect to your machine could access or delete your files. NOTE: Only the md5 hash of the password you type is stored by Sage. You can change your password by typing notebook(reset=True). Enter new password: Retype new password: Please login to the notebook with the username 'admin' and the above password. Password changed for user 'admin'. ************************************************** * * * Open your web browser to http://localhost:8000 * * * ************************************************** 2010-11-18 19:14:04+0100 [-] Log opened. 2010-11-18 19:14:04+0100 [-] twistd 9.0.0 (/Applications/sage/local/bin/python 2.6.4) starting up. 2010-11-18 19:14:04+0100 [-] reactor class: twisted.internet.selectreactor.SelectReactor. 2010-11-18 19:14:04+0100 [-] twisted.web2.channel.http.HTTPFactory starting on 8000 2010-11-18 19:14:04+0100 [-] Starting factory <twisted.web2.channel.http.HTTPFactory instance at 0x10a3ddc20> Pour le reste, je ne sais rien de ce programme. Pour quitter sage dans le Terminal, taper tout simplement: quit Ce message a été modifié par fgiron - 18 Nov 2010, 19:23. -------------------- [size=1]iMac 24", M1, 1To, 16 Go, Sonoma 14.1
19 Nov 2010, 11:44
après la procédure que vous m'avez indiqué, après notebook(), il ne me demande pas de password, j'ai directement le signe > Ensuite, en allant, avec Safari, sur http://localhost:8000, Safari me dit : Safari ne parvient pas à ouvrir la page « http://localhost:8000/ » car Safari ne peut pas se connecter au serveur « localhost ». Ensuite, j'ai essayé de cliquer sur certaines icônes mais cela ne fonctionne pas. |
19 Nov 2010, 11:59
C'est parce que vous avez lancé la commande notebook() sans lancer sage. Il faut d'abord lancer la commande ./sage, puis apparaît dans le terminal la fenêtre de dialogue de sage. Alors juste après 'sage:', vous tapez notebook().
Code $ ./sage
---------------------------------------------------------------------- | Sage Version 4.6, Release Date: 2010-10-30 | | Type notebook() for the GUI, and license() for information. | ---------------------------------------------------------------------- sage: notebook() -------------------- [size=1]iMac 24", M1, 1To, 16 Go, Sonoma 14.1
19 Nov 2010, 14:37
Exact, vous avez raison. Lorsque je fais ./sage, il ne me lance pas sage. Pourtant j'ai
imac-monnom:sage monnom$ et à ce moment je fais imac-monnom:sage monnom$./sage et j'obtient le message ---------------------------------------------------------------------- | Sage Version 4.6, Release Date: 2010-10-30 | | Type notebook() for the GUI, and license() for information. | ---------------------------------------------------------------------- dyld: unknown required load command 0x80000022 /Applications/sage/local/bin/sage-sage: line 170: 985 Trace/BPT trap "$SAGE_ROOT/local/bin/"sage-location Et, dans mon finder, dans Applications, j'ai le dossier "sage" dans lequel il y a "sage" sous forme de "terminal". |
19 Nov 2010, 16:27
C'est étrange. La seule question qui me vient à l'esprit, c'est celle de savoir si vous avez installé la version de sage correspondant à votre version de Mac OS X. Ou bien si vous avez bien mis tout le dossier "sage" de l'archive dans Applications.
19 Nov 2010, 17:44
C'était celà. Je n'avais pas vu que c'était pour le 10.6 alors que j'ai 10.5.8.
Merci pour m'avoir aidé à résoudre ce problème. |
20 Nov 2010, 00:49
C'était celà. Je n'avais pas vu que c'était pour le 10.6 alors que j'ai 10.5.8. Merci pour m'avoir aidé à résoudre ce problème. Il n'y a pas de quoi. -------------------- [size=1]iMac 24", M1, 1To, 16 Go, Sonoma 14.1
Nous sommes le : 28th May 2024 - 15:52 |
