Triple boot sur un seul SDD : apfsdriverloader.efi ne montre pas tous les volumes |
8 Jan 2021, 23:52
Nouveau Membre Groupe : Membres Messages : 25 Inscrit : 20 Nov 2017 Membre no 203 803 |
Je boot avec HighSierra, Mojave et Catalina installés sur un seul SSD, avec une seule partition EFI avec Clover 5100 en mode BIOS legacy. (ma CM est une GA-H61N-USB3) Mon disque : Code iMac:~ phil$ sudo gpt -r show disk0 Password: start size index contents 0 1 PMBR 1 1 Pri GPT header 2 32 Pri GPT table 34 6 40 409600 1 GPT part - C12A7328-F81F-11D2-BA4B-00A0C93EC93B 409640 156325576 2 GPT part - 7C3457EF-0000-11AA-AA11-00306543ECAC 156735216 156325576 3 GPT part - 7C3457EF-0000-11AA-AA11-00306543ECAC 313060792 155801296 4 GPT part - 7C3457EF-0000-11AA-AA11-00306543ECAC 468862088 7 468862095 32 Sec GPT table 468862127 1 Sec GPT header iMac:~ phil$ diskutil list /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *240.1 GB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_APFS Container disk2 80.0 GB disk0s2 3: Apple_APFS Container disk1 80.0 GB disk0s3 4: Apple_APFS Container disk3 79.8 GB disk0s4 /dev/disk1 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +80.0 GB disk1 Physical Store disk0s3 1: APFS Volume Mojave SSD512 28.0 GB disk1s1 2: APFS Volume PreBoot 24.6 MB disk1s2 3: APFS Volume Recovery 517.5 MB disk1s3 4: APFS Volume VM 20.5 KB disk1s4 /dev/disk2 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +80.0 GB disk2 Physical Store disk0s2 1: APFS Volume Catalina SSD512 - Data 16.1 GB disk2s1 2: APFS Volume Catalina SSD512 11.3 GB disk2s2 3: APFS Volume PreBoot 352.1 MB disk2s3 4: APFS Volume Recovery 2.7 GB disk2s4 5: APFS Volume VM 1.1 MB disk2s5 /dev/disk3 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +79.8 GB disk3 Physical Store disk0s4 1: APFS Volume High Sierra SSD512 35.7 GB disk3s1 2: APFS Volume PreBoot 21.6 MB disk3s2 3: APFS Volume Recovery 515.0 MB disk3s3 4: APFS Volume VM 20.5 KB disk3s4 Si je mets ApfsDriverLoader.efi dans drivers/BIOS folder, Clover ne me propose dans le menu que les volumes APFS du premier container, soit disk2, Catalina. Je n'ai pas trouvé le moyen de savoir quel apfs.efi est chargé par ApfsDriverLoader.efi, sachant qu'il y en a un dans les 3 OSs. J'imagine qu'il prends par défaut celui du premier container, soit Catalina : c'est bien cela ? Si je copie l'apfs.efi de Catalina dans drivers/BIOS et enlève ApfsDriverLoader.efi, alors Clover me montre bien tous les containers APFS et je peux booter un des 3 OSs depuis le menu. Donc apparemment ca marche mais : 1/ pourquoi ca ne marche pas avec ApfsDriverLoader.efi ? 2/ est ce que ApfsDriverLoader.efi charge un apfs.efi juste pour permettre à Clover de voir les containers/volumes et ensuite, quand on boot un OS, l'apfs.efi de cet OS est chargé à la place pendant le process de boot de l'OS ? (autrement dit, cela permet de charger l'apfs.efi de chaque OS, sachant qu'ils ont des versions différentes d'un OS à l'autre, même si je ne sais pas si c'est mieux) 3/ utiliser l'apfs.efi dans Clover a l'inconvénient des messages affichés : ce pb avait disparu grace à ApfsDriverLoader.efi mais si je n'arrive pas à l'utiliser, y a til un moyen simple de supprimer ces messages ? 4/ est-ce que l'ordre des containers et des disks qui ne sont pas incrémental pourrait y etre pour quelques chose ? 1: EFI EFI 209.7 MB disk0s1 5/ est-ce que booter 3 OSs avec le même Clover comme je le fais est possible ou faut il que je m'y prenne différemment ? Merci de votre aide Ce message a été modifié par polyzargone - 9 Jan 2021, 06:30. -------------------- Gigabyte H67MA-UD2H-B3 Bios F8 - i3-2105 (Sandy Bridge) - HD3000 & MSI GT710 1Go
Gigabyte H61N-USB3 Bios F8 - Pentium G2020 (Ivy Bridge) - Intel HD GRAPHICS & MSI GT710 1Go Gigabyte H67MA-USB3-B3 Bios F8 - i5-3550 (Ivy Bridge) - Asus GT720 1Go Silent |
9 Jan 2021, 06:33
Essaie de mettre à jour Clover en r5122 : https://github.com/CloverHackyColor/CloverB...leases/tag/5122
9 Jan 2021, 08:39
@poly
r5128 as une modification importante pour lister toutes les partitions Je te propose de te faire une clé nouvelle avec un EFI et de passer sous clover r5128 . Le but n'est pas d'installé, r5128 as été modifié pour lire et identifier mieux les partitions jusqu'à BS. Le rapport dans clover indique les partition et le décodage au mieux. Par contre, passer de R5122 à R5128, cela nécessite : -ajout quirk dans config.plist -ajout opencore.efi -suppression datahubDxe.efi -déterminer la suite pour les .efi ancien.. car un certains nombres sont obsolète ( optionmemory3D.efi etc...) -avoir à jour les kexts tu dois pouvoir démarré, et voir la liste sous clover puis démarrer Arprès c'est un PR à ouvrir t voir ce que slice va décidé (c'est une autre histoire.....) -------------------- macpro1,1 Dual core 2,66 GHz, 4 Go FB-dimm+ radeon HD 5770 + ST 500 Go + LCD Samsung 710T + Mac OS 10.6.8 + plantronics DSP 500 + Canon S50 + imprimante HP5520 + ipad mini ► NO WINDOWS BOOT... Only linux manjaro -------------------- |
9 Jan 2021, 08:45
Par contre, passer de R5122 à R5128, cela nécessite : -ajout quirk dans config.plist -ajout opencore.efi -suppression datahubDxe.efi -déterminer la suite pour les .efi ancien.. car un certains nombres sont obsolète ( optionmemory3D.efi etc...) -avoir à jour les kexts Oui et c'est pour ça que je lui propose de passer en r5122. Il est sur High Sierra avec une GTX 1060 donc de toute manière il ne pourra pas aller haut de dessus à moins de changer de CG. Par conséquent, la r5122 devrait suffire sans avoir à trop modifier son EFI . -------------------- Un Mac • macOS 10.15.7 MacBook Air mi-2012 Core i5 1,7 GHz Intel HD 4000 SSD 64 Go
9 Jan 2021, 10:05
Oui et c'est pour ça que je lui propose de passer en r5122. Il est sur High Sierra avec une GTX 1060 donc de toute manière il ne pourra pas aller haut de dessus à moins de changer de CG. Par conséquent, la r5122 devrait suffire sans avoir à trop modifier son EFI . C'est pour cela que je proposais une clé avec une version mac os ... d'où une autre question , il démarre une GTX 1060 sous une version mac os supérieur à high sierra ? Après , je suis pas certain que la r5122 apporte une amélioration sur ce sujet. A tester d'abord. Après on verra, le but étant simplement de lancer clover, et non d'installer ! @pct6 pourrais tu mettre dans la signature la configuration ? merci Ce message a été modifié par maclinuxG4 - 9 Jan 2021, 10:11. -------------------- macpro1,1 Dual core 2,66 GHz, 4 Go FB-dimm+ radeon HD 5770 + ST 500 Go + LCD Samsung 710T + Mac OS 10.6.8 + plantronics DSP 500 + Canon S50 + imprimante HP5520 + ipad mini ► NO WINDOWS BOOT... Only linux manjaro -------------------- |
9 Jan 2021, 10:58
C'est pour cela que je proposais une clé avec une version mac os ... d'où une autre question , il démarre une GTX 1060 sous une version mac os supérieur à high sierra ? Non en fait j’ai confondu avec un autre sujet . Si on en croit sa signature, c’est une GT 710. -------------------- Un Mac • macOS 10.15.7 MacBook Air mi-2012 Core i5 1,7 GHz Intel HD 4000 SSD 64 Go
9 Jan 2021, 22:09
C'est pour cela que je proposais une clé avec une version mac os ... d'où une autre question , il démarre une GTX 1060 sous une version mac os supérieur à high sierra ? Non en fait j’ai confondu avec un autre sujet . Si on en croit sa signature, c’est une GT 710. Oui c'est ca, je suis sur le H61N-USB3 avec un Pentium G2020 (Ivybridge) et une GT710 Bon je vais me lancer mais je ne connais pas OC du tout et encore moins comment marchent les dernières versions de Clover qui intégrent cette partie. Petite question pour la r5128: est-ce que je peux garder le config.plist de la 5100 et y ajouter la section Quirks ou il faut que je reparte de celui de la 5128 ? Y'a un truc que je ne comprends pas : je n'ai pas de section booter dans le config.plist ni dans le sample de ce post ci : https://forum.macbidouille.com/index.php?s=...t&p=4348944 Autre question : j'ai trouvé OpenCore.efi dans la pkg de la 0.5.6 : je le mets où ? J'ai testé la 5122 depuis une clef USB : même résultat, je ne vois que Catalina Edit ce matin : petit test avec un r5128 mais meme chose, toujours que Catalina Extrait du preboot.log : effectivement il ne reconnait pas tout 3:095 0:000 === [ LoadDrivers ] ============================= 3:112 0:016 Loading AudioDxe.efi status=Success 3:129 0:016 - driver needs connecting 3:129 0:000 Loading FSInject.efi status=Success 3:146 0:016 Loading SMCHelper.efi status=Success 3:163 0:016 Loading XhciDxe.efi status=Success 3:180 0:016 - driver needs connecting 3:180 0:000 Loading ApfsDriverLoader.efi status=Success 3:197 0:016 - driver needs connecting 3:197 0:000 3 drivers needs connecting ... 3:197 0:000 PlatformDriverOverrideProtocol->GetDriver overriden 3:197 0:000 APFS driver loaded ../.. 8:125 0:016 === [ ScanVolumes ] ============================= 8:125 0:000 Found 12 volumes with blockIO 8:125 0:000 - [00]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0) 8:125 0:000 Result of bootcode detection: bootable unknown (legacy) 8:125 0:000 - [01]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(1,GPT,C7DCF6FC-3398-4CC0-9281-03DEAB3D2A62,0x28,0x64000) 8:126 0:000 Result of bootcode detection: bootable unknown (legacy) 8:126 0:000 label : EFI 8:126 0:000 - [02]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8) 8:127 0:000 Result of bootcode detection: bootable unknown (legacy) 8:127 0:000 - [03]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(3,GPT,11E01983-12EC-42F8-B831-1BDDB4BF393A,0x95796F0,0x95156C8) 8:127 0:000 Result of bootcode detection: bootable unknown (legacy) 8:127 0:000 - [04]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(4,GPT,93F8DC4A-469D-4203-BEEF-1D6C1BD959E4,0x12A8EDB8,0x94956D0) 8:127 0:000 Result of bootcode detection: bootable unknown (legacy) 8:127 0:000 - [05]: Volume: PcieRoot(0x0)\Pci(0x1A,0x0)\USB(0x0,0x0)\USB(0x3,0x0) 8:139 0:011 Result of bootcode detection: bootable unknown (legacy) 8:139 0:000 - [06]: Volume: PcieRoot(0x0)\Pci(0x1A,0x0)\USB(0x0,0x0)\USB(0x3,0x0)\HD(1,MBR,0x00000000,0x2,0x1EA7FE) 8:150 0:011 Result of bootcode detection: bootable unknown (legacy) 8:167 0:016 label : TESTCLOVER 8:167 0:000 This is SelfVolume !! 8:167 0:000 - [07]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,092A473E02BA4F4995EDAA22A3DF127B) 8:167 0:000 apfsFileSystemUUID=3E472A09-BA02-494F-95ED-AA22A3DF127B, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x10 8:168 0:000 label : PreBoot 8:168 0:000 - [08]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,25DDFB1832678B438635A61F885C212A) 8:168 0:000 apfsFileSystemUUID=18FBDD25-6732-438B-8635-A61F885C212A, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x40 8:174 0:006 label : Catalina SSD512 - Data 8:174 0:000 - [09]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,9BDBFFC41EFCBA439823488236B031B2) 8:174 0:000 apfsFileSystemUUID=C4FFDB9B-FC1E-43BA-9823-488236B031B2, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x1 8:179 0:004 label : Catalina SSD512 8:179 0:000 - [10]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,E5BCDE05309CD74EBA60B0C031600853) 8:179 0:000 apfsFileSystemUUID=05DEBCE5-9C30-4ED7-BA60-B0C031600853, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x4 8:179 0:000 label : Recovery 8:179 0:000 - [11]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,175955BDE4041D4AA5DED75D940A9587) 8:180 0:000 apfsFileSystemUUID=BD555917-04E4-4A1D-A5DE-D75D940A9587, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x8 8:180 0:000 label : VM 8:180 0:000 Searching volumes for latest nvram.plist ... 8:180 0:000 loaded Status=Not Found 8:180 0:000 PutNvramPlistToRtVars: nvram.plist not found Ce message a été modifié par pct06 - 10 Jan 2021, 15:51. -------------------- Gigabyte H67MA-UD2H-B3 Bios F8 - i3-2105 (Sandy Bridge) - HD3000 & MSI GT710 1Go
11 Jan 2021, 18:34
Bon je vais me lancer mais je ne connais pas OC du tout et encore moins comment marchent les dernières versions de Clover qui intégrent cette partie. Pas besoin de connaître OC, Clover en intègre certaines parties mais Clover reste Clover. Y'a un truc que je ne comprends pas : je n'ai pas de section booter dans le config.plist ni dans le sample de ce post ci : https://forum.macbidouille.com/index.php?s=...t&p=4348944 C'est parce qu'il n'y en a pas. Il faut s'inspirer de la section Booter sur le site de Dortania pour configurer les Quirks comme expliqué dans le post. Autre question : j'ai trouvé OpenCore.efi dans la pkg de la 0.5.6 : je le mets où ? Pas besoin d'utiliser le pkg d'OC 0.5.6, OpenCore.efi est déjà dans l'installeur de Clover : J'ai testé la 5122 depuis une clef USB : même résultat, je ne vois que Catalina Poste le dossier EFI/CLOVER de ta clé stp. -------------------- Un Mac • macOS 10.15.7 MacBook Air mi-2012 Core i5 1,7 GHz Intel HD 4000 SSD 64 Go
11 Jan 2021, 19:25
Voici le lien vers l'EFI : https://mega.nz/file/RkUgXJYa#Ie2GIJt6yHgG1...MVzHL_dn1ZtBU-Q
J'ai refait un test avec la v5128 et en mettant apfs.efi dans le dossier drivers/BIOS. Il voit bien tous les containers. Voici le résultat, pour comparer dans mon poste précédent avec apfsdriverloader.efi 3:105 0:000 === [ LoadDrivers ] ============================= 3:122 0:016 Loading apfs.efi status=Success 3:241 0:118 - driver needs connecting 3:241 0:000 Loading AudioDxe.efi status=Success 3:258 0:016 - driver needs connecting 3:258 0:000 Loading FSInject.efi status=Success 3:275 0:016 Loading SMCHelper.efi status=Success 3:292 0:016 Loading XhciDxe.efi status=Success 3:309 0:016 - driver needs connecting 3:309 0:000 3 drivers needs connecting ... 3:309 0:000 PlatformDriverOverrideProtocol->GetDriver overriden 3:309 0:000 APFS driver loaded ../.. 8:246 0:016 === [ ScanVolumes ] ============================= 8:246 0:000 Found 20 volumes with blockIO 8:246 0:000 - [00]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0) 8:246 0:000 Result of bootcode detection: bootable unknown (legacy) 8:246 0:000 - [01]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(1,GPT,C7DCF6FC-3398-4CC0-9281-03DEAB3D2A62,0x28,0x64000) 8:246 0:000 Result of bootcode detection: bootable unknown (legacy) 8:247 0:000 label : EFI 8:247 0:000 - [02]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8) 8:248 0:000 Result of bootcode detection: bootable unknown (legacy) 8:248 0:000 - [03]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(3,GPT,11E01983-12EC-42F8-B831-1BDDB4BF393A,0x95796F0,0x95156C8) 8:248 0:000 Result of bootcode detection: bootable unknown (legacy) 8:248 0:000 - [04]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(4,GPT,93F8DC4A-469D-4203-BEEF-1D6C1BD959E4,0x12A8EDB8,0x94956D0) 8:248 0:000 Result of bootcode detection: bootable unknown (legacy) 8:248 0:000 - [05]: Volume: PcieRoot(0x0)\Pci(0x1A,0x0)\USB(0x0,0x0)\USB(0x2,0x0) 8:260 0:011 Result of bootcode detection: bootable unknown (legacy) 8:260 0:000 - [06]: Volume: PcieRoot(0x0)\Pci(0x1A,0x0)\USB(0x0,0x0)\USB(0x2,0x0)\HD(1,MBR,0x00000000,0x2,0x1EA7FE) 8:271 0:011 Result of bootcode detection: bootable unknown (legacy) 8:288 0:016 label : TESTCLOVER 8:288 0:000 This is SelfVolume !! 8:288 0:000 - [07]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,092A473E02BA4F4995EDAA22A3DF127B) 8:288 0:000 apfsFileSystemUUID=3E472A09-BA02-494F-95ED-AA22A3DF127B, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x10 8:289 0:000 label : PreBoot 8:289 0:000 - [08]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,25DDFB1832678B438635A61F885C212A) 8:289 0:000 apfsFileSystemUUID=18FBDD25-6732-438B-8635-A61F885C212A, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x40 8:295 0:005 label : Catalina SSD512 - Data 8:295 0:000 - [09]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,9BDBFFC41EFCBA439823488236B031B2) 8:295 0:000 apfsFileSystemUUID=C4FFDB9B-FC1E-43BA-9823-488236B031B2, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x1 8:300 0:004 label : Catalina SSD512 8:300 0:000 - [10]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,E5BCDE05309CD74EBA60B0C031600853) 8:300 0:000 apfsFileSystemUUID=05DEBCE5-9C30-4ED7-BA60-B0C031600853, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x4 8:300 0:000 label : Recovery 8:300 0:000 - [11]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(2,GPT,9FEEE078-DFB6-4245-B2E9-DA486A646341,0x64028,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,175955BDE4041D4AA5DED75D940A9587) 8:300 0:000 apfsFileSystemUUID=BD555917-04E4-4A1D-A5DE-D75D940A9587, ApfsContainerUUID=733C664D-FD93-4C88-A6F2-711594B28BC6, ApfsRole=0x8 8:300 0:000 label : VM 8:300 0:000 - [12]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(3,GPT,11E01983-12EC-42F8-B831-1BDDB4BF393A,0x95796F0,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,BAF07CDD7BFDB742B61014AA7FDF2455) 8:300 0:000 apfsFileSystemUUID=DD7CF0BA-FD7B-42B7-B610-14AA7FDF2455, ApfsContainerUUID=44469C38-ED75-43A5-AEB3-5201B4DB4B6F, ApfsRole=0x10 8:301 0:000 label : PreBoot 8:301 0:000 - [13]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(3,GPT,11E01983-12EC-42F8-B831-1BDDB4BF393A,0x95796F0,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,78496236B57C694A91D5BF90D6290DE7) 8:301 0:000 apfsFileSystemUUID=36624978-7CB5-4A69-91D5-BF90D6290DE7, ApfsContainerUUID=44469C38-ED75-43A5-AEB3-5201B4DB4B6F, ApfsRole=0x0 8:306 0:005 label : Mojave SSD512 8:306 0:000 - [14]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(3,GPT,11E01983-12EC-42F8-B831-1BDDB4BF393A,0x95796F0,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,3ED4E0FEBA53A342A0F143AB8626CEAD) 8:306 0:000 apfsFileSystemUUID=FEE0D43E-53BA-42A3-A0F1-43AB8626CEAD, ApfsContainerUUID=44469C38-ED75-43A5-AEB3-5201B4DB4B6F, ApfsRole=0x4 8:306 0:000 label : Recovery 8:306 0:000 - [15]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(3,GPT,11E01983-12EC-42F8-B831-1BDDB4BF393A,0x95796F0,0x95156C8)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,CDD9B418E0CB2E479BC3161D33F38980) 8:306 0:000 apfsFileSystemUUID=18B4D9CD-CBE0-472E-9BC3-161D33F38980, ApfsContainerUUID=44469C38-ED75-43A5-AEB3-5201B4DB4B6F, ApfsRole=0x8 8:306 0:000 label : VM 8:306 0:000 - [16]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(4,GPT,93F8DC4A-469D-4203-BEEF-1D6C1BD959E4,0x12A8EDB8,0x94956D0)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,F0F9FACF154C7843A3F74879111C5564) 8:306 0:000 apfsFileSystemUUID=CFFAF9F0-4C15-4378-A3F7-4879111C5564, ApfsContainerUUID=A90347C8-01E5-4CED-9525-4C5E97468796, ApfsRole=0x10 8:307 0:000 label : PreBoot 8:307 0:000 - [17]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(4,GPT,93F8DC4A-469D-4203-BEEF-1D6C1BD959E4,0x12A8EDB8,0x94956D0)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,FC5C7FEA57446E48A31D6E6CEEACCA93) 8:307 0:000 apfsFileSystemUUID=EA7F5CFC-4457-486E-A31D-6E6CEEACCA93, ApfsContainerUUID=A90347C8-01E5-4CED-9525-4C5E97468796, ApfsRole=0x0 8:316 0:009 label : High Sierra SSD512 8:316 0:000 - [18]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(4,GPT,93F8DC4A-469D-4203-BEEF-1D6C1BD959E4,0x12A8EDB8,0x94956D0)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,55D0AEB77645BB4388753195CD053EAC) 8:317 0:000 apfsFileSystemUUID=B7AED055-4576-43BB-8875-3195CD053EAC, ApfsContainerUUID=A90347C8-01E5-4CED-9525-4C5E97468796, ApfsRole=0x4 8:317 0:000 label : Recovery 8:317 0:000 - [19]: Volume: PcieRoot(0x0)\Pci(0x1F,0x2)\Sata(0x0,0x0,0x0)\HD(4,GPT,93F8DC4A-469D-4203-BEEF-1D6C1BD959E4,0x12A8EDB8,0x94956D0)\VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,ECCFAE23233E654EBA5F0DCEF633CC43) 8:317 0:000 apfsFileSystemUUID=23AECFEC-3E23-4E65-BA5F-0DCEF633CC43, ApfsContainerUUID=A90347C8-01E5-4CED-9525-4C5E97468796, ApfsRole=0x8 8:317 0:000 label : VM 8:317 0:000 Searching volumes for latest nvram.plist ... 8:317 0:000 loaded Status=Not Found 8:317 0:000 PutNvramPlistToRtVars: nvram.plist not found -------------------- Gigabyte H67MA-UD2H-B3 Bios F8 - i3-2105 (Sandy Bridge) - HD3000 & MSI GT710 1Go
Nous sommes le : 25th April 2024 - 16:18 |
