Supprimer une partition chiffrée |
2 Jun 2023, 13:51
#61
Adepte de Macbidouille Groupe : Membres Messages : 225 Inscrit : 27 May 2017 Membre no 202 279 |
Petit check à 15h :
Code CoreStorage logical volume groups (1 found)
| +-- Logical Volume Group 44646DC8-B52B-44DF-AFCD-743F36A7D14F ========================================================= Name: OS X Yosemite Status: Online Size: 201225048064 B (201.2 GB) Free Space: 18911232 B (18.9 MB) | +-< Physical Volume DA8B2E3A-93D5-46D2-9224-A4F65CC37995 | ---------------------------------------------------- | Index: 0 | Disk: disk0s4 | Status: Online | Size: 201225048064 B (201.2 GB) | +-> Logical Volume Family BF077E29-DE53-4D46-AD16-7181AB93AA01 ---------------------------------------------------------- Encryption Type: AES-XTS Encryption Status: Unlocked Conversion Status: Converting (backward) Reversion State: Decrypting High Level Queries: Not Fully Secure | Has Visible Users | Has Volume Key | +-> Logical Volume 10023DD7-F825-4D20-8F75-19434C361F0F --------------------------------------------------- Disk: disk1 Status: Online Size (Total): 200853815296 B (200.9 GB) Conversion Progress: 69% Revertible: Yes (unlock and decryption required) LV Name: OS X Sierra Volume Name: OS X Sierra Content Hint: Apple_HFS |
2 Jun 2023, 14:51
#62
Code Conversion Progress: 69% Courage, plus qu'1/3 à faire.
3 Jun 2023, 14:09
#63
Code Conversion Progress: 69% Courage, plus qu'1/3 à faire. Je crois que c'est bon Code CoreStorage logical volume groups (1 found)
| +-- Logical Volume Group 44646DC8-B52B-44DF-AFCD-743F36A7D14F ========================================================= Name: OS X Yosemite Status: Online Size: 201225048064 B (201.2 GB) Free Space: 18911232 B (18.9 MB) | +-< Physical Volume DA8B2E3A-93D5-46D2-9224-A4F65CC37995 | ---------------------------------------------------- | Index: 0 | Disk: disk0s4 | Status: Online | Size: 201225048064 B (201.2 GB) | +-> Logical Volume Family BF077E29-DE53-4D46-AD16-7181AB93AA01 ---------------------------------------------------------- Encryption Type: None | +-> Logical Volume 10023DD7-F825-4D20-8F75-19434C361F0F --------------------------------------------------- Disk: disk1 Status: Online Size (Total): 200853815296 B (200.9 GB) Conversion Progress: Complete Revertible: Yes (no decryption required) LV Name: OS X Sierra Volume Name: OS X Sierra Content Hint: Apple_HFS |
3 Jun 2023, 14:24
#64
Toujours sur Sierra tu vas passer la commande
Code diskutil cs revert 10023DD7-F825-4D20-8F75-19434C361F0F Puis tu donneras les résultats de Code diskutil list
3 Jun 2023, 15:34
#65
Toujours sur Sierra tu vas passer la commande Code diskutil cs revert 10023DD7-F825-4D20-8F75-19434C361F0F Code Started CoreStorage operation on disk1 OS X Sierra Switching partition from Core Storage type to original type Reclaiming space formerly used by Core Storage metadata Even though the disk is now fully reverted, you should reboot soon to re-mount your reverted disk from the actual original partition Removing Physical Volume Destroying Logical Volume Group Remounting former Physical Volume as normal disk Core Storage LV UUID: 10023DD7-F825-4D20-8F75-19434C361F0F Core Storage disk: disk0s4 Finished CoreStorage operation on disk1 OS X Sierra Citation Puis tu donneras les résultats de Code diskutil list Code /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *750.2 GB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS Macintosh HD 547.4 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 4: Apple_HFS OS X Yosemite 201.2 GB disk0s4 5: Apple_Boot Recovery HD 650.0 MB disk0s5 /dev/disk1 (internal, virtual): #: TYPE NAME SIZE IDENTIFIER 0: Apple_HFS OS X Sierra +201.2 GB disk1 Logical Volume on disk0s4 10023DD7-F825-4D20-8F75-19434C361F0F Unencrypted |
3 Jun 2023, 16:59
#66
Macbidouilleur d'Or ! Groupe : Modérateurs Messages : 19 378 Inscrit : 22 Jul 2004 Lieu : Louvain-la-Neuve (Gaule Gelbique) Membre no 21 291 |
Et maintenant, comme suggéré par le message d'alerte, tu peux redémarrer pour pleinement valider ces changements.
3 Jun 2023, 17:02
#67
Peux tu redémarrer le Mac sur Lion et redonner les retours de
Code diskutil list Oups, grillé Ce message a été modifié par jeanjd63 - 3 Jun 2023, 17:05. |
3 Jun 2023, 18:21
#68
Peux tu redémarrer le Mac sur Lion et redonner les retours de Code diskutil list Voici : Code /dev/disk0
#: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *750.2 GB disk0 1: EFI 209.7 MB disk0s1 2: Apple_HFS Macintosh HD 547.4 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 4: Apple_HFS OS X Sierra 201.2 GB disk0s4 5: Apple_Boot Recovery HD 650.0 MB disk0s5 |
3 Jun 2023, 18:43
#69
Donc tu vas faire :
Code diskutil erasevolume free space disk0s4 Et tu redonnes les retours de Code diskutil list
3 Jun 2023, 19:35
#70
3 Jun 2023, 20:06
#71
Tu fais bien cela depuis Lion et non Sierra ?
3 Jun 2023, 21:59
#72
Oui
4 Jun 2023, 06:01
#73
Donc, toujours depuis Lion tu vas faire :
Code sudo diskutil umount force disk0s4 Puis si OK, tu retentes : Code diskutil erasevolume free space disk0s4
4 Jun 2023, 10:15
#74
Le MacBook ne démarre plus
Quand j'appuie sur le bouton d'alimentation il y a le "dong", l'écran s'allume puis devient noir tout de suite, la led de veille s'allume. J'appuie sur le clavier, sur le trackpad mais aucune réaction Ce message a été modifié par Macintoy - 4 Jun 2023, 10:15. |
4 Jun 2023, 10:36
#75
Il faut faire
Reset nvram https://support.apple.com/fr-fr/HT204063 Reset Smc https://support.apple.com/fr-fr/HT201295 |
4 Jun 2023, 11:38
#76
Ça marche pas, c'est comme si je l'allumais sans presser les touches
4 Jun 2023, 11:55
#77
As-tu essayé un démarrage sans échec (appuis sur la touche Maj puis bouton arrêt marche sans relâcher l'appui sur Maj ?
Sinon démarrage en mode recovery (appui sur cmd+r après mise en marche) . Edit : As-tu passé les commandes du poste #73 ? Ce message a été modifié par jeanjd63 - 4 Jun 2023, 12:01. |
4 Jun 2023, 13:12
#78
Toujours pareil, le dong, l'écran s'allume puis se met en veille
Je n'ai pas pu tapé la ligne de code du post 73 |
4 Jun 2023, 15:36
#79
Je ne vois pas trop le rapport avec les dernières opérations.
Tu peux tenter Mac branché et débranché au secteur. Sinon tente de démarrer touche alt (option) appuyée. Ce message a été modifié par jeanjd63 - 4 Jun 2023, 15:37. |
4 Jun 2023, 16:03
#80
Déjà fait
EDIT : C'est bon il s'est allumé, je suis pas sûr mais je crois que c'est parce que le mac était posé sur un autre mac, ça me parait bizarre mais quand je l'ai enlevé il s'est allumé normalement Ce message a été modifié par Macintoy - 4 Jun 2023, 16:21. |
4 Jun 2023, 16:19
#81
Aie aie, tu les a dérangé lors de l'accouplement.
Sinon retour au post #73 |
4 Jun 2023, 16:22
#82
Aie aie, tu les a dérangé lors de l'accouplement. Je viens de me rappeler que ça me le faisait parfois avec mon téléphone, je le pose sur le bord du mac et pouf l'écran s'éteint et se met en veille Sinon la première commande me donne ça : Code Volume OS X Sierra on disk0s4 force-unmounted Je ne sais pas si c'est ok mais j'ai quand même tapé la seconde commande : Code Started erase on disk0s4 OS X Sierra
Unmounting disk Error: 2: POSIX reports: No such file or directory Ce message a été modifié par Macintoy - 4 Jun 2023, 16:25. |
4 Jun 2023, 18:23
#83
Que renvoi
Code diskutil list
4 Jun 2023, 19:24
#84
Que renvoi Code diskutil list Ceci : Code /dev/disk0 #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *750.2 GB disk0 1: EFI 209.7 MB disk0s1 2: Apple_HFS Macintosh HD 547.4 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 Quand je regarde dans l'utilitaire de disque il ne reste plus que Macintosh HD mais il n'a pas récupéré les 200Go |
4 Jun 2023, 19:50
#85
Donc tu vas faire maintenant
Code diskutil resizevolume disk0s3 0b
4 Jun 2023, 20:52
#86
4 Jun 2023, 20:59
#87
Macbidouilleur d'Or ! Groupe : Membres Messages : 2 191 Inscrit : 1 Nov 2021 Membre no 214 848 |
Ne pouvant joindre 'jeanjd63' par message personnel, je poste ici à son adresse exclusive:
je suis actuellement en voyage jusq'au 15 juin je n'ai pas mon stick gparted avec moi. Gparted marche, sûr. Il marche parce qu'il intervient depuis l'extérieur du système. Le plus important c'est de faire les changements de la table de partition depuis un autre disque, impérativement. Si vous voulez essayer avec macOS il faut avoir un disque externe duquel on boote et depuis lequel on fait les manips sur le disque interne dont aucune partition n'aura été montée. Le plus simple est de faire une copie du plus récent système fonctionnel avec CCC sur un disque externe, de booter depuis celui-ci et de retenter l'effacement de la partition. Ça devrait marcher. -------------------- "Les gens douteront toujours de la vérité sur Internet car l'erreur est constamment prêchée autour de nous" Johann Wolfgang von Goethe
4 Jun 2023, 21:23
#88
@Macintoy
Que te renvoi la commande : Code diskutil info disk0s2
4 Jun 2023, 21:46
#89
@Macintoy Que te renvoi la commande : Code diskutil info disk0s2 Code Device Identifier: disk0s2
Device Node: /dev/disk0s2 Part of Whole: disk0 Device / Media Name: Customer Volume Name: Macintosh HD Escaped with Unicode: Macintosh%FF%FE%20%00HD Mounted: Yes Mount Point: / Escaped with Unicode: / File System Personality: Journaled HFS+ Type (Bundle): hfs Name (User Visible): Mac OS Extended (Journaled) Journal: Journal size 57344 KB at offset 0xead1000 Owners: Enabled Partition Type: Apple_HFS OS Can Be Installed: Yes Media Type: Generic Protocol: SATA SMART Status: Verified Volume UUID: 24360C1A-B187-35F7-8750-F294DD5B8087 Total Size: 547.4 GB (547421564928 Bytes) (exactly 1069182744 512-Byte-Blocks) Volume Free Space: 197.2 GB (197187055616 Bytes) (exactly 385130968 512-Byte-Blocks) Device Block Size: 512 Bytes Read-Only Media: No Read-Only Volume: No Ejectable: No Whole: No Internal: Yes Solid State: No |
4 Jun 2023, 22:05
#90
Le volume étant journalisé, je ne vois pas pourquoi il refuse le "redimensionnement"
Peux tu redémarrer le Mac, puis redonner les retours de Code diskutil list Edit : petite question subsidiaire : pourquoi rester sur Lion, système totalement dépassé alors que ton Mac doit tourner sur High Sierra, sinon sur El Capitan? Ce message a été modifié par jeanjd63 - 5 Jun 2023, 06:23. |
Nous sommes le : 12th May 2024 - 05:43 |
