[Résolu] - Macbook pro veille ?, Blackout de quelques instants |
9 May 2018, 22:19
Edit: Dans le doute de savoir si c'est hardware ou logiciel je poste ici. Code 09/05/18 22:46:52 kernel 00000000 00000020 NVEthernet::setLinkStatus - not Active 09/05/18 22:46:52 kernel AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving). 09/05/18 22:46:52 configd[13] network configuration changed. 09/05/18 22:46:52 kernel System Sleep 09/05/18 22:46:56 kernel Wake reason = EC LID0 09/05/18 22:46:56 kernel System Wake 09/05/18 22:46:56 kernel Previous Sleep Cause: 5 09/05/18 22:46:56 kernel en1: 802.11d country code set to 'X3'. 09/05/18 22:46:56 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 09/05/18 22:46:57 kernel 00000000 00000020 NVEthernet::setLinkStatus - not Active 09/05/18 22:46:57 kernel Auth result for: 68:a3:78:cc:56:04 MAC AUTH succeeded 09/05/18 22:46:57 kernel AirPort: Link Up on en1 09/05/18 22:46:57 kernel AirPort: RSN handshake complete on en1 09/05/18 22:46:57 configd[13] network configuration changed. 09/05/18 22:48:01 kernel en1: 802.11d country code set to 'FR'. 09/05/18 22:48:01 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 09/05/18 22:48:42 com.apple.launchd.peruser.501[88] ([0x0-0x33033].com.apple.Console[686]) Exited: Killed 09/05/18 22:52:57 kernel 00000000 00000020 NVEthernet::setLinkStatus - not Active 09/05/18 22:52:57 kernel AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving). 09/05/18 22:52:57 configd[13] network configuration changed. 09/05/18 22:52:58 kernel System Sleep 09/05/18 22:53:01 kernel Wake reason = EC LID0 09/05/18 22:53:01 kernel System Wake 09/05/18 22:53:01 kernel Previous Sleep Cause: 5 09/05/18 22:53:01 kernel en1: 802.11d country code set to 'X3'. 09/05/18 22:53:01 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 09/05/18 22:53:02 kernel 00000000 00000020 NVEthernet::setLinkStatus - not Active 09/05/18 22:53:02 kernel Auth result for: 68:a3:78:cc:56:04 MAC AUTH succeeded 09/05/18 22:53:02 kernel AirPort: Link Up on en1 09/05/18 22:53:02 kernel AirPort: RSN handshake complete on en1 09/05/18 22:53:02 configd[13] network configuration changed. 09/05/18 22:54:07 kernel en1: 802.11d country code set to 'FR'. 09/05/18 22:54:07 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 09/05/18 23:00:25 ntpd[22] time reset +0.388159 s Mon MBP sur magsafe vient à 22h46 de me faire un écran noir avec arrêt du ventilo poussé au max par macfancontrol, ça a duré un peu moins de 10 secondes puis il s'est remis en marche normalement. Me demandant s'il avait trop chauffé (apparemment non il était à 57°C lorsqu'il s'est remis en route) j'ai tenu à essayer de checker ce qui s'était passé dans la Console (en copie) mais je ne comprend pas la cause. En googlisant "macbook pro Previous Sleep Cause: 5" at the command prompt. Similarly, a Previous Sleep Cause of 5 indicates any clean user-initiated sleep, from the menu or a hot corner or the command line or closing the lid and triggering the hall-effect sensor in the top case of a MacBook/Pro/Air. https://apple.stackexchange.com/questions/1...lained-anywhere Ça semble indiquer une mise en veille propre comme si je l'avais initiée de moi-même, ce qui n'est pas le cas. Ce message a été modifié par anonym_d019ede3 - 10 May 2018, 00:20. |
9 May 2018, 23:39
J'ai continué à creuser et il semble que Wake reason = EC LID0 ça indique une sortie de veille par ouverture de couvercle du MBP, ce qui signifierait qu'il se soit préalablement cru à couvercle fermé en veille:
https://www.cnet.com/news/how-to-find-syste...causes-in-os-x/ Du coup, ça serait un petit souci du côté du capteur situé proche de la touche fn qui réagit normalement à l'aimant du couvercle lorsqu'on ferme le mac, donc ça serait Hardware. Je n'avais rien d'aimanté au moment ou ça s'est produit, par contre c'est peut être dû à mon portable, je ne me souviens pas s'il était à proximité à ce moment… Ce message a été modifié par anonym_d019ede3 - 9 May 2018, 23:42. |
10 May 2018, 00:19
Je pense que c'était la cause, donc je passe en [Résolu].
Nous sommes le : 26th April 2024 - 16:40 |
