Erreur de compilation bizarre |
18 Aug 2013, 05:31
Macbidouilleur d'argent ! Groupe : Membres Messages : 566 Inscrit : 2 Mar 2007 Membre no 81 881 |
Bonsoir à tous,
je tente de compiler un programme chargé à partir d'un dépôt Git sur 10.6.8. Les dépendances ont été installées avec MacPorts, et le programme lui-même a été cloné localement, comme le veut Git. Cependant, la compilation ne fonctionne pas, mais je n'arrive pas vraiment à comprendre la source de l'erreur, malgré une recherche faite. Le log contient ça: Code This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by libosmocore configure UNKNOWN, which was generated by GNU Autoconf 2.69. Invocation command line was $ ../configure --host=arm-none-eabi --enable-embedded --disable-shared --disable-tests ac_cv_header_sys_select_h=no --disable-tests ac_cv_header_sys_socket_h=no CFLAGS=-Os -ffunction-sections -I/usr/bin/osmocom-bb/src/target/firmware/include -nostartfiles -nodefaultlibs ## --------- ## ## Platform. ## ## --------- ## hostname = Lancelot.local uname -m = x86_64 uname -r = 10.8.0 uname -s = Darwin uname -v = Darwin Kernel Version 10.8.0: Tue Jun 7 16:32:41 PDT 2011; root:xnu-1504.15.3~1/RELEASE_X86_64 /usr/bin/uname -p = i386 /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = Mach kernel version: Darwin Kernel Version 10.8.0: Tue Jun 7 16:32:41 PDT 2011; root:xnu-1504.15.3~1/RELEASE_X86_64 Kernel configured for up to 4 processors. 2 processors are physically available. 4 processors are logically available. Processor type: i486 (Intel 80486) Processors active: 0 1 2 3 Primary memory available: 16.00 gigabytes Default processor set: 80 tasks, 389 threads, 4 processors Load average: 0.22, Mach factor: 3.77 /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /opt/local/bin/ PATH: /opt/local/sbin/ PATH: /opt/local/bin PATH: /opt/local/sbin PATH: /usr/bin PATH: /bin PATH: /usr/sbin PATH: /sbin PATH: /usr/local/bin PATH: /usr/X11/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:2349: checking for a BSD-compatible install configure:2417: result: /usr/bin/install -c configure:2428: checking whether build environment is sane configure:2483: result: yes configure:2542: checking for arm-none-eabi-strip configure:2572: result: no configure:2582: checking for strip configure:2598: found /opt/local/bin//strip configure:2609: result: strip configure:2634: checking for a thread-safe mkdir -p configure:2673: result: ../install-sh -c -d configure:2680: checking for gawk configure:2710: result: no configure:2680: checking for mawk configure:2710: result: no configure:2680: checking for nawk configure:2710: result: no configure:2680: checking for awk configure:2696: found /usr/bin/awk configure:2707: result: awk configure:2718: checking whether make sets $(MAKE) configure:2740: result: yes configure:2769: checking whether make supports nested variables configure:2786: result: yes configure:2925: checking whether make supports nested variables configure:2942: result: yes configure:2954: checking whether make sets $(MAKE) configure:2976: result: yes configure:2994: checking for arm-none-eabi-gcc configure:3024: result: no configure:3034: checking for gcc configure:3050: found /usr/bin/gcc configure:3061: result: gcc configure:3290: checking for C compiler version configure:3299: gcc --version >&5 i686-apple-darwin10-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00) Copyright (C) 2007 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:3310: $? = 0 configure:3299: gcc -v >&5 Using built-in specs. Target: i686-apple-darwin10 Configured with: /private/var/tmp/llvmgcc42/llvmgcc42-2336.1~3/src/configure --disable-checking --enable-werror --prefix=/Developer/usr/llvm-gcc-4.2 --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-prefix=llvm- --program-transform-name=/^[cg][^.-]*$/s/$/-4.2/ --with-slibdir=/usr/lib --build=i686-apple-darwin10 --enable-llvm=/private/var/tmp/llvmgcc42/llvmgcc42-2336.1~3/dst-llvmCore/Developer/usr/local --program-prefix=i686-apple-darwin10- --host=x86_64-apple-darwin10 --target=i686-apple-darwin10 --with-gxx-include-dir=/usr/include/c++/4.2.1 Thread model: posix gcc version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00) configure:3310: $? = 0 configure:3299: gcc -V >&5 llvm-gcc-4.2: argument to `-V' is missing configure:3310: $? = 1 configure:3299: gcc -qversion >&5 i686-apple-darwin10-llvm-gcc-4.2: no input files configure:3310: $? = 1 configure:3330: checking whether the C compiler works configure:3352: gcc -Os -ffunction-sections -I/usr/bin/osmocom-bb/src/target/firmware/include -nostartfiles -nodefaultlibs conftest.c >&5 Undefined symbols for architecture x86_64: "start", referenced from: -u command line option ld: symbol(s) not found for architecture x86_64 collect2: ld returned 1 exit status configure:3356: $? = 1 configure:3394: result: no configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "libosmocore" | #define PACKAGE_TARNAME "libosmocore" | #define PACKAGE_VERSION "UNKNOWN" | #define PACKAGE_STRING "libosmocore UNKNOWN" | #define PACKAGE_BUGREPORT "[email protected]" | #define PACKAGE_URL "" | #define PACKAGE "libosmocore" | #define VERSION "UNKNOWN" | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:3399: error: in `/usr/bin/osmocom-bb/src/shared/libosmocore/build-target': configure:3401: error: C compiler cannot create executables See `config.log' for more details ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set=set ac_cv_env_CFLAGS_value='-Os -ffunction-sections -I/usr/bin/osmocom-bb/src/target/firmware/include -nostartfiles -nodefaultlibs' ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_LIBS_set= ac_cv_env_LIBS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set=set ac_cv_env_host_alias_value=arm-none-eabi ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_header_sys_select_h=no ac_cv_header_sys_socket_h=no ac_cv_path_install='/usr/bin/install -c' ac_cv_prog_AWK=awk ac_cv_prog_ac_ct_CC=gcc ac_cv_prog_ac_ct_STRIP=strip ac_cv_prog_make_make_set=yes am_cv_make_support_nested_variables=yes ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /usr/bin/osmocom-bb/src/shared/libosmocore/missing aclocal-1.14' ALLOCA='' AMDEPBACKSLASH='' AMDEP_FALSE='' AMDEP_TRUE='' AMTAR='$${TAR-tar}' AM_BACKSLASH='\' AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)' AM_DEFAULT_VERBOSITY='0' AM_V='$(V)' AR='' AUTOCONF='${SHELL} /usr/bin/osmocom-bb/src/shared/libosmocore/missing autoconf' AUTOHEADER='${SHELL} /usr/bin/osmocom-bb/src/shared/libosmocore/missing autoheader' AUTOMAKE='${SHELL} /usr/bin/osmocom-bb/src/shared/libosmocore/missing automake-1.14' AWK='awk' CC='gcc' CCDEPMODE='' CFLAGS='-Os -ffunction-sections -I/usr/bin/osmocom-bb/src/target/firmware/include -nostartfiles -nodefaultlibs' CPP='' CPPFLAGS='' CYGPATH_W='echo' DEFS='' DEPDIR='' DLLTOOL='' DOXYGEN='' DSYMUTIL='' DUMPBIN='' ECHO_C='\c' ECHO_N='' ECHO_T='' EGREP='' ENABLE_GB_FALSE='' ENABLE_GB_TRUE='' ENABLE_MSGFILE_FALSE='' ENABLE_MSGFILE_TRUE='' ENABLE_PLUGIN_FALSE='' ENABLE_PLUGIN_TRUE='' ENABLE_SERIAL_FALSE='' ENABLE_SERIAL_TRUE='' ENABLE_TALLOC_FALSE='' ENABLE_TALLOC_TRUE='' ENABLE_UTILITIES_FALSE='' ENABLE_UTILITIES_TRUE='' ENABLE_VTY_FALSE='' ENABLE_VTY_TRUE='' EXEEXT='' FGREP='' GREP='' HAVE_DOXYGEN_FALSE='' HAVE_DOXYGEN_TRUE='' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='$(install_sh) -c -s' LD='' LDFLAGS='' LIBOBJS='' LIBRARY_DL='' LIBS='' LIBTOOL='' LIPO='' LN_S='' LTLDFLAGS_OSMOGB='' LTLDFLAGS_OSMOGSM='' LTLIBOBJS='' MAKEINFO='${SHELL} /usr/bin/osmocom-bb/src/shared/libosmocore/missing makeinfo' MANIFEST_TOOL='' MKDIR_P='../install-sh -c -d' NM='' NMEDIT='' OBJDUMP='' OBJEXT='' OTOOL64='' OTOOL='' PACKAGE='libosmocore' PACKAGE_BUGREPORT='[email protected]' PACKAGE_NAME='libosmocore' PACKAGE_STRING='libosmocore UNKNOWN' PACKAGE_TARNAME='libosmocore' PACKAGE_URL='' PACKAGE_VERSION='UNKNOWN' PATH_SEPARATOR=':' RANLIB='' SED='' SET_MAKE='' SHELL='/bin/sh' STRIP='strip' SYMBOL_VISIBILITY='' VERSION='UNKNOWN' ac_ct_AR='' ac_ct_CC='gcc' ac_ct_DUMPBIN='' am__EXEEXT_FALSE='' am__EXEEXT_TRUE='' am__fastdepCC_FALSE='' am__fastdepCC_TRUE='' am__include='' am__isrc=' -I$(srcdir)' am__leading_dot='.' am__nodep='' am__quote='' am__tar='$${TAR-tar} chof - "$$tardir"' am__untar='$${TAR-tar} xf -' bindir='${exec_prefix}/bin' build='' build_alias='' build_cpu='' build_os='' build_vendor='' datadir='${datarootdir}' datarootdir='${prefix}/share' docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' dvidir='${docdir}' exec_prefix='NONE' host='arm-none-eabi' host_alias='arm-none-eabi' host_cpu='' host_os='' host_vendor='' htmldir='${docdir}' includedir='${prefix}/include' infodir='${datarootdir}/info' install_sh='${SHELL} /usr/bin/osmocom-bb/src/shared/libosmocore/install-sh' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localedir='${datarootdir}/locale' localstatedir='${prefix}/var' mandir='${datarootdir}/man' mkdir_p='$(MKDIR_P)' oldincludedir='/usr/include' pdfdir='${docdir}' prefix='NONE' program_transform_name='s,x,x,' psdir='${docdir}' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ----------- ## ## confdefs.h. ## ## ----------- ## /* confdefs.h */ #define PACKAGE_NAME "libosmocore" #define PACKAGE_TARNAME "libosmocore" #define PACKAGE_VERSION "UNKNOWN" #define PACKAGE_STRING "libosmocore UNKNOWN" #define PACKAGE_BUGREPORT "[email protected]" #define PACKAGE_URL "" #define PACKAGE "libosmocore" #define VERSION "UNKNOWN" configure: exit 77 Comment est-ce que ça se résout? |
18 Aug 2013, 08:20
est-ce que tu as volontairement activé l'option Code --host=arm-none-eabi ?On dirait que tu essayes de compiler pour un proc arm sur une machine x86, ce qui n'est pas forcément le plus simple. En tout cas, chez moi (iMac i7, OS 10.8.4 et macports, un simple Code autoreconf -i ./configure fonctionne sans erreurs (mais le Code make échoue. Précision : ce n'est pas une erreur de compilation qui se passe chez toi, la configuration n'est même pas terminée. Ce message a été modifié par audionuma - 18 Aug 2013, 08:24. -------------------- Membre du club des AIPBP (Anciens Inscrits Pas Beaucoup de Posts) Voir la liste
19 Aug 2013, 03:11
Non, je ne l'ai pas activée volontairement, et la source est, à toutes fins pratiques, l'originale telle que téléchargée de Git.
La commande autoreconf donne un résultat bizarre, peux-tu être plus spécifique dans ta réponse? Code $ sudo autoreconf -i autoreconf: 'configure.ac' or 'configure.in' is required De même pour "configure" Code $ sudo configure sudo: configure: command not found La compilation sur OS X n'est pas censée nécessiter d'autre étape. |
19 Aug 2013, 06:34
nous parlons bien du même projet ? J'ai suivi les indications ici : http://bb.osmocom.org/trac/wiki/libosmocore Code $ git clone git://git.osmocom.org/libosmocore.git $ cd libosmocore $ autoreconf -i $ ./configure $ make Citation La compilation sur OS X n'est pas censée nécessiter d'autre étape. En fait, la compilation à proprement parler a lieu lors du make, configure sert à (justement) configurer la compilation. -------------------- Membre du club des AIPBP (Anciens Inscrits Pas Beaucoup de Posts) Voir la liste
20 Aug 2013, 09:11
Non, en fait j'avais commencé par la page "Getting started", après avoir lue celle de Mac Os X, qui n'indique pas clairement d'installer libosmocore avant. Dans tous les cas, en faisant la suite de commandes que tu montres (à précéder de sudo, sinon ça ne fonctionne pas.), ça échoue quand même:
Code CC msgfile.lo msgfile.c: In function 'osmo_config_list_parse': msgfile.c:116: warning: implicit declaration of function 'getline' CC serial.lo CCLD libosmocore.la Undefined symbols for architecture x86_64: "_getline", referenced from: _osmo_config_list_parse in msgfile.o ld: symbol(s) not found for architecture x86_64 collect2: ld returned 1 exit status make[3]: *** [libosmocore.la] Error 1 make[2]: *** [all] Error 2 make[1]: *** [all-recursive] Error 1 make: *** [all] Error 2 Pourquoi? |
Nous sommes le : 24th April 2024 - 14:53 |
