> Impossible de copier mon disque dur avec super duper, voici ce que dit super Duper
ronparchita
posté 13 Feb 2018, 10:21
Inscrit : 6 Nov 2004
Membre no 26 427
Mon disque de sauvegarde ne remonte pas, copie de mon disque dur impossible. Pourquoi ? Je n'en sais vraiment rien.
Je suis sous Mavericks, j'ai la version SD 3.1.1, gratuite.
Voilà ce que dit Super Duper :
| 10:03:39 AM | Info | SuperDuper!, 3.1.1 (103.1), path: /Applications/SuperDuper!.app, Mac OS 10.9.5 build 13F1911 (i386)
| 10:03:39 AM | Info | Started on Tue, Feb 13, 2018 at 10:03 AM
| 10:03:39 AM | Info | Source Volume: "MAVERICKS" mount: '/' device: disk0s2 file system: 'Mac OS Extended (Journaled)' protocol: SATA OS: 10.9.5 capacity: 639.09 GB available: 467.28 GB files: 834 957 directories: 206 960
| 10:03:39 AM | Info | Target Volume: "SSD" mount: '/Volumes/SSD' device: disk1s2 file system: 'Mac OS Extended (Journaled)' protocol: USB capacity: 239.71 GB available: 239.4 GB files: 57 directories: 18
| 10:03:39 AM | Info | Copy Mode : Erase, then copy files
| 10:03:39 AM | Info | Copy Script : Backup - all files.dset
| 10:03:39 AM | Info | Transcript : BuildTranscript.plist
| 10:03:39 AM | Info | PHASE: 1. Prepare to Copy Files
| 10:03:39 AM | Info | ...ACTION: Preparing MAVERICKS
| 10:03:39 AM | Info | ......COMMAND => Enabling permissions on MAVERICKS
| 10:03:39 AM | Info | File system user/group ownership enabled
| 10:03:39 AM | Info | ...ACTION: Erasing SSD
| 10:03:39 AM | Info | ......COMMAND => Erasing SSD
| 10:03:40 AM | Info | Erasing /Volumes/SSD...
| 10:03:40 AM | Info | Started erase on disk1s2 SSD
| 10:03:40 AM | Info | Unmounting disk
| 10:03:40 AM | Info | Error: -69879: Couldn't open disk
| 10:03:40 AM | Info | Waiting for /Volumes/SSD to mount...
| 10:07:42 AM | Info | Waiting for /Volumes/SSD to mount...
| 10:07:44 AM | Error | /Volumes/SSD did not appear
J'ai fait une recherche sur ça : | 10:03:40 AM | Info | Error: -69879: Couldn't open disk
et je n'ai rien trouvé.
Est-ce que ça vous parle ?
Edité
S'il n'y a pas de solution, est-il possible de cloner son Disque Dur sur le SSD externe avec utilitaire de disque ?
Edité à nouveau :
J'ai trouvé une réponse là :
http://communaute.crucial.com/t5/FAQ-SSD/C...D-Mac/ta-p/9283
Ca me permettra peut-être d'avoir une copie tout à fait identique à mon Disque Dur actuel.
Donc à priori, ça devrait marcher, avec une question tout de même : je vais devoir réduire la taille de mon disque dur, mais je ne veux pas installer mon SSD dans mon ordinateur tout de suite. Je vais peut-être installer El Capitan, j'y pense mais ne suis pas encore décidé.
Comment vais-je devoir faire pour remettre mon actuel HD à sa taille d'origine ?
Avez-vous des idées ?
D'avance merci,
Ce message a été modifié par ronparchita - 13 Feb 2018, 14:17.
Ronparchita,
1 MacBookPro 13" 2011, iMac Alu 2009 24", 2,66 GHz écran légèrement taché, Time Capsule 3To - Mavericks.
Dans l'attente du retour à la SNCF d'une tarification unique au km tout au long de l'année et de la mise en place de trains supplémentaires pour les départs et retours de vacances, comme en Allemagne, j'opte pour la semaine de 28 heures sans perte de salaire.
Sauvez Le Monde ! Abonnez-vous à Free.
mazelle jeanne
posté 13 Feb 2018, 19:43
Macbidouilleuse d'or !
Inscrit : 11 Jul 2006
Lieu : paris
Membre no 64 304
Si j'ai bien compris, tu veux faire un clone bootable de ton disque dur sur le SSD ?
Si oui, il faut bien sûr que le SSD monte sur le bureau et que tu le formates correctement. Est-ce que tu peux le voir dans Utilitaire de disques ?
Carpe diem
Imac G5 avec OS 10.4 Tiger
Imac intel core i5 avec Snow Leopard et El Capitan
bigmechantmou
posté 13 Feb 2018, 20:03
Inscrit : 16 Jul 2010
Lieu : Paris, Montmartre
Membre no 156 738
Oui il est possible de réaliser un clone avec l'UDD en créant une image disque qu'on restaure sur la cible.
Sinon il y a aussi Carbon Copy Cloner. gratuit en démo 30j.
Pour ton soucis de disque tu ne te trouverais pas dans le cas d'un SSD avec TRIMenabler qui bloquait les SSD lors de reset NVRAM entre Mavericks et Yosemite jusqu'à la 3e mouture ?
http://forum.macbidouille.com/index.php?sh...p;#entry4164809
Mac mini 2Ghz rév mars 2009, SSD, 8Go ram (Snow Leopard).
Macbook Pro mid 2009. 13" 2,53Ghz, SSD, 4Go ram (Snow Leopard).
mazelle jeanne
posté 13 Feb 2018, 21:13
Lieu : paris
Membre no 64 304
bigmechantmou, Super Duper est gratuit également et je le trouve très bien, ça fait des années que je fais mes clones bootables avec lui et zéro problème. smile.gif
Carpe diem
castor74
posté 13 Feb 2018, 21:34
Inscrit : 1 Apr 2004
Lieu : 74
Membre no 17 041
Citation (mazelle jeanne @ 13 Feb 2018, 21:13) *
Idem. Je m'en sers toutes les semaines pour cloner plusieurs disques externes, en sélectionnant uniquement les fichiers modifiés. smile.gif
Apprentissage typo plomb en 1973 ;-) - PAO pro pendant 27 ans (début sur CRTronic 200) - Sur Mac depuis 1989 (Mac IIx jusqu'à PPC G5 2 x 2.3 Ghz) • Matériel perso: iMac Intel Core 2 Duo 20" - OS X 10.6.8 - CS2.3 - LiveBox Sagem - 20 Mega • iMac DV 400 - OS 9.1 • iBook G3 Graphite - OS 9.2/10.2.8 • MacBook 13" OS 10.5.8 | Photo: Fuji FinePix S9500 - Nikon D90 - 18-200 VR II - VR 105 Macro f:2.8 - Micro Nikkor 60 mm f:2.8 - Mon site mycologique
ronparchita
posté 13 Feb 2018, 22:01
Membre no 26 427
Bonjour à tous et merci de vos réponses.
Je voulais avoir un SSD exactement comme le disque dur avec EFI, recovery et le disque.
J'ai CCC 3.4.4, derniere version gratuite avant les payantes
Il fait très bien la copie de recovery pour le lion des montagnes, mais celui de Mavericks à grossi et ne tient pas dans l'espace dédié.
J'hésite à télécharger une version plus récente, car à part ce petit problème, cette version me satisfait pleinement pour le peu que je lui demande, et je ne voudrais pas être définitivement coincé par une version d'essais qui désactiverait ma version actuelle. Je n'ai donc pas pris le risque.
Super duper ayant bonne réputation, j'ai telechargé la version qui va bien avec Mavericks.
Avant d'utiliser Super Duper, j'avais formaté le SSD via Utilitaire de Disque sans aucun problème.
J'avais d'abord essayé de lui installer Mavericks, mais je n'y suis pas arrivé (j'avais fait un dvd lors du téléchargment) car pendant l'install l'ordinateur s'éteint puis se rallume mais sur le disque dur, pas sur le SSD.
Avec Super Duper, j'ai essayé plusieurs fois, mais toujours avec le même problème que j'ai montré en haut de ce fil.
Quand Utilitaire de disque a terminé le formatage et le partitionnement, est-ce qu'il démonte le disque ?
Dommage, je n'ai pas regardé...
Peut-être faudrait-il qu'avant de relancer Super Duper, je devrais débrancher le SSD puis le rebrancher, car normalement, il devrait automatiquement monter.
"tu ne te trouverais pas dans le cas d'un SSD avec TRIMenabler qui bloquait les SSD lors de reset NVRAM entre Mavericks et Yosemite jusqu'à la 3e mouture ?"
Je suis allé au bout de ton lien, crois-tu que j'etais dans une phase de reset NVRAM ?
Et puis
Je ne sais plus combien j'ai intallé de maj de Mavericks, mais je suis allé jusqu'à la dernière, et ça devait être plus que la troisième, mais j'irai voir ce qu'il y a dans le fil...
Citation (castor74 @ 13 Feb 2018, 21:34) *
Vous l'avez acheté alors parce que la version gratuite ne permet pas, d'apres ce que j'ai vu, autre chose que cloner un disque, mais pour moi, il s'agit de la version d'essais compatible avec Mavericks, peut être que la plus récente offre plus de possibilités... smile.gif
Ce message a été modifié par ronparchita - 13 Feb 2018, 22:02.
Ronparchita,
bigmechantmou
posté 13 Feb 2018, 23:08
Membre no 156 738
Là, dans ton rapport de Superduper, ton SSD est monté, c'est après l'effacement par le logiciel qu'il est démonté et ne semble plus réapparaître.
Pour le TRIM ça semble pas être ça même si je parlais du bug possible jusqu'à la 3e de Yosemite et pas Maverick.
Sur quel mac ? Boitier SSD auto alimenté ?
As-tu tenté de le reformater ou il n'apparait plus dans l'Utilitaire de Disques ?
=> un formatage parfois peut-être foireux.
Quant au DVD d'installation que tu as créé, testé sur l'autre mac avant installation ? Il boote ?
*mazelle jeanne & castor74, je proposais CCC car il rencontre des soucis avec Superduper et ça permet d'éliminer une piste logicielle ou une préférence de ce dernier potentiellement corrompue.
ronparchita
posté 14 Feb 2018, 13:02
Membre no 26 427
Citation (bigmechantmou @ 13 Feb 2018, 23:08) *
J'ai recommencé, c'est à dire un nouveau partitionnage, j'ai lancé utilitaire de disque, j'ai lancé Super Duper, quand j'ai vu que ça trainait, de l'Utilitaire j'ai selectionné le disque interne, mais pas possible de le monter, donc j'ai choisi Mavericks et la j'ai pu le monter. (C'est d'ailleurs le choix qui est proposé au départ). La sauvegarde a immediatement commencé.
Ce n'est pas le résultat escompté, sur le SSD j'ai EFI et Mavericks mais toujours pas Recovery.
J'ai à nouveau cherché dans Super Duper mais je plane.
Dans avancé de la fen^tre SD, je peux cocher During; Copy ACLs from Mavericks. Mais je n'ai pas trouvé ni ce que c'etait ni à quoi ça servait, bien qu'ayant trouvé du texte, mais en anglais.
Install package on SSD pourrait peut-être convenir, mais ça ouvre le Finder, et dans le Finder, il n'y a pas le Recovery HD. Je touche le fond...
Le DVD
Lorsque je le met dans l'iMac de début 2009, il se charge sur l'ordi, ça demande un moment, puis il offre la possibilité de s'installer, reste à choisir le disque sur lequel le faire, on lance et ça s'installe jusqu'à ce qu'il indique qu'un redémarrage est nécessaire. Comme sur le SSD il n'y avait rien, il n'y avait pas de possibilité de le choisir pour etre le disque de redemarrage, donc quand ça reboote, ça le fait sur le disque dur.
Le SSD est auto alimenté sur une prise USB.
Tant que je n'aurai pas réussi à avoir l'équivalent sur le SSD de que ce qui apparait sur le Disque Dur, donc avec le "RECOVERY", je ne suis pas chaud pour installer ce SSD dans mon iMac.
A ce propos, j'ai noté que pendant la vitesse de transfert de Mavericks vers le SSD était d'environ 25MB/s
Ca ne parait pas beaucoup.
Je pourrais peut-être demarrer sur la sauvegarde de l'iMac (un disque conventionnel), télécharger la version d'essais de CCC, puis si c'est possible, lancer la sauvegarde de Mavericks sur le SSD, peut être qu'avec la version de CCC compatible avec Mavericks, il pourra créer cette partition Recovery, qu'en pensez-vous ?
Ce n'est pas tres gros un SSD, je pourrais quasiment en mettre deux dans l'iMac, un pour Mavericks et un pour El Capitan, a cela près que je n'ai pas 2 prises SATA smile.gif
Encore merci de vos reponses,
Ronparchita,
Aliboron
posté 14 Feb 2018, 13:58
Inscrit : 1 Jan 2008
Lieu : Toulouse.cong
Membre no 103 942
Citation (ronparchita @ 14 Feb 2018, 13:02) *
Pa sûr d'avoir tout suivi mais, si c'est ce qui te chagrine, sache que le volume "Recovery" n'est pas dupliqué par SuperDuper. Et c'est normal, c'est un choix de l'éditeur, qu'explique D Nanian quelque part sur le site (peut-être dans ce fil sur son forum ?). En gros, il ne le fait pas parce que c'est inutile.
Mais bon, ce n'est peut-être pas ça le problème...
Ce message a été modifié par Aliboron - 14 Feb 2018, 13:59.
Bernard
MacMini, iMac et tout un tas d'accessoires -- FAQ Office Macintosh
radioman
posté 14 Feb 2018, 14:25
Inscrit : 30 Sep 2002
Lieu : Limoges
Membre no 3 870
Citation (ronparchita @ 13 Feb 2018, 10:21) *
Mon sentiment (qui n'est pas forcément une vérité taillée dans le marbre):
quoique tu utilises, tant que la source sera plus grande que la cible ça ne fonctionnera pas
comme indiqué dans ton lien Crucial il faut que tu diminues la taille de ton volume source à la taille réellement utilisée pour faire la copie
639,09 (au total) - 467,28 dispo = 171,81 Go utilisés sur ton volume source
via utilitaire de disques tu réduit ce volume à son minimum en glissant le curseur de taille
tu clone ces 171,81 Go sur le SSD
une fois celle ci faite tu remets ton volume source à sa taille initiale (tout le disque visiblement)
sur le clone tu auras un volume 171,81 Go plein plus un espace vide de 67,59 Go que tu réaffecteras au volume 171,81 avec l'utilitaire de disques en glissant le curseur à la totalité du disque
Ce message a été modifié par radioman - 14 Feb 2018, 14:40.
 MacBook Pro 13" core i7 (2012) type 9,2 / 2,9 Ghz / 16 Go / Crucial M550 1To / Sierra 10.12.6
 Imac Alu 24" (mid 2007) type 7,1 / 2,4 Ghz / 4 Go / SSD Crucial C300 256 Go Samsung 840 EVO 512 Go / Yosémite 10.10.5
 DD externe AluICE 4 To Time Machine MBP
 DD externe AluICE 2 To Mojave
 DD externe AluICE 500 Go Time Machine iMac
 Dock "Freecom" + DD Bidouilles 10.4 / 10.5 / 10.6 / 10.7 / 10.8 / 10.9 / 10.10 / 10.11 / 10.12 / 10.13 / 10.14.xß
 Dock double "Advance Dual Easy Docking" pour cloner les disques …
 Imac G4 800 15" (2002) type 4,2 60 Go 80Go 7200tr / 768 Mo / Pioneer DVR 104 111D / Tiger 10.4.11
 imprimante-scanner A3 Epson Workforce 7620 / iPad 2 32 Go / iPhone 8S+ Red 256 Go
_Panta
posté 14 Feb 2018, 14:31
Inscrit : 24 Dec 2006
Lieu : "Over The Rainbow"
Membre no 76 401
Y a pas de fenetre ni de jolis bouton, mais c'en est d'autant plus efficace. Vive le terminal tongue.gif
D'un repertoire ou d'un disque à l'autre en local:
rsync -vzptre --progress /Mon/Volume /Ma/destination
ou sauvegardes distantes par rsync sur tunnel ssh
rsync -vzptre 'ssh -p 22' --progress /Mon/Volume panta@xx.xx.xx.xx:/Ma/Destination/Distante
C'est limite hors sujet, mais ça fera peut être le bonheur de quelqu'un wink.gif
Ce message a été modifié par _Panta - 14 Feb 2018, 14:32.
- Macbook Pro TouchBar 15" T1 - 512GB/core i7@2,7Ghz
- Macbook Air 13,3" core i5 - iMac 27" core i5 - iPhone7@128GB
- Airport Extrême
- Fbx Delta Devialet
ronparchita
posté 14 Feb 2018, 20:28
Membre no 26 427
Citation (_Panta @ 14 Feb 2018, 14:31) *
Ca m'inspire plein de questions
Avec ça on peut faire un copier coller directement à l'ouverture du terminal ? : rsync -vzptre --progress /Mon/Volume /Ma/destination
Est-ce que ça va copier juste (par exemple ) Mavericks sur SSD, ça copiera aussi EFI mais pas RECOVERY ?
J'ai rebouté sur ma sauvegarde traditionnelle et de là, j'ai téléchargé la version d'essais de CCC, la 4.
Et dans la fenêtre de CCC, Bombich dit qu'il est tres important d'avoir une partition recovery, que ça permet de réinstaller son OS sans se casser la tête.
Donc de mon disque de sauvegarde, j'ai pu grace à la version de test cloner Mavericks dans mon SSD et avoir EFI et Recovery.
Et ça s'est bien passé, la taille du disque qui porte Mavericks plus importante que celle du SSD n'a pas pesé sur la décision finale de CCC.
Mais par les lignes de commande, j'aimerai bien savoir si on peut arriver au même résultat, et ensuite comment est-ce qu'on écrit les lignes de commandes pour que ça reprenne automatiquement la manoeuvre tout seul toutes les 180 minutes biggrin.gif
Ronparchita,
radioman
posté 15 Feb 2018, 19:54
Lieu : Limoges
Membre no 3 870
Citation (ronparchita @ 14 Feb 2018, 20:28) *
bonne nouvelle donc …
ronparchita
posté 15 Feb 2018, 20:38
Membre no 26 427
Citation (radioman @ 15 Feb 2018, 19:54) *
Mais oui, reste que je n'ai pas encore decidé de l'utilisation definitive de ce SSD, soit de l'installer dans mon iMac, soit de le garder comme disque de sauvegarde et le raccorder à un MBP quand je voyage, soit d'installer dessus El Capitan et voir comment ça marche.
J'ai noté pendant la sauvegarde que la vitesse de transfert de Mavericks vers le SSD était d'environ 25MB/s
Ronparchita,
radioman
posté 15 Feb 2018, 21:38
Lieu : Limoges
Membre no 3 870
Citation (ronparchita @ 15 Feb 2018, 20:38) *
Bah, c'est surtout la vitesse du "tuyau" entre le Mac et ton SSD, si c'est de l'usb 2 …
sinon, ton SSD >> dans le mac !!! mettre un SSD en disque d'archive "c'est gâcher"
_Panta
posté 16 Feb 2018, 10:20
Membre no 76 401
La commande rsync va copier tes fichiers et repertoires donné dans le chemin /Mon/Volume/
En revanche pour copier l'intégralité d'un disque, y compris les partitions recovery et la partition de boot, c'est la commande suivante
dd if=/dev/disk0 of=/dev/disk1 bs=4096 count=1
On traduit la commande dd, ne jamais utiliser une ligne de commande sans essayer de la comprendre un minimun :
if= input file , fichier d'origine. Donc ton disque d'origine dont tu connaitras le nom par la commande diskutil list
attention, c'est le disque entier que l'on sélectionne, pas une partition, donc /dev/disk0 mais pas /dev/disk0s0 ou /dev/disk0s1
of= Output file, fichier de sortie : ton disque de destination, par exemple /dev/disk1
bs= 4096 la taille des blocks
count=1 On le copie 1 fois
ensuite une fois ton disque copié, il nne faut pas lancer cette commande dd toute les heures, tu relancerais la copie entière des disques, mais il faudra créer une routine (un cron, du moins launchd sous OsX) de la commande rsync qui synchronisera de manière incrémentale les differences horaires des deux disques.
On peux utiliser dd également pour faire un benchmark de la vitesse des disque
la vitesse d'ecriture
dd if=/dev/zero of=benchdisk bs=1m count=1024
pour un disque externe
dd if=/dev/zero of=/Volumes/MonDisk/benchdisk bs=1m count=1024
la vitesse de lecture
dd if=benchdisk of=/dev/null
sur un disque externe
dd if=/Volumes/MonDisk/benchdisk of=/dev/null
Ce message a été modifié par _Panta - 16 Feb 2018, 11:08.
- Airport Extrême
ronparchita
posté 16 Feb 2018, 11:34
Membre no 26 427
Citation (_Panta @ 16 Feb 2018, 10:20) *
Il pourra pleuvoir dimanche, j'ai une explication de texte en attente :
Volume =
Partition =
Etc
Pour ne pas confondre les deux et mettre en pratique ton conseil : ne jamais utiliser une ligne de commande sans essayer de la comprendre un minimun
Dans l'expression : disk0s0 le petit s se rapporte à un sous volume (donc une partition ?) qui apparait dans la liste # de diskutil list ?
Cron ! J'ai une revue de Linux qui explique comment on programme la répétition d'une tâche. Cron viendrait de crono, le temps, programmer dans le temps, si je me souviens bien. smile.gif
Merci Panta,
C'est vrai que le terminal n'offre pas de petits boutons, mais les petits boutons ne font qu'une chose, les commandes peuvent avoir des applications multiples, etres associées, etc.
Edité : j'ai un doute
D'habitude, quand j'ouvre mon terminal je n'ai pas ça :
Last login: Fri Feb 16 10:35:05 on ttys000
You have mail.
[iMac-de-Ronparchita:~] Ronparchita% diskutil list
etc..
ttys000 et You have mail, je n'y suis pas habitué. Qu'est-ce que ça peut etre ?
Ce message a été modifié par ronparchita - 16 Feb 2018, 12:08.
Ronparchita,
_Panta
posté 16 Feb 2018, 12:57
Membre no 76 401
Une alerte system certainement en provenance d'un service, tape simplement mail (et entrée) dans le terminal, tu devrais avoir le ou les mails en question.
C'est rigolo et simple d'envoyer un mail en ligne de commande, vous tapez dans le terminal:
mail exemple@gmail.com (enter)
Subject : mon sujet (enter)
Mon message à moi (enter)
(enter)
.(enter) <-- point final apres une ligne vide puis enter pour l'envoyer
Tu peux "t'exercer" avec deux clefs USB, en copiant de l'une vers l'autre et en essayant de la cloner sur l'autre ensuite, c'est un bon bac à sable
Citation
Oui, dans disk0s1 et disk2s3, cela concerne la 1ere partoche du disque #0 et la 3ème partition du disque #2 (s comme sector - pour bien utiliser la ligne de commande, il est important de connaitre ou de trouver un moyen mnémotechnique des argument . a comme all, q comme quit etc etc . ensuite c'est que tu bonheur car en fait tu lui parles "fait ci et ca puis ca" et on est beaucoup plus rapide. Moi je ne suis pas le switcher classique, quand je suis arrivé en 2005 sous Mac à cause de MacIntel, j'arrivais de Linux, et pas de WIndows. Et j'ai gardé des habitudes, donc il y a pas mal de truc certainement faisable avec une interfacer graphique mais je préfère le faire en ligne de commande quand je le sais
Ce message a été modifié par _Panta - 16 Feb 2018, 13:06.
- Airport Extrême
ronparchita
posté 16 Feb 2018, 14:45
Membre no 26 427
Citation (_Panta @ 16 Feb 2018, 12:57) *
Je donne ma langue au chat !
Ca donne :
Last login: Fri Feb 16 12:02:06 on console
You have mail.
[iMac-de-Ronparchita:~] Ronparchita% mail
Mail version 8.1 6/6/93. Type ? for help.
"/var/mail/Ronparchita": 37 messages 37 new
>N 1 Ronparchita@iMac-de-ron Tue Jan 5 16:19 24/1660 "Cron <Ronparchita@iMac-d"
N 2 Ronparchita@iMac-de-ron Mon Jan 18 12:30 24/1660 "Cron <Ronparchita@iMac-d"
N 3 Ronparchita@iMac-de-ron Mon Jan 25 09:09 24/1660 "Cron <Ronparchita@iMac-d"
N 4 Ronparchita@iMac-de-ron Mon Feb 1 10:56 24/1660 "Cron <Ronparchita@iMac-d"
N 5 Ronparchita@iMac-de-ron Mon Feb 8 00:07 24/1660 "Cron <Ronparchita@iMac-d"
N 6 Ronparchita@iMac-de-ron Mon Feb 15 08:18 24/1678 "Cron <Ronparchita@iMac-d"
N 7 Ronparchita@iMac-de-ron Mon Feb 29 01:44 24/1678 "Cron <Ronparchita@iMac-d"
N 8 Ronparchita@iMac-de-ron Mon Mar 7 10:03 24/1678 "Cron <Ronparchita@iMac-d"
N 9 Ronparchita@iMac-de-ron Mon Mar 14 09:50 24/1678 "Cron <Ronparchita@iMac-d"
N 10 Ronparchita@iMac-de-ron Mon Mar 21 09:16 24/1674 "Cron <Ronparchita@iMac-d"
N 11 Ronparchita@iMac-de-ron Sun Mar 27 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 12 Ronparchita@iMac-de-ron Sun Apr 3 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 13 Ronparchita@iMac-de-ron Sun Apr 10 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 14 Ronparchita@iMac-de-ron Sun Apr 17 23:59 19/880 "Cron <Ronparchita@iMac-d"
N 15 Ronparchita@iMac-de-ron Sun May 29 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 16 Ronparchita@iMac-de-ron Sun Jun 12 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 17 Ronparchita@iMac-de-ron Sun Jun 19 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 18 Ronparchita@iMac-de-ron Sun Jul 10 23:59 19/896 "Cron <Ronparchita@iMac-d"
N 19 Ronparchita@iMac-de-ron Sun Dec 4 23:59 19/894 "Cron <Ronparchita@iMac-d"
N 20 Ronparchita@iMac-de-ron Sun Dec 18 23:59 19/894 "Cron <Ronparchita@iMac-d"
Message 1:
From Ronparchita@iMac-de-Ronparchita.local Tue Jan 5 16:19:23 2016
X-Original-To: Ronparchita
Delivered-To: Ronparchita@iMac-de-Ronparchita.local
From: Ronparchita@iMac-de-Ronparchita.local (Cron Daemon)
Subject: Cron <Ronparchita@iMac-de-Ronparchita> /Applications/MacScan\ 2/MacScan.app/Contents/MacOS/MacScan -autoscan YES -autoquit YES
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=Ronparchita>
X-Cron-Env: <USER=Ronparchita>
X-Cron-Env: <HOME=/Users/Ronparchita>
Date: Sun, 3 Jan 2016 23:59:01 +0100 (CET)
2016-01-03 23:59:01.393 MacScan[62891:d07] ApplePersistenceIgnoreState: Existing state will not be touched. New state will be written to /var/folders/x0/25gl0s0m8xj6bn0059_yd0g80000gp/T/com.securemac.MacScan.savedState
2016-01-03 23:59:02.221 MacScan[62891:d07] Can't open input server /Users/Ronparchita/Library/InputManagers/SafariStand3.0L159
/Users/Ronparchita/Library/Caches/com.securemac.MacScan/Cache.db-wal: Permission denied
/Users/Ronparchita/Library/Caches/com.securemac.MacScan/Cache.db-shm: Permission denied
Jan 3 23:59:05 iMac-de-Ronparchita.local MacScan[62891] <Error>: SQLite: unixTruncateDatabase() failed with 10 for replacing '/Users/Ronparchita/Library/Caches/com.securemac.MacScan/Cache.db' with flags 0
2016-01-03 23:59:05.030 MacScan[62891:1407] ERROR: __CFURLCache:RecreateEmptyPersistentStoreOnDiskAndOpen - failed to find the main database for truncation. Err:10
Je n'ai mis que le premier sur 37
Ronparchita,
ronparchita
posté 17 Feb 2018, 18:52
Membre no 26 427
Citation (radioman @ 15 Feb 2018, 21:38) *
Ce n'est pas tout à fait l'utilisation que je veux en faire, mais si un SSD ça consomme moins qu'un disque à plateau, ça m'eviterait de me ballader avec un Disque dur 3,5 dans un boitier et un transfo pour l'alimenter quand je voyage, puisque je ne peux pas emmener mon ordinateur de bureau. smile.gif
Ronparchita,
ronparchita
posté 17 Feb 2018, 19:16
Membre no 26 427
(enter)
C'est l'environnement qui me choquerait.
Et puis avec Mail, j'ai les echanges qui s'enchainent, c'est bien aussi. La console permet de voir les photos jointes ?
Peut-être qu'avec le temps on s'habitue, je veux dire que quand on a un probleme à résoudre et qu'on passe par le terminal, on doit finir par dedramatiser cet écran qui pour moi n'est pas tres beau. Mais quand on le pratique et qu'on résous des problemes, il doit etre tentant plutôt que de changer de logiciel, surtout pour un petit mail, de rester sur la console. L'aspect ludique doit y faire aussi et puis toutes les capacités de cette console, ça doit tourner au défit permanent, sans compter que ça va super vite smile.gif
Ronparchita,
_Panta
posté 17 Feb 2018, 19:23
Message #22
Membre no 76 401
Mais sur des usages auquels vous ne pensez pas forcement, ça m'a permis par exemple d'envoyer des mails en passant en ssh sur sa propre machine pour bypasser un firewall ou des smtp bloqué.
- Airport Extrême
ronparchita
posté 17 Feb 2018, 19:41
Message #23
Membre no 26 427
Citation (_Panta @ 17 Feb 2018, 19:23) *
(...) envoyer des mails en passant en ssh sur sa propre machine pour bypasser un firewall ou des smtp bloqué.
La seule chose que je comprend, c'est SMTP bloqué. C'est douloureux comme un lumbago, et j'y perd des heures comme quoi je n'ai pas vraiment bien compris. biggrin.gif
Ronparchita,
_Panta
posté 17 Feb 2018, 20:44
Message #24
Membre no 76 401
En gros ca peut être utile de savoir envoyer un mail en ligne de commande tongue.gif
- Airport Extrême
ronparchita
posté 17 Feb 2018, 21:03
Message #25
Membre no 26 427
Citation (_Panta @ 17 Feb 2018, 20:44) *
Je le pense aussi,
Toi qui est multilingue, as-tu jeté un coup d'oeil sur les "mails" qu'annonçait ma console ?
Ronparchita,
_Panta
posté 17 Feb 2018, 23:25
Message #26
Membre no 76 401
Ah désolé, j'etais sous mon smart phone et n'avais pas vu tes logs.
Macscan.app qui essaye d'envoyer des résultats chez lui. Apparement ils ne sont pas passé, mais peut être certains oui car il y a une tâche cron (on en parlais plus haut en plus) qui regulierement reessaye. C'est un anti malware cette appli, je ne connais pas ? Car apparement cet app essaye d'acceder a des fichiers caches qui ne lui sont pas autorisé, et les mails sont donc des notifications de cette erreur.
Passe un coup de Malwarebyte dans un premier temps quand même.
tu peux aussi sans risque virer /var/mail/ronparchita, le system le recréera si besoin
sudo rm -rf /var/mail/ronparchita
Ce message a été modifié par _Panta - 17 Feb 2018, 23:37.
- Airport Extrême
ronparchita
posté 19 Feb 2018, 02:05
Message #27
Membre no 26 427
Le terminal m'a répondu : dd: /dev/disk0: Permission denied tongue.gif
MacScan est effectivement un antiMalware, pour scanner mon disque dur de 160 Go, il a mis 6:00 et m'a trouvé 73 cookies pisteurs qu'il m'a permis d'effacer, la première version était gratuite, la deuxième 7,90 dollars et la 3e 50 €
Ce message a été modifié par ronparchita - 19 Feb 2018, 02:29.
Ronparchita,
_Panta
posté 19 Feb 2018, 07:38
Message #28
Membre no 76 401
sudo dd if=/dev/disk0 of=/dev/disk1 bs=4096 count=1
Ensuite si c'est ton disque de démarrage qui est la source, tu ne peux le copier monté, il faut donc le faire en mode single user. (Ou à partir d'une clef ou CD d'installation booté)
Ce message a été modifié par _Panta - 20 Feb 2018, 12:46.
- Airport Extrême
ronparchita
posté 20 Feb 2018, 11:58
Message #29
Membre no 26 427
Citation (_Panta @ 19 Feb 2018, 07:38) *
Ca explique tout. Merci.
S'agissant de lignes de commande, Apple en communique quelques unes là : https://support.apple.com/fr-be/HT201372 pour réaliser des clés USB boutables (Merci Baron !).
Il doit falloir au moins une page pour expliquer toutes les commandes qui s'enchainent dans ces lignes, n'est-ce pas.
Ronparchita,
_Panta
posté 20 Feb 2018, 12:44
Message #30
Membre no 76 401
Citation (ronparchita @ 20 Feb 2018, 11:58) *
Ce message a été modifié par _Panta - 20 Feb 2018, 12:45.
- Airport Extrême
Nous sommes le : 19th February 2019 - 10:45
