> PC Gamer Hackintosh - Multiboot Win10 Pro & High Sierra 10.13.3, Un dual boot sur i7 8700k - GTX1080ti
thunder72fr
posté 2 Feb 2018, 17:24
Inscrit : 5 Jun 2015
Lieu : LE MANS
Membre no 195 534
PC Gamer Hackintosh - Multiboot Win10 Pro & Hight Sierra 10.13.3
Processeur Intel Core i7 6700K
Refroidissement Thermaltake Pacific RL360 Boitier
Thermaltake Core P5 & Kit Tempered Glass Edition
6 ventilateurs RGB & Controleur Riing Thermaltake
Asus Rog Front Base
Alimentation Seansonic 1000W
Carte mère ASUS ROG MAXIMUS VIII FORMULA
Mémoire Corsair Vengeance LPX 16 Go (2x8) DDR4 2400Mhz
Windows 10 Pro x64 sur 1 SSD Crucial BX100 500Go & 1 Disque Dur Seagate IronWolf HD 8 To MacOs
Hight Sierra 10.13 x64 sur 1 SSD Samsung 850 EVO 500Go & 1 Disque Dur WD 2To
Gigabyte Aorus GTX 1080 Ti Xtreme Edition 11Go
Carte Pci Express Combi Wifi 802.11AC, Bluetooth 4.0 ABWB BCM94360CD
Samsung 49" LED - C49HG90DMU (3840 x 1080 pixels - 1 ms - Format large 32/9 - Dalle VA incurvée - HDMI/DisplayPort - FreeSync)
Bootloader Clover r4392
Bios Setting:
1 - Extreme Tweaker
AI Overclock Tuner > X.M.P.
Extreme Tweaking > Enable
2 - Advanced Items
CPU Configuration > CPU Power Management Configuration > CFG lock > Disable
System Agent (SA) Configuration > VT-d > Disable
System Agent (SA) Configuration >Graphics Configuration > DVMT Pre-Allocated > 128M
PCH Configuration > IOAPIC 24-119 > Enable
USB Configuration > Legacy USB Support > Enabled
USB Configuration > XHCI Hand Off > Enabled
APM Configuration > Power on by PCIE/PCI > Disabled
Onboard Devices Configuration > Wi-Fi Controller > Disable
Onboard Devices Configuration > Bluetooth Controller > Disable
3 -Boot Menu
CSM > Disable (if no OS or UEFI GPT Windows)
Fast Boot > Disabled
Secure Boot > OS Type > Other OS
Boot Option 1 > UEFI SSD (qui sera le SSD Hight Sierra)
Exit > Save Changes
Création de la clé USB d'installation Hight Sierra:
1 - Téléchargment de Hight Sierra 10.13.3 par l'AppleStore
2 - Formatage de la clé USB avec l'utilitaire de disque sous format « Mac OS étendu journalisé » et sous Schéma « Table de partition GUID ». je lui donne le nom « clemacos ».
3 - Utilisation du Terminal où je rentre la commande suivante:
sudo /Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/clemacos --applicationpath /Applications/Install\ macOS\ High\ Sierra.app --nointeraction &&say Done
Hackintoshsation de la clé USB en installant clover en UEFI Boot
1 - Dans la partition EFI de la clé qui apparait, je supprime le dossier Clover et colle le dossier décompressé du lien suivant:
dossier clover à modifier pour le serial avec Clover Configurator
2 - Je démonte la partition EFI (en éjectant la clé ou en utilsant clover Configurator).
3 - Réutilisation de l'installateur Clover (comme si je faisais un mise à jour) sur la clé USB.
Démarrage sur la clé USB en ne branchant qu'un SSD (sur port SATA 1 Intel) et en activant la carte intégrée IGPU dans le bios (tout en enlevant la carte PCI-Express Nvidia)
Installation normale de Hight Sierra après formatage du SSD avec l'utilitaire de disque sous format « AFS » et sous Schéma « Table de partition GUID ». (voir tutos du forum).
Plusieurs rédemarrages.
Installation du disque dur DATAS (sur port SATA 2 Intel) (pour le stockage de jeux sous Steam, Origin, Battlenet) après formatage du DD avec l'utilitaire de disque sous format « Mac OS étendu journalisé » et sous Schéma « Table de partition GUID ».
Montage de la carte Nvidia (Dans le bios, j'active l'option multiGPU ( IGPX + PGU) pour avoir à la fois le chipset vidéo Intel et le GPU, en définisant l'odre de Boot en premier pour le PGU.
Intallation du Webdriver Nvdia 378.10.10.10.25.104 (modifié pour être compatible Hight Sierra 10.13.3), la modfication NVDAStartupWeb.kext ( dans Bibliotheque/extensions), le rebuild des caches dans la terminal:
sudo kextcache -system-prelinked-kernel
sudo kextcache -system-caches
Puis le redémarrage de la machine (demandé par l'installateur Nvidia).
Une fois redemmarrée, la carte Nvidia sera prise en compte avec l'accélération (tout comme le chipset Intel pour l'airport).
Je débranche les cables SATAS 1 & 2.
Je monte le SSD et le DD pour Windows 10 (sur port SATA 3& 4)
J'installe Windows 10 Pro avec une clé USB préalablment créée, avec la procédure habituelle.
Je rebranche la SSD Hight Sierra et son DD associé.
Modification dans le bios avec ordre de priorité de boot sur port SATA 1 (UEFI SATA)
Et vous avec un double boot Win10 Pro & Hight Sierra 10.13.3
Ce message a été modifié par jeanchrijaz - 24 Mar 2018, 14:50.
Macbook Pro 15" Retina Mid 2012/i7 3620QM/8Go/Nvidia 650M/Mojave-Win10 Pro
Mac Pro 4.1 @ 5.1/Dual X5690/64Go/Vega 56/Asus VQ275/Iiyama GE2288HS-B1/Mojave-Win10 Pro
PC Gamer Hackintosh /i7 8700K/ASUS Z370-E Gaming/32Go/GTX 1080 Ti/Samsung C49HG90DMU/3 x iiyama G2730HSU-B1/Mojave-Win10 Pro-Linux Mint
thunder72fr
posté 24 Mar 2018, 07:45
Lieu : LE MANS
Membre no 195 534
Je viens de terminer mon upgrade sur mon PC Gamer Hackintosh principal:
Processeur Intel Core i7 8700K
Refroidissement Thermaltake Pacific RL360 Boitier Thermaltake Core P5 & Kit Tempered Glass Edition
Asus Rog Front Base
Alimentation 1000W
Carte mère ASUS ROG STRIXX Z370-E Gaming
Mémoire G.SKILL Trident Z RGB 32 Go (4x8) DDR4 2400Mhz
MacOs Hight Sierra 10.13 x64 sur 1 SSD Samsung 850 EVO 500Go & 1 Disque Dur WD 2To
Bootloader Clover v4411
Quelques benchs sous Hight Sierra:
Une video de démonstration du multiboot:
Ce message a été modifié par thunder72fr - 24 Mar 2018, 07:49.
jeanchrijaz
posté 24 Mar 2018, 14:28
Inscrit : 22 Sep 2015
Membre no 196 549
Note de la modération
j'ai fusionné tes deux sujets
car ce qui serait intéressant au lieu d'ouvrir à chaque fois une nouveau sujet à chaque upgrade de ta machine,
ça serait que tu donnes un peu plus de détails sur la manière que tu as procédé et/ou les difficultés que tu as pu rencontrer
c'est d'ailleurs un peu le but de cette rubrique qui ne sert pas seulement à montrer son hack/ordi
et ce qui serait encore plus intéressant serait que tu nous fasse partager ton dossier EFI afin d'aider ceux qui comme toi voudraient passer sur un 8700k avec la même carte mère wink.gif
iPhone X🅂 256 Go Apple TV 4K 64 Go Macbook Pro Touch Bar 13" | 2017 | Core i5 | SSD NVme 512 Go | 16 Go de Ram | macOS Mojave 10.14.2 |
Hackintosh : SMBIOS iMac 14,2 |
🍀 Clover r4844 | macOS Sierra 10.12.6 (16G1710) | Présentation ici |
__Carte mère : Asus Z97-Pro (wifi-ac) • CPU : Core i7 4790K • Ram : 32 Go (4 x 8 Go) 2133Mhz • CG : EVGA GTX 1080 FTW
__• 2 x moniteurs 27" WQHD (2560 x 1440) • Carte combo PCI-E
BCM94360CSAX
Carte son : AVID Pro Tools Quartet (Apogee)
Disque Système : 960 EVO 250 Go NVme | Disque de Rendus : 950 PRO 256 Go NVme | Disque Cache : 850 EVO 500 Go | Stockage interne : 3 x 3 To en Raid 0
_ NO WINDOWS BOOT... Only
Politique vis à vis des outils automatisés - FAQ Générale du Hackintosh - FAQ des Bootloaders - FAQ des Bootflags - FAQ des problèmes les plus courants - Guide d'installation
IISGORZ
posté 24 Mar 2018, 20:14
Inscrit : 30 Sep 2014
Lieu : Cherbourg-Octeville
Membre no 192 176
@jeanchrijaz,
Bonsoir, pour info c'est pas du tout la même carte mère, Thunder72fr est passé d'une Z170 à une Z370E ..... biggrin.gif
Myhack: Gigabyte GA-Z170-HD3P /Intel Core i5 6600/2X8 Go 2133Mhz DDR4 HyperX Fury/SSD Samsung 970 EVo M2 nvme 250Gb/Mac OS Mojave /Samsung 860 Evo 500Go Data Mac/Sandisk Ultra Plus 120Go/Windows 10Pro/ SSHD 1To 64Mo 3.5"/ Sapphire Radeon RX 570 8Go/Clover EFI
Asus P8H67-M /Intel Core I5 2500/ 2x4Go kingston 1333Mhz/ Gainward GeForce GTS 250 / Mac OS Mojave /Clover Legacy/Hitachi 2.5" 500Go/Windows 10 pro/ Sandisk 128Go -
Notebook PC Asus A6J Intel Centrino Duo T2300E 4Go de ram Pata / Windows7
FTTH SFR @100Mo Down 50Mo Up
Carpediem !!!!!
jeanchrijaz
posté 24 Mar 2018, 20:33
Membre no 196 549
Citation (IISGORZ @ 24 Mar 2018, 20:14) *
@jeanchrijaz,
j'ai bien écrit clairement que si quelqu'un achète la même carte que lui ça serait intéressant de connaitre son EFI et la procédure qu'il a suivi pour upgrader
Citation (jeanchrijaz @ 24 Mar 2018, 14:28) *
BCM94360CSAX
Yellocab
posté 25 Mar 2018, 00:13
Inscrit : 7 May 2017
Lieu : Lyon
Membre no 202 099
Hello thunder!
On se retrouve ici 😉
N°1: 🍀GA-Z370-UG - i7 8700k - Nitro+ Vega 64 8GO - 32 Go 3600 DDR4 - 1xSSD (win10) + 1xSSD NVMe 960 evo + 1XSSD TimeMachine - HD 1To
N°3: 🍀GA-H110M S2H- i7 6700k- GA GT 1030 - 8 Go DDR4 2133- 2XSSD (macOS+Win10) - Carte Combo Wifi/BT PCI
 MBP 2017 13 pouces Touch Bar
IISGORZ
posté 25 Mar 2018, 10:10
Membre no 192 176
@jeanchrijaz,
Pour moi , la même carte mère voulais dire la première....
Ce message a été modifié par IISGORZ - 25 Mar 2018, 10:12.
Carpediem !!!!!
thunder72fr
posté 29 Mar 2018, 20:17
Lieu : LE MANS
Membre no 195 534
Pour ceux que cela intéresse, j'ai mis en pièce jointe mon config.plist (Serial perso bien sûr modifié).
Le Airplay minorring est activé. (Voir tuto dans le forum: Nvidia GTX 1080ti avec Intel 630 HD avec mémoire 192 Mo dans le EFI de la carte mère).
Config.plist modifié pour faire apparaitre de manière cosmétique les 4 barrettes de G.SKILL Trident Z RGB 32 Go (4x8) DDR4 2400Mhz.
La wifi et le bluetoothh de la carte mère sont désactivés.
J'ai à la place cette carte pci-express reconnue nativement (que je possède depuis plusieurs hackintoshs) :
ABWB 802.11AC, Bluetooth 4.0 WI-FI PCI Express (PCI-E)-Carte Combo BCM94360CD Hackintosh (pour MAC OS X)
Double boot donc 2 ssd (un par systeme)
Clover v 4411.
thunder72fr
posté 10 Jun 2018, 09:38
Lieu : LE MANS
Membre no 195 534
Je viens de terminer mon Triple Boot Hight Sierra 10.13.4 / Win 10 Pro / Ubuntu 18.04:
Un SSD par systeme
Dernière version de Clover: 4509
J'ai réaménagé mon bureau juste auparavant:
Ce message a été modifié par thunder72fr - 10 Jun 2018, 17:07.
_Panta
posté 10 Jun 2018, 09:57
Inscrit : 24 Dec 2006
Lieu : "Over The Rainbow"
Membre no 76 401
Belle machine.
Ca donne quoi sur des bench classique OsX ?(geekbenck, cinebench ..)
Et les mêmes sous Linux et Windows ? Cela serait interessant de voir les differences sur la même série de bench
Ce message a été modifié par _Panta - 10 Jun 2018, 09:59.
- Macbook Pro TouchBar 15" T1 - 512GB/core i7@2,7Ghz
- Macbook Air 13,3" core i5 - iMac 27" core i5 - iPhone7@128GB
- Airport Extrême
- Fbx Delta Devialet
thunder72fr
posté 10 Jun 2018, 17:15
Lieu : LE MANS
Membre no 195 534
J'ai fait quelques benchmarks sous Ubuntu aussi mais je n'ai pas fait de captures.
Le Multiboot Hight Sierra 10.13.4 / Win 10 Pro / Ubuntu 18.04, c'est plus par fun.
J'ai même réalisé une installation de TrueOS (anciennement PC-BSD ou PCBSD ), système d'exploitation basé sur FreeBSD, sur un 4ième SSD (Que j'ai démonté depuis).
Même mes machines Apple, ont droit à un multiboot (avec bootloader Refind). Une habitude.
Ce message a été modifié par thunder72fr - 10 Jun 2018, 17:20.
_Panta
posté 10 Jun 2018, 19:55
Membre no 76 401
Merci !
- Airport Extrême
Yellocab
posté 2 Jul 2018, 20:44
Lieu : Lyon
Membre no 202 099
Thunder la star!
blackhole
posté 3 Jul 2018, 12:44
Inscrit : 27 Sep 2010
Lieu : Clermont-Ferrand
Membre no 159 444
Citation (Yellocab @ 2 Jul 2018, 21:44) *
Thunder la star!
Ça fait déjà 1 semaine que j'ai vu l'article et j'hésitais à "balancer"...! biggrin.gif tongue.gif dry.gif rolleyes.gif wink.gif
Mais je vois que Yello à envie de se faire payer l'apéro...! biggrin.gif laugh.gif rolleyes.gif
À jour du 31/10/2018
Laptop; 1 - MBP mi-2012 --> SSD 10.14.12 - ProBook 4540S --> SSD 10.13.63 - ProBook 4530S --> SSD 10.13.6 (famille) • 10 - ProBook 4530S --> SSD 10.13.6 (famille)
Desktop; 4 - Z170X-Gaming 5 + i5 6600K + Bi-GPUs (GTX980Ti 6Go +GTX760 2Go) + 16Go 3000MHz --> SSD 10.13.6 + SSD 10.14.0 No-WD + SSD WinDob 10 - (Mon Topic Retex)5 - Z87N-WiFi + i5 4690 + GT640 2Go + 4Go 1600MHz --> SSD 10.13.66 - Z87X-UD5H + i7 4770k + GTX980 4Go + 16Go 1600MHz --> SSD 10.12.6 (famille) • 7 - P5QL-Pro + E7600 + 8400GS 512Mo + 8Go 667MHz --> SSD 10.11.6 (famille) • 8 - P5Q-Deluxe + Q8300 + GT610 1Go + 4Go 1066MHz --> SSD 10.11.6 (famille) --> Dead9 - P5KR + Q6600 + GT218 512Mo + 8Go 800MHz --> SSD 10.12.6 (famille) • 11 - P5KPL-VM/V + E7600 + GT210 1Go + 8Go 800MHz --> SSD 10.13.3 (famille) • 12 - P8H61/USB3 + i5 2300 + GT210 1Go + 8Go 1333MHz --> SSD 10.13.613 - P8H61-M LX3 PLUS R2.0 + i3 2120 + GT210 1Go + 4Go 1333MHz --> SSD 10.13.6
Mobile; iPhone 6S Gold 16Go --> iOS 11.4.1iPhone X White 64Go --> iOS 11.4.1iPad Pro 2017 Sidéral 10,5" 64Go --> iOS 11.4.1
Yellocab
posté 3 Jul 2018, 18:40
Lieu : Lyon
Membre no 202 099
Un apéro Hackintosh... une rencontre de gros geeks .... ça va me rappeler le bon vieux temps de l'Amiga...
Nous sommes le : 18th January 2019 - 19:32
